Just how good is the GX8 especially against the GX7 ?
Started Jan 27, 2016 | Discussions
Ger Horgan Regular Member • Posts: 260
Re: Just how good is the GX8 especially against the GX7 ?
cameron2 wrote:
I have both the GX7 and the GX8. If you know the GX7 well, and with some work, you can probably produce pictures with the GX7 that are just as good as the GX8 99% of the time.
The GX8 is vastly superior to the gx7 ... I could go on but ...:-)
 Ger Horgan's gear list:Ger Horgan's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8
cameron2 Veteran Member • Posts: 4,142
I agree that the GX8 is superior to the GX7, but what I'm trying to say is that for producing pictures, if you know the GX7 well and are willing to work a little harder, you can almost always capture a picture that is as good as you could with the GX8. At least for me, the GX8 workflow is simply better and smoother and easier to be more precise with. It would be difficult for me to judge the difference in IQ though at anything less than 100% or 200% magnification on a good monitor!
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
HGFGKM Regular Member • Posts: 248
I have been trying to find a small flash for GX8 and have not been able to. Following your message, I looked for Fl-2 or -3, and I cannot find them listed. Is this the exact brand name for it?
Thanks for any answer!
 HGFGKM's gear list:HGFGKM's gear list
Sony RX100 Canon G1 X III Nikon D750 Sony a7R II Panasonic Lumix DMC-GX8 +8 more
Big Ga Forum Pro • Posts: 18,627
Adrian Harris wrote:
The photos from the GX8 are much sharper with a serious amount of more detail ... when used with a pro lens. The colours and local contrast is also improved
Really? I'd have thought that side by side, one would find the images virtually indistinguishable.
Have you got any examples to show these improvements?
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
FL-LM3. See link below:
http://www.bhphotovideo.com/c/product/1118048-REG/olympus_v326150bw000_fl_lm3_flash.html
A reviewer on the site mentions that it is indeed totally compatible with the GX8.
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
brentbrent Veteran Member • Posts: 5,766
Another option you might consider: http://www.amazon.com/gp/product/B00UHJ2SUY?keywords=meike%20320%20panasonic&qid=1454193862&ref_=sr_1_1&sr=8-1
This one is powered by two AA batteries, instead of being powered by the camera's battery.  A bit bigger, but probably more capable, and not much more expensive than the Oly flash.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
RichardGSmith Regular Member • Posts: 320
Did you have any difficulty adjusting to the offset view finder?
Rich G Smith
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Re: Just when I thought the GAS had subsided...go for it Chazza!
Chas2 wrote:
...I have been very happy with the GX7, but the viewfinder can be too small in 4:3! Arggh
You really want that GX8. Go get it bro!
Yes, the EVF in the GX7 is just that bit too small. Sigh.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Alohaman Contributing Member • Posts: 576
I'll wait til the GX-10 to replace my GX-7 when the pop up flash returns. The GX-7's flash is really good for fill-in light. Panasonic shouldn't have removed it.
 Alohaman's gear list:Alohaman's gear list
Sony a7R II Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus M.Zuiko Digital 17mm F1.8 +1 more
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
I have found the viewfinder offset to be really good in use.
Adrian
http://www.majestyofsteam.com/
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
FrankS009
FrankS009 Veteran Member • Posts: 6,557
Never  noticed. With all you guys complaining, maybe I should be less satisfied.
F.
"We shoot the things that move us in ways that will move others." David duChemin
 FrankS009's gear list:FrankS009's gear list
Panasonic Lumix DMC-GF1
Adrian Harris
Yes I will get around to it shortly. Am currently very busy getting photos ready for my next exhibition in a few weeks.
Adrian
Looks like it would work after cutting off a couple of small plastic tabs.
Looks like t would work for GX8 after shaving off a couple of small plastic tags.
