Canon XSi (450D) and Tokina 12-24mm Lens ( Focus issue )
Started Feb 1, 2016 | Questions
Lokito Regular Member • Posts: 151
Hello,
I know this is really old equipment, so old most of you might not even be familiar with it but I still use it because it is sufficient for most of my needs.
I use a Canon Rebel XSi 450D which produces outstanding results with the kit lens 18-55mm.
Because I do mostly street photography I wanted a wider lens and I purchase a mint like new condition Tokina 12-24mm wide angle lens after reading endless good reviews about this lens.
But ever since I got it, I can not manage to get a good sharp shot, it almost appears as if the lens diminished the camera resolution, very disappointing. I have always read that wide angle lens, they so wide that the whole frame is almost always in focus, sharp, but not in my case.
I want to avoid that taught that I got screwed with a defective lens that needs to be aligned and calibrated.
So...
Any ideas of why these could be happening ?
Could it be me that is not using the proper techniques to breath and hold the camera while shooting ?
Any pointers would be welcome.
Thanks in advance.
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2) Nikon AF-P 18-55mm F3.5-5.6G VR
Lemming51
Lemming51 Forum Pro • Posts: 15,278
post some samples?
CaNik wrote:
I want to avoid the thought that I got screwed with a defective lens that needs to be aligned and calibrated.
Posting some sample shots with the EXIF and your AF settings and intended target would help to diagnose whether it's the lens or your technique.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
brightcolours Forum Pro • Posts: 15,885
You have shown NO samples.
CaNik wrote:
Hello,
So...
No, you do not show any samples.
Well, not really no: it is possible that the lens just focusses very inaccurately, and that you will be better off focusing manually or set it to infinity as standard (my 12-24mm f4 focussed very badly on my 450D). But again, without samples we can't say anything about your lens and camera combination results.
Thanks in advance.
