FD Lens Bushing Repair - Here's a How To for the Canon FD 24mm f2.8
Started Feb 3, 2016 | Discussions
bolesautomotive
bolesautomotive Forum Member • Posts: 99
A few days ago I asked for help locating the microfiche or parts list for this lens. No response from the community led me to think either no one cares (likely do to age of lens) or no one could provide a suitable answer. So, I came up with a solution. I hope this helps someone in the future.
Images are not for beauty so don't expect much. Also, the lens being repaired has been well loved and obviously seen many days loose in a bag.
If your FD lens flops around inside the barrel or if the lens moves forward and backward freely you may have worn bushings. This lens had worn bushings that allowed the rear lens group to move in and out by 2mm making focusing a pain.
Here's how I fixed mine. If you attempt this do so at your own risk. This is to help those who wish to try this on their own. Myself and this website cannot be held responsible if your lens suffers in any way from an attempt by anyone to do what I have done here.
Here we go
Front of the lens.
To start the plastic lens ring with CANON LENS FD 24mm 1:2.8 is removed by unscrewing it counter clockwise. This can be achieved using a large rubber o-ring pressed against the plastic and turned counter clockwise. I didn't take a picture of the o-ring but it needs to be thick enough to extend beyond the barrel. If you can't do it by hand just push the lens face down onto a table with the o-ring between the lens and the table and unscrew the lens from the o-ring. I acquired the o-ring from a kit I use at my automotive shop. They are less than $1 USD at the auto parts store.
Plastic Ring Removed
Now with the plastic name plate ring removed you can see these six phillips screws. Removing three of these will allow for the lens filter ring to be removed. The other three will allow the front lens group to be removed. Once you remove all six of these screws be prepared for the front element group to fall out. Don't drop it!
Front Lens Group Removed
With the front lens group removed you can now see the inner lens group. The inner lens group and rear lens group are attached together. They are both attached to the inner black barrel you see here. At this point you will want to mark the orientation of the parts you can see here. Set the lens to infinity focus and make a scratch mark across the two inner barrels and inside the outer barrel. This is crucial. If you do not mark the orientation of the barrels you will be in for a long frustrating night trying to clock the lens properly. This lens must be timed in order to work properly. Don't let this deter you, just be sure to take plenty of pictures and always work from either infinity focus or the lock past 0.3 m.
Rear View with Lock Ring and Rear Cover Removed
The rear mounting ring (silver) can be removed by removing the three black screws on the outside of the barrel that hold the ring to the barrel. The first screw is next to the lens mount release button. WARNING - These little guys are often in with thread locker. It is ESSENTIAL that you use a quality screw driver of the proper size. Using a cheap screw driver or the wrong size will strip the screw heads which will then need to be drilled out (not fun).
In this picture the rear cover has also been removed. The rear cover holds the lock level and aperture level. Once the mount ring has been removed the rear cover can be lifted from the lens. You will hear the aperture lever in the lens click as it moves to a resting state. No worries this is not a problem.
You now see the three screws which are visible in this picture. These three screws hold the mounting ring release button barrel to the lens. Remove the three screws you see in this picture and lift the release button barrel. Beneath is the aperture control ring.
Aperture Ring Removal
Now you see the aperture control ring. Turn the aperture to f2.8 and lift the ring up. There are no screws here to remove. Immediately turn the aperture control ring over and make sure the steel dowel has not fallen from the ring. There is a very small dowel approximately 2mm by 1mm in this ring. This dowel is what provides resistance and makes the clicks you feel when changing the aperture. Without it you will not be able to lock the aperture in any single location. TIP - Once the aperture control ring is removed and you see that the aperture dowel is still in place dab a small amount of grease on it to keep it from growing legs while you continue to work on the lens.
The two tabs sticking up next to the rear lens group are the aperture lever and lock lever. You can play with these to see how they function. It will be a good idea to familiarize yourself with how they operate so assembly will go smoothly later on.
Aperture Control Ring Removed
Now you can see the two stays secured by four phillips screws. These stays are basically guides. They keep the inner barrel from rotating with the middle barrel. This is why it is crucial to mark the barrel before disassembly. They must be clocked correctly or the lens will not function properly.
AFTER MARKING THE BARRELS remove the four screws. Once these four screws are removed the middle barrel, inner barrel and lens group can be removed as an assembly from the focusing barrel (outer barrel). Once again, I can't stress the importance of marking the barrels not only to line up but also for depth when lined up.
Don't twist this assembly out yet.
Rubber Removal
To remove the rubber grip from the focus barrel just slip it over the front of the barre. Simple as that!
Outer Barrel Seperation
The outer barrel separates into two halves. The separation point is beneath the grip. Just pull it apart. There are no screws or secret tricks here, just a good hold and strong pull will separate the two halves.
Middle barrel, inner barrel, lens group and bushings.
Here we have removed the middle barrel, inner barrel and lens group from the outer barrel. If your lens had smooth focusing youwill not need to remove this completely from the outer barrel (and I strongly suggest not removing it unless completely necessary).
With this removed we can see holes in the aluminum barrel. One is notched while the others are simply circular holes. The notched hole is the one that allows removal of the bushings. In this picture you can see the three brass bushings lying to the left of the barrels.
If you do not need to remove the aluminum barrel from the outer barrel then only rotate it outward enough to see the square window in the aluminum barrel. Once you can see clearly into the square window then rotate the inner barrel until a screw becomes visible within the window. Remove the screw and bushing then rotate the lens until the next screw is visible in the window. There will be three of these screws/bushings. Remove them through the window. Be Careful - when you remove the last screw the inner lens group will slide out Hopefully you marked the orientation of this group so you can put it back together correctly. Make sure you mark where the first screw was removed from and which way you turned he inner barrel to access the following screws. If you don't you will not have correct infinity focus or possibly will not be able to reassembly the lens properly.
If you did remove the middle barrel and inner barrel you can clean them. I used white lithium grease in very small amounts to lubricate the threads of each barrel. You will find much more grease in the lens than is actually needed to function properly. The old grease will be grey due to metal particulates that have been captured in the grease. It used to be nearly clear!
Heat Shrink Tubing used to increase bushings thickness
My first attempt I used black heat shrink tubing to add thickness to the bushings. The problem I ran into was that grease saturation of the heat shrink caused it to deteriorate and lose shape. This caused the focus ring to become difficult to rotate. This is simply to show the process I went through. Do NOT use regular black heat shrink tubing.
Heat Shrink as a bushing sleeve.
This is what the heat shrink tubing looked like when used as a bushing sleeve. During installation the sleeve wanted to slide off the bushing further making this less useful for this repair.
Plastic Heat Shrink Tubing Works Best!
Here plastic heat shrink tubing was used. The bushing is installed only two show it on the inner lens group. I cut approximately 3mm long tubes from this heat shrink sleeve. I held the bushings with a dentist pick a allowed the heat shrink tubing to hang around the brass bushing. I heated the shrink with a lighter until it formed tightly to the bushing.
NEXT - The bushing will need to be sanded to fit into the square opening on the aluminum barrel just as the bushings were removed. Sand the heat shrink to make a square that fits easily into the aluminum barrel. I did this with an old nail file. Do not sand into the bushings. This will cause additional play in the bushings and will require they be replaced.
If you did not remove the middle and inner barrel from the outer barrel you can now fit the bushings into the square window. Apply a small drop of lubricant to each bushing once it's been installed to the barrel.
Assemble in reverse direction and enjoy your lens! Mine is rock solid now.
AGAIN - I cannot stress how IMPORTANT it is that you mark the orientation of each piece. If not you will have to reverse engineer how the focusing mechanics works and how to clock it properly. Even if you get it to line up properly you may find the aperture does not function properly or focus is not correct. I have made this mistake on several lenses while being in a rush and all I can say is if this happens, breathe, be patient and take breaks.
Hope this helps! Have a great day!
 bolesautomotive's gear list:bolesautomotive's gear list
NEX-5T Sony a7 II Sony a7R III Sigma 35mm F1.4 DG HSM Art Sigma 30mm F2.8 DN | A +14 more
photonius Veteran Member • Posts: 6,895
Re: FD Lens Bushing Repair - Here's a How To for the Canon FD 24mm f2.8
thanks   getting at information from before the days of the internet is not trivial
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
Shirozina Contributing Member • Posts: 736
Here we go
Front of the lens.
Rubber Removal
Great post. I've got lots of FD glass in various states of 'repair' - I've found them mechanically over-complicated compared to lenses of a similar age from other manufacturers which always makes them more of a challenge to work on and repair. Once forgotten due to the register problems which made them incompatible with EF bodies they are now seeing a resurgence due to their adaptability to mount on mirrorless cameras. Some lenses are very good ( the 24mm 2.8 being one of them) but you have to be prepared do some DIY on them like this to get the focus ring to feel nice without backlash.
bolesautomotive
OP bolesautomotive Forum Member • Posts: 99
Glad to see someone else post with experience.  Yes, it is just so easy to get them clocked wrong.  If that happens (as you know) the lens will not seat properly at either end of the focus setting.  On the 85mm 1.2L the rear lens group can be damaged by not clocking it properly as it will crush into the rear lens cover.  If anyone reading this is planning on tackling any L glass I'd suggest gaining much experience with less expensive lenses first. The L series are much more difficult to repair.
On another note, the EF stuff appears to be much easier to repair.  My experience however limited has been that the newer lenses are more straight forward.  Just have to be careful not to damage circuit boards, gears and ribbons.
jakutsu New Member • Posts: 2
Thank you very much for this post. I bought a canon FD 24mm F2 from ebay 6 months ago and it has been lying in parts because I didnt know how to open it and fix the loose focus issue. I already fixed the stuck aperture (which was stuck). But then noticed the loose focus.
Your photos showed that there is a rubber grip that can be removed and under that was one screw and after that the whole bushnell thing assembly came out and I could remove every possible piece.
I never thought the rubber grip was removable, under it was the last screw.
Now to the hardware store to get some heat shrink!
Thank you.
bolesautomotive
Thank you.
You're welcome....just be sure to get a high quality heat shrink that will not degrade in petroleum products.  The first heat shrink I used (black type) softened after a few hours in the silicone that I use to lubricate the threads.  Use the clear plastic type shrink.   Secondly, be sure to mark the orientation of the lens as you disassemble it or you will have a long trial and error process reassembling the unit.  You'll find that the rear element either will not seat correctly when at infinity focus or the rear element will be too far extended not allowing infinity focus to be obtained.  Marking the lens barrels/sleeves is crucial when repairing any lens.
Glad I could help!  Good luck!
SQLGuy
SQLGuy Forum Pro • Posts: 12,672
I have an old-FD  (breech lock) 24/2.8 where the MFD focus stop seems to be broken. The focus itself is smooth, and stops at infinity correctly, but at the MFD end it binds a bit past .3m, rather than stopping hard there.
Anyone know how much of the lens needs to be disassembled to get to the MFD stop? I'd rather not disassemble more than is needed.
A7-II with kit lens and a number of legacy lenses (mostly Canon FD); NEX-7 converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Sony Mavica FD-91 Sony Cyber-shot DSC-S70 Sony Cyber-shot DSC-V3 +45 more
bolesautomotive
That would require the lens to be fully disassembled.  Sorry for the late reply btw.  It's possible that the original grease in the lens has dried and caked up or possibly debris have collected near the close focus stop.  There is also a chance that someone had it apart in the past and did not reassemble properly.  The barrels can be screwed to the inner elements by starting from more than one location (multiple thread design) but they are designed to land on the close focus stop from only one assembly clocking position.  This is why it's important to identify exactly where the body and inner body come apart for reassembly.  If that is not known (like what could be possible in your case) then the body will need to be assembled multiple times until the correct clocking is found.
SQLGuy
faisalnuqo New Member • Posts: 2
Fd 24mm ssc
I can't remove front elements group, Ssc model have 8 screws. Can anyone help?
Herbert_GH2 Junior Member • Posts: 47
Great Article!
It looks like only the focus ring of my 24mm lens has some play. It moves about 1mm before engaging. But focusing itself is smooth. No problem at all when photographing but a little annoying when filming as the microphone catches the "click" when the ring engages. Also a faint grinding noise when moving.
Is the focus ring the outer barrel? Do I need to to the disassembly as described, with marking the barrels and so forth? Or is the focus ring a part of it's own, that can be dealt with, by only removing the front lens element?
Best, Herbert
