Not for studio
Started Jan 27, 2016 | User reviews
aliba New Member • Posts: 5
Not for studio
At first I was very happy with my camera. After a bit of time I was looking for a new "challenge". Taking pictures in the studio and use a flash off-camera. That seems to be impossible. The camera doesn't reccognize there is something on the hotshoe. Contacted Samsung...not possible. The camera will only communicate with a samsung flash on the hotshoe and I don't want the flash on that place.
 aliba's gear list:aliba's gear list
Samsung NX20
Samsung NX20
20 megapixels • 3 screen • APS-C sensor
Announced: Apr 19, 2012
aliba's score
3.5
Average community score
3.7
bad for good for
Kids / pets
good
Action / sports
okay
Landscapes / scenery
great
Portraits
great
Low light (without flash)
good
Flash photography (social)
bad
Studio / still life
awful
= community average
SewSimple
SewSimple Regular Member • Posts: 112
Re: Not for studio
I had the NX20, and you can use a 3rd party off camera flash and trigger. See this post:
http://www.dpreview.com/forums/thread/3959529
 SewSimple's gear list:SewSimple's gear list
Sony a7 III Sony 50mm F2.8 Macro Sony E 35mm F1.8 OSS Sony FE 85mm F1.8 Sigma 100-400mm F5-6.3 DG DN OS +1 more
socal4142 Regular Member • Posts: 279
Re: Not for studio
Somehow I think you're confused. A simple trigger and manual flash setup, such as those from Yongnuo, will work just fine for off-camera flash.
Kaziklu Senior Member • Posts: 1,301
Re: Not for studio
6
This is categorically false. I have used the NX20 with studio like conditions regularly with off camera flash.
It works perfectly fine.
I have Use Yongnou, Cactus and Pocketwizard Triggers all without issue.
Here are two examples of the NX20 using flash off camera, links provide posts with accessible EXIF data
https://plus.google.com/u/0/+RobElliottca/posts/5NfWokxiWbq
https://plus.google.com/u/0/+RobElliottca/posts/3boRLhAHoV8
Just to add a third
https://plus.google.com/u/0/+RobElliottca/posts/UGQa2LBAJHt
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
OP aliba New Member • Posts: 5
Re: Not for studio
the link brings me to a text where the nx1 is mentioned. it works on the nx 300 to but until this moment there's no communication between several sets. I go and try the set you mentioned. Thanks for reacting.
Samsung NX20
ttbek Veteran Member • Posts: 4,869
Re: Not for studio
Realize that we are talking about fully manual flash here. If you already own a set of wireless flash triggers, then we should probably see what you're doing wrong with those rather than spending money on more of the same. Maybe you were trying to use to fast of a shutter speed? The NX cameras do not trigger the hotshoe if the shutter speed is set faster than the sync speed. Actually on older cameras this was annoying because the camera would only stop at 1/180 if a flash was detected, so for manual flash the fastest sync you could get was 1/160. The NX1 has a stop right at its 1/250 sync speed, which is nice.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Re: Not for studio
Thanks for your answer. I checked once again. The flash goes off when I use the test button but not on my camera. Tried several shutter speed options.
Samsung NX20
Re: Not for studio
Thanks for answering but I've checked again. But it only works when I use the test button but no communication when I'm using the camera.
An other problem occured. After using the test button when it was on the hotshoe my camera was not responding when I changed settings. I had to turn it off to reset.???
Samsung NX20
Re: Not for studio
That sounds like something with your set up. It isn't the camera, as I said all the images I posted were shot with the NX20 with Off Camera flash and wireless triggers (cactus V5 triggers and Yongnuo flashes I've also used studio strobes with Pocket Wizards, and Canon Flashes with Yongnuo triggers when out with some friends)
What are the camera settings? what equipment are you using? What are the flash settings?
PTurbo Forum Member • Posts: 87
Re: Not for studio
check you your shutter speed if you are in manual . if it is higher than 1/125 then it may not transmit. The triggers don't react. The camera is a great studio camera. I use the Youngo TX1 as the trigger. It is the best one to use with Samsung Cameras
 PTurbo's gear list:PTurbo's gear list
Fujifilm X10 Fujifilm X30 Canon EOS 5D Samsung GX-10 Samsung NX300 +11 more
Re: Not for studio
Thanks to the people who have shared their tips with me. Sorry it took some time to answer. At this moment there are some other issues that need attention.
Samsung NX20
