35LII vs. 35L samples
Started Jan 31, 2016 | Discussions
J A C S
J A C S Forum Pro • Posts: 20,544
5
A few comparisons below. The light outside was changing and this may have affected some of the results a bit. All focused in LV and processed in LR with lens module off, same WB, all other settings default. The 35L is always first below, then the 35LII. The 35LII is sharper, of course but I was not testing just for sharpness. The old 35L looks quite sharp, as well but with more CA (of course). I was mostly interested in the OOF blur. It is hard to test for that, so do not take this too seriously.
The I looks slightly wider but the entrance pupil of the II is positioned slightly farther away from the sensor, which could make a difference for objects close enough. You can see the perspective changing just a bit with the II (like if you step closer). This could change the bokeh a bit but not by much.
The 35LII has a noticeably better bokeh in certain situations but my test today was not enough to demonstrate this. My impressions are based on those and other comparisons, as well. Even here however, you can see that the II has vey well defined blur disk. That was noticed by other people before. I was not sure if I would like it, but now I see that I do.
35L. Visible CA and more flare but still very good.
35LII. The bokeh on the right is visibly better. This scene (and the rest) is not challenging enough, however.
35L
35LII
35L. Focus on the left
35LII. I wanted to focus on an object farther away but this composition did not include bokeh near the borders, where things are worse.
BAK Forum Pro • Posts: 26,019
Re: 35LII vs. 35L samples
Any copies of the last shot at a decent aperture, so we can see the room?
As test locales go, it looks warm and welcoming, and I'd like to see the room, know where it is, and know who the men worthy of busts are, and what they did.
I do recognize the effort that went into the tests.
That said,
I spent ten minutes squinting at the fuzziness. I remain conclusion free on the cost-benefit analysis.
BAK
J A C S
OP J A C S Forum Pro • Posts: 20,544
Do you want to know the story of the test charts when you see a resolution test? Think of this room as a test chart.
That said,
As I said, those are tests. I did use it "in the field", and so far (I had it for a few days only), the results are excellent. But I do not post photos of relatives or friends here, sorry. Nor photos of my house.
cpharm86 Senior Member • Posts: 2,742
Thanks for the quick comparison. I am going to purchase the 35 f/4Lii this March. Looking at your quick comparisons I don't see $700 difference between the both versions.
My typical purchasing habits though are to go with the newer version.
LaszloBencze
LaszloBencze Contributing Member • Posts: 828
Thanks for the tests. I like them and thought they were useful. There is no doubt the II version is the better lens. This is most obvious in the chromatic aberration visible in the overexposed windows. However, the degree of chromatic aberration shown by the I version is hardly obnoxious. It is fairly trivial to the impact of the image. Moreover, the color fringing is easily removed in RAW conversion.
As for sharpness, I do believe the II version reveals a tad bit more sharpness but it is amazingly subtle. You have to look hard and go back and forth between the two versions to notice it. I doubt that anyone would ever object to the degree of sharpness revealed in the I version. In personal impressionistic terms, I'd say that the II version is about 5% better than the I version.
In terms of return on investment, it is important to remember that the I version can be had used on ebay for around $900 these days. The II version costs $1700. Yet, results produced by the original I version would be perfectly acceptable to any client, wedding or commercial. Moreover, the differences between the two lenses disappear by f4.0. I decided not to sell my I version and buy the new II. I just can't justify it.
J A C S
Actually, in another thread, I advised the OP to get version I. Not that II is not better in any respect except for size and weight.
The difference matters to me mostly in the bokeh area. I have a number of shots with the I with a double line busy bokeh. This is a small percentage of all the images wide open with that lens but it bothered me. Today, I could not really challenge either lens to reproduce the busy bokeh. In some other shots around the house, I can see the difference better.
Here are the crops I posted there, It is easy to say which is which and I was testing for performance in backlit situations.
EDIT: Here is a bokeh comparison taken near the left border of the photo above, 100% crop.
LaszloBencze
Thanks once again. These samples certainly do emphasize differences. Everything comes out in favor of the new version quite clearly.
But here's my situation: I bought the 35 mm I some years ago for $1595.00. I am loathe to sell it for $900 (or less) to reduce problems which are either easily correctable (chromatic aberration) or very subtle (sharpness).
If I did not already own a top shelf 35mm lens and wanted to purchase a new one, of course I would go for the II. It's only $200 more than what I paid for the I. But that's not the situation.
One other factor is that when it comes to wide angle lenses, I almost always want great depth of field. Therefore, when I do use the 35mm lens, it's generally stopped down to f8 or smaller. And as I already mentioned, when stopped down there is virtually no difference between the two lenses.
Again, I do appreciate your good work on these comparisons. They bring the lens chart comparisons to life.
LaszloBencze
I agree that the bokeh in the type I lens is distracting. However it is possible to adjust such things (assuming it really bothers the photographer) by adding lens blur in Photoshop. I took the liberty of adjusting the I version you posted here:
Yes, it was an troublesome extra step. But it did work.
maiaibing Veteran Member • Posts: 5,139
I generally see the difference in CA and PF which can be pretty bad with the 35L. Not in the bokeh.
For the price difference it remains a doubtful upgrade if you have the 35L already which in itself is a great lens.
I am currently still using the original 35L with my 16-35L f/4.
For the price difference its also worth noting that you get a new lens, a guarantee period and a better resale down the road. However, for now I'll probably wait until there's a price slide or another chance of shaving something off the price for the 35L II.
 maiaibing's gear list:maiaibing's gear list
Canon EOS 5DS R Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM Canon Extender EF 1.4x III Canon Extender EF 2x III +5 more
Ryanide
Ryanide Contributing Member • Posts: 854
I can see the difference in the contrast and sharpness in the version II photos, but also you can see there is less barrel distortion on the lines of the room. Of course the CA is apparent in the version I, and even though it can be corrected in LR, it is much nicer to not have that issue in every photo.
If you were going to shoot 35mm at F5.6 or F8, then I'd just as well use the 24-70mm F2.8II which will easily match the quality. This lens, like the 24mm F1.4II, are both ideal for low light situations, so their performance at the open apertures is critical.
Thanks for the real world photos. I think an upgrade is worth it.
Would love to see more photos that you've taken with the 35II.
 Ryanide's gear list:Ryanide's gear list
Sony a7R IV Sony FE 135mm F1.8 GM Sony FE 35mm F1.4 GM Sony RX10 IV Sony a7C +7 more
J A C S
I will post more photos here, I did not abandon this thread. The weather here has been miserable lately, and it is really ugly outside this time of the year, so I will wait for better shooting opportunities.
BlueRay2 Forum Pro • Posts: 14,816
thanks for the comparison but i don't see a compelling reason to a abandoning my old 35 f1.4 for the new one differences are quite minute!
J A C S
Well, I had to have the new one but I have always said that the 35L was a great lens.
TyphoonTW
TyphoonTW Senior Member • Posts: 1,484
Contrast
I've never owned any of these 2 lenses so I can only use Flickr and these "vs." thread to compare the two, but to me it looks like contrast is a bit better on the older model. For sharpness and bokeh I'd pick the mkII for sure, but am I wrong thinking the mkI has slightly better contrast? I'm watching these images from my computer monitor that is supposed to be well calibrated, but you'll never know.
This is where I write stuff: http://randomibis.wordpress.com/
This is where I upload stuff: http://www.flickr.com/photos/107755637@N06/
Canon 6d + 50mm f1.8 STM + 85mm f1.8 + Samyang 14mm F2.8 + 10mm f2.8 Macro
Panasonic G3 + 12-32 + 35-100 + 14mm
 TyphoonTW's gear list:TyphoonTW's gear list
Canon EOS 6D Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +2 more
J A C S
Re: Contrast
I do not think so.
rtoml321 Regular Member • Posts: 393
Thank you for this comparison. I have been searching for 35L vs 35L II same scene comparison for a long time. If it is possible, I would like to see some skin tone rendition comparison between the old and new version.
 rtoml321's gear list:rtoml321's gear list
Canon EF 135mm F2L USM Sigma 35mm F1.4 DG HSM Art
J A C S
More 35LII vs. 35L samples
The weather is better here today, and I snapped a few more shots. Sorry, no skin tones. All shot in manual, same exposure and processing in LR, lens module off.
The first pair was compensated by -1 EV in LR. One may say that the sun has moved between the shots. There was a slight breeze. F/11.
more flare
F/1.4. Focused in LV but with a scene like this, I cannot guarantee exactly the same focus.
smoother bokeh in the lower right corner
Here, I had to do highlight compensation -82 which lower the contrast. The main subject is very bright with highlights that look blown before the compensation. The bokeh is better with the II.
Check out the lower left corner! Not that it matters.
The bokeh is harsher. Look at the power lines in the upper left corner or the branches in the upper right one.
Ryanide
Re: More 35LII vs. 35L samples
It is definitely noticeable in the power lines. The II looks a tad sharper and a little cleaner. What amazed me was the noticeable barrel correction in the version II from the first batch of samples. Seeing barrel distortion in wide angle lenses is a real pet peeve of mine... It drives me nuts.
If you take any more comparisons, can you photograph a building or room where we can see how the barrel distortion and lines compare?
Thanks. I appreciate you doing this as the jump from a version I to a version II is a big investment.
LaszloBencze
sure would be nice if you labeled each shot with the lens that took it.
J A C S
I expected to be in the EXIF. I usually link from flickr, and then you can see in in the EXIF but this time, I uploaded them to my gallery. Anyway, the slightly longer FL is the 35LII, the other is the 35L.
