35mm IS f2 Lens flare tips?
Started Jan 24, 2016 | Discussions
CosmicYo New Member • Posts: 5
I'm wondering if anyone has a solution to eliminating lens flare in photos like these.
Admittedly, if lens flare is going to happen, this is where. I'm shooting right into the sun so it's not a surprise, and in any other shooting situation I cant find a flare. Mostly I dont like the small white dagger on the bottom of the frame. Is this something a lens hood will take care of? I'm not using one. Or maybe I am just SOL and shouldnt shoot into the sun with this lens. Any tips or feeback welcome.
I'm using a 5DSR and a Canon 35mm IS USM F/2
bottom right center
bottom left. small blue orb at the top right that is less noticeable
Canon EF 35mm F2 IS USM Canon EOS 5DS R
jayboo Senior Member • Posts: 2,366
Re: 35mm IS f2 Lens flare tips?
bottom right center
The Hood is the solution, protection for your lens, and protection against flare for your images. For my 35 I purchased the Hoya 67mm Rubber lens hood, I find these useful for many of my lenses and preferable in some cases to the Canon offerings.  As others have said, shooting straight into the sun, hood won't help much though.
 jayboo's gear list:jayboo's gear list
Leica CL Canon EOS R6 Leica M10-R Canon EOS R7 Leica Elmar-M 24mm f/3.8 ASPH +11 more
brightcolours Forum Pro • Posts: 15,885
No
5
No, the flare is from the light source, and that is inside the image frame. So the hood won't fix that. The hood will give a bit more contrast when the light source is outside of the frame and actually kept from the front element by the hood, and the hood is good for protection (bump protection, shock absorb protection in a fall).
bottom right center
hotdog321
hotdog321 Forum Pro • Posts: 21,141
I always use a lens hood, but a lens hood will do nothing when you shoot directly into a light source. About the only things you can do are:
1. wait for better light
2. use something (like a tree) to block the sun
3. do NOT use a filter
4. make sure the front and rear lens elements are clean
5. sometimes you can rearrange the composition so the flare hot spot falls in the glare of the light source.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
J A C S
J A C S Forum Pro • Posts: 20,544
Remove it in LR or PS.
OP CosmicYo New Member • Posts: 5
That seems to be the option. I've already been cropping it out but i could remove it. I try to stay from editing so if rather it just not be there but oh well.
Suave Senior Member • Posts: 2,289
Looks like a prime candidate for HDR to me.
Where's my new 50, Canon?
 Suave's gear list:Suave's gear list
Nikon D7000 Canon EOS 5D Mark III Canon EOS RP Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM +7 more
J A C S
HDR would make it look worse.
Well, I am not suggesting combing complete layers and shooting without light modifiers.
J A C S
A filter or just covering the upper half with a hand  in the most exposed shot would help. On the other hand, a few seconds in LR can achieve the same effect.
The flare is not so bad here because it is well confined to one bright spot.
Frankly, I think flare is not an issue here at all, it's poor contrast and general washed out quality of the image.
I would not know about LR - I could never get that thing going.
arty H Senior Member • Posts: 1,546
I am more concerned about my vision than flare. I avoid shooting directly into the sun, since I value my decrepit retina.
Incidentally, I always have the hood on my 35F2 IS. It is the normal position, even in storage. It will help to protect the lens and reduce flare when the light source is not in the frame. I find the 35F2 IS has good flare resistance. You should see the flare you can get from the earlier 35F2 without a hood. It was a purple monster flare machine. Keeping the hood on that lens, even in storage, is an excellent idea. The hood made the old 35F2 useful.
Tazz93
Tazz93 Veteran Member • Posts: 3,484
Exactly
No lens hood is going to stop that flare. But honestly, those two flares are not very hard at all the remove with PS.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
I wanted to bracket but i only had a monopod and my friend was already growing impatient, as you can see if you look closely because hes almost walked out of frame.
It is washed out. This is a little closer to what I was seeing after a little PS.
riderfanreturns Contributing Member • Posts: 964
Nice improvement!  I still find the white blob in the sky a bit distracting but the photo is now worth keeping.
I'm still new to using the 35 f2is but have read it is a bit prone to flare when shooting directly into the sun (as most lens are to at least some degree).   Some people even want the flare if shooting portrait shots into the light (I'm not sure where I stand on this style yet).
 riderfanreturns's gear list:riderfanreturns's gear list
Sony RX100 III Olympus Tough TG-4 Olympus OM-D E-M5 Canon EOS 5D Mark III Olympus E-M1 +20 more
bigfatron Contributing Member • Posts: 777
Most HDR software will account for small shifts during bursts for handheld bracketed sequences.
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Canon Extender EF 1.4x III Canon EF 35mm F2 IS USM +3 more
