Canon G9x- nice images, BUT...
Started Jan 24, 2016 | User reviews
OP 9and3quarters New Member • Posts: 12
Re: Canon G9x- nice images, BUT...
UPDATE-- after 300+ images, 2 months of casual use--
I didn't return it, obviously. I still like the images it makes. I can do most of what I can do with my DSLR with this.
On paper I wasn't crazy about the battery life, but realized that the way I use THIS camera, 270 shots is fine. I didn't have to swap it out until after 6 or 7 weeks of use.
Auto-focus is fast and accurate, even in low light. I still LOVE the touch to focus/shoot function.
Even after consulting with Canon tech over the phone, the Wifi doesn't work with Marshmallow on my Nexus 6p, which is my chief complaint. I'll probably pair it with my old phone and keep that around as an interim measure until Canon & Huawei magically start to get along.
 9and3quarters's gear list:9and3quarters's gear list
Canon G9 X Nikon D5500 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Sigma 18-250mm F3.5-6.3 DC Macro OS HSM Rokinon 16mm F2.0 ED AS UMC CS +1 more
Dan Hudson
Dan Hudson Senior Member • Posts: 1,383
My suggestion would be a Canon G5 X. It has a 100% view EVF. I have this and it does a great job. It is not my only camera, but it is my favorite. Purse size with a fully articulated LCD and EVF. I don't plan to buy any more cameras without an electronic view finder or one like my Pentax DSLR. Also no more of those like on other Canon G series cameras (optical view finders) that have parallax problems. If you like to compose in the camera, then in bright sun where most pictures are made, an EVF is just about indespensible. New price on Amazon & Adorama is $749. I bought a used one on Amazon that is perfect for about $100 less. I don't work for Amazon, but I nearly own it from making so many purchases over the years.....Dan
Christian Amateur Photographer
Choose life's involvements carefully with an eye toward eternity.
 Dan Hudson's gear list:Dan Hudson's gear list
Canon PowerShot SX120 IS Canon EOS M50 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM
Smaug01
Smaug01 Veteran Member • Posts: 6,966
Glad to read that you kept it
I think it's the best pocket camera yet made.
I was worried about the wimpy battery too, but I found that it is quite adequate. I bought a back-up (OEM) just in case, but it will be largely unnecessary.
The image quality still blows me away.
I think you can shoot raw in semi-auto modes, and considering how little changing the aperture does to limit DoF on this sensor size, that's good enough for me.
-Jeremy
 Smaug01's gear list:Smaug01's gear list
Panasonic Lumix DMC-TS30 Ricoh GR III Olympus OM-D E-M10 III Nikon Z5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +25 more
david kohn Contributing Member • Posts: 714
Lady, I don't know any camera that saves RAW in auto mode. You have to put them in P (program) mode for RAW capture.  You should know this already.
 david kohn's gear list:david kohn's gear list
Fujifilm X100T Panasonic ZS100 Olympus OM-D E-M10 IV Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +7 more
Smaug01
9and3quarters wrote:
Potential Deal Breakers:
LIMITED RAW FUNCTIONALITY: I can't shoot RAW in Auto modes???? Seriously, Canon? Why the hell not? Granted, I shoot manual about three-quarters of the time, but this is a P&S camera! Ease, convenience, speed! There's ZERO reason to block RAW capture in Auto modes. I'm pinning my hopes on someone at Canon coming to their senses and shooting out a firmware update before I'm forced to hack it myself.
WIFI: Canon Connect won't work with Lollipop 5, and apparently I'm not alone in this. I have a Nexus 6p, but I gather it's not limited to my phone. Read online reviews first to see if this will be an issue for you, too. If I can't get the camera to cooperate with the Nexus, my old HTC, or the Surface Pro 4, this will probably be what pushes me into a return, and returns me to my quest for the perfect purse-cam.
Incidentally, I'm seriously intrigued by the Lumix DMC-ZS100 coming out in March... if I return the G9X, I'll be ordering that.
Just to clarify a bit on the somewhat rude response by David Kohn:
Some of the Auto modes involve biasing the image processing engine in some what or other. Colors, exposure, etc. If you shot raw in those modes, the raw image would just throw out all those biases and the resulting file would be identical to the one from 'P' anyway.
The 'P' Program mode sets your exposure and takes into account exposure compensation, but doesn't bias the raw image in any other way.
So don't let that be a deal-breaker for you, or even a minor Con. Just shoot in 'P' if you want (and have time) for raw capture.
Are you still happy with your G9X? I am. Any reasonable amount of cropping and viewing size doesn't show any real flaws.
-Jeremy
rinser Forum Member • Posts: 68
I know this was a while ago, but I couldnt see any mention in this thread (regarding deleting of images) of using the menu button. While reviewing my snaps, I push Menu, then on Screen 1 I see Erase. When that is selected you can select a range of pics to remove.
I know its not the same as the reverse L maneuver, but needs to be mentioned!
NS Murali New Member • Posts: 5
I really like the dynamic range of Canon G9X ( certainly enhanced by the BSI chip) . This comes to the fore when you shoot a tree against bright moon in the sky and also want to see the intricate details of every twig on the tree and capture the moon's reflection in the water. I did this a few days ago. To compare performance when the dynamic range of a scene is so high, I also pulled out my Iphone6 and tried to get the same image. The result was a white haze on black background
For such a compact camera, the performance of G9X  is really terrific. My other favorite small camera is my older RX100 MKII. This too performs so well in the auto setting. However, I cannot carry the RX100 in my pocket. or jacket.
Jayzh New Member • Posts: 10
Re: Glad to read that you kept it
Hi, Jeremy,
I like your comment because it took the size of sensor into account. As a newbie, I have the tendency to think about specs/numbers in isolation. Do you think a mint G9X is still a good choice for about $200 CAD (=$130USD)? Does the newer processor of G9X Mark II make a noticable/meaningful improvement in speed in the field? The Mark II was once sold for $340 CAD (after tax) on Costco.ca last October but that was the last stock. I am debating if the newer processor is worth waiting for a used Mark II or I should grab the original version for $200 CAD available now.
Thanks.
J.
Anders_K Contributing Member • Posts: 896
Jayzh wrote:
Hi, Jeremy,
Thanks.
J.
I had the M1 and own the M2. I found the M1 pictures slightly better than the newer M2's, but that's maybe due to product variation.
The M2 is a bit faster and offers Bluetooth. You decide whether that is worth the price difference. Both are nice pocketable cameras and a joy to use.
A modern smartphone camera would be the other alternative. If you already shoot with a smartphone, a camera with longer optical zoom reach than the G9X might be another interesting option.
Smaug01
Jayzh wrote:
Hi, Jeremy,
Thanks.
J.
I wouldn't buy another Canon G series camera until I read that their lenses are notably improved. When they went to a 1" sensor at the expense of optical quality, it was a bad call.
I wound up keeping my older Pentax MX-1. Although its sensor is smaller, it's lens is MUCH better, so the images are, too. I also had an Olympus XZ-1, which had the same lens and sensor and was more compact but not as pretty. It's about comparable to a G7X, size-wise.
Prior to getting into Canon G series', I had a Canon S90 as my pocket camera, and I would rather have that. Small sensor, but good lens. Just accept that to shoot good low light photos, you need a tripod and to set the sensitivity lower.
-Jeremy
"Rudeness is the weak man's imitation of strength."
-Eric Hoffer
  1. Thanks. Anders
Thanks, Jeremy.
