15-85mm Lens Blur
Started Feb 1, 2016 | Discussions
omri2 New Member • Posts: 1
15-85mm Lens Blur
Hi,
I'm new here and would appreciate some help.
After having a 500D for five years, half a year ago I finally got my second lens - Canon 15-85mm. I really enjoy both the wide and medium-telephoto ranges of this lens.
However, right from the start I began noticing that in many of my pictures the right side was heavily blurred - and attributed it to me being a beginner (Thought maybe out of focus, or small DoF). I was in Zurich last week and finally got to a conclusion that this must not be the case. Attached is a sample picture which illustrates the problem clearly (notice how, when viewed 100%, the buildings on the right are really blurred).
So I made a test and took some pictures near my house with a tripod and the same parameters. Once with the usual UV filter on, once off, and once with my old kit lens.
Apparently, the UV filter had a lot to do with the blur. Yet I am still pretty sure the right side of the picture is not as sharp as it should be. The pictures are attached.
So basically few questions:
1) Do you also notice any difference in sharpness from the left side and the right side of the picture (without the UV filter)? Or is this just me being too critical? I guess lens softening should at least be symmetrical...
2) Is this normal for UV filters? Mine is this one from Hoya. Are the more expensive ones better in this regard? Or should I just go without one if I want ultimate sharpness?
Thanks.
15-85mm lens with the UV filter
15-85mm without the UV filter
18-55mm
Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3)
role_of_72 Junior Member • Posts: 32
Re: 15-85mm Lens Blur
Hi and welcome on dpr forums!
I'm no expert but as I looked through your pictures there is clearly a difference between the left (better) and right sides of the frame.
I would not attribute it to the UV filter you have. I have the same filter on my Sigma 10-20 (although a 77mm Japan made one) and it can cause some flare in contra-light situations and with street lights at night but this blur is not because of that.
The houses/trees on the left and right sides are approximately in the same distance so it is not a DOF issue. I would also like to mention that these pictures does not even show the wide open performance! If I were you I'd try it wide open, too, because stopping down to F9 of F10 (like you did) can even hide a part of the problem.
By the way my Canon 18-135mm stm has a bit of this problem, too, but I noticed it only on a few shots and notat all focal lengts. The thing I can advise you is to go out with your tripod and do an extensive test wide open at all the marked focal lenghts (lens IS off, 2sec timer, mirror lockup, etc... you know ).
Then examine the results and decide whether it worths a repair or not (repair cost, warranty?). For example my lens is adequately sharp on the blurrier side even on 40x60cm prints so I decided to use it the way it is. But it differs from case to case.
Have good luck with it!
 role_of_72's gear list:role_of_72's gear list
Canon EOS Rebel T4i Canon EOS M5 Canon EF 50mm F1.8 II Sigma 10-20mm F4-5.6 EX DC HSM Samyang 8mm F2.8 UMC Fisheye +4 more
trulandphoto Senior Member • Posts: 1,019
Also, at the apertures you made those shots with an APS-C sensor diffraction will certainly be contributing some softness. I try to stay around f/5.6 or f/6.7 on crop sensors.
The problem with slower zooms is then you're pretty much shooting wide open. No real room to stop down without diffraction creeping in.
 trulandphoto's gear list:trulandphoto's gear list
Canon EOS R Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F2 Macro IS STM Canon RF 50mm F1.8 STM +3 more
plantdoc Veteran Member • Posts: 4,339
I couldn't tell much looking at your posted pics. However, shoot more test pics at wide open aperture. It took me 3 tries to get a copy of this lens that was decentered, soft along the left 20% at wide angle. For me, this has been a common problem with zoom lenses. It usually will occur at certain FL or even distances. Haven't had good luck with obtaining a repair for this issue. Also, I always test on two different cameras to be sure the lens mount isn't the issue. Fix lens cameras can also have this problem. Apparently, lens elements aren't precisely aligned and once assembled a fix may be difficult.
Greg
photonius Veteran Member • Posts: 6,895
omri2 wrote:
Hi,
Thanks.
Does not look so good, looks like you have a skewed/tilted lens. In the first picture, it looks like the focus on the foreground trees is sharper on the right, but in the background its not sharp, while on the left the background is sharp. More difficult to say with the other shots, but overall I do suspect something is not right with your lens.
Try shooting a brick wall straight on, then turn the camera 180 degrees upside down. If the blurriness moves with the camera, it's the lens.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
M Stewart Contributing Member • Posts: 985
Sounds like your lens is decentred.
It's happened to several of mine (including L lenses), and your Canon service centre may have a standard charge for doing the fix, and bringing it back to spec.  (I owned a 70-300L for 2 years using it on a cropped body without problem, then I tried it on a full-frame 5D MkII, and I had it back to Canon within a week!  Now it's sharp all over.)
M. Stewart
Milton Keynes, UK
 M Stewart's gear list:M Stewart's gear list
Canon EOS M Canon EF 15mm f/2.8 Fisheye Canon EF 20mm f/2.8 USM Canon EF 24mm f/2.8 Canon EF 35mm F2.0 +15 more
