17-85mm EF-S Err99 lens repair in the UK?
Started Jan 31, 2016 | Discussions
C Andrew Green New Member • Posts: 7
Anyone in the UK used one of the eBay lens repair services?
So far I've seen at least three different repair devices advertised, two of them advertise replacing the iris and ribbon cable assembly, the other one replaces just the ribbon cable.
They all charge around £40.00 which appears to be about half of what camera repair shops quote, good deal or too good go be true?
I'm pretty sure my iris ribbon cable is the problem as it works OK at the long end of the zoom and not below 24mm at the wide end...…..
Regards
Andrew
 C Andrew Green's gear list:C Andrew Green's gear list
Canon EOS 400D Canon EF 50mm F1.8 II Canon EF-S 17-85mm f/4-5.6 IS USM Canon EF 75-300mm f/4.0-5.6 III USM Sigma 18-50mm F2.8-4.5 DC OS HSM +1 more
kreygscott
kreygscott Senior Member • Posts: 1,285
Re: 17-85mm EF-S Err99 lens repair in the UK?
Um ... Why not consider Canon's repair service?
My Blog
http://prakticalphotography.blogspot.com
My Website
https://scottcraigphotography.smugmug.com/
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
kreygscott
Although it's a bit more costly there's no price you can put on having a piece of mind.
My Blog
My Website
NetMage Senior Member • Posts: 2,910
The 17-85 was never considered very good- time to consider an alternative?
-- Please remove the Quote option!
-- How about switching to real forum software?
 NetMage's gear list:NetMage's gear list
Canon PowerShot SD1000 Sigma DP1x Panasonic Lumix DMC-LX5 Fujifilm X10 Fujifilm X-S1 +23 more
Michael Thomas Mitchell Forum Pro • Posts: 12,158
Regards
Andrew
Although I made good money here and there with this lens many years ago, this is a lens that's pretty well past its prime and maybe not a good candidate for repair. Canon fixed this exact issue on this lens for me, but it was covered under warranty. I'd be looking at other -- and better -- lenses to replace this one rather than dumping money into this one.
 Michael Thomas Mitchell's gear list:Michael Thomas Mitchell's gear list
Canon EOS-1D Mark II Canon EOS 7D Mark II Canon EOS 80D Canon EOS 5D Mark IV GoPro Hero7 Black +6 more
