Best settings to capture "snow in flight" during Blizzard?
Started Jan 21, 2016 | Discussions
alexisgreat Veteran Member • Posts: 6,459
So we have a Blizzard Watch up in Long Island for Saturday for up to 2 feet of snow and I was wondering what's the best way to capture snowflakes in flight when snow is falling at a very fast rate?  We could have up to 4 inches per hour!  In the past when I tried this, I would get disappointed and only see all the flakes blend into a white blur.  I want to have a fast enough shutter speed to capture individual flakes as they fall and yet have the whole scene bright enough to see the background too.  The good thing is the heaviest snow will be falling in the afternoon which is pretty rare- most of our snowstorms have the heaviest snow at night, so this will be during the brightest part of the day, great for photography!
I'm going to use spot metering, but am wondering how much exposure compensation I should use as well as the shutter speed and ISO.  I am going to use shutter priority mode and the aperture will be at the maximum.
Might end up doing a timelapse with the E-PL6 too.
 alexisgreat's gear list:alexisgreat's gear list
Olympus C-7070 Wide Zoom Fujifilm FinePix HS20 EXR Fujifilm FinePix HS50 EXR Olympus E-520 Olympus PEN E-PL6 +3 more
Olympus PEN E-PL6
Fri13 Veteran Member • Posts: 3,116
Re: Best settings to capture "snow in flight" during Blizzard?
Forget the automatic exposures. Use M mode and you see what you get.
Use a external flash to freeze snowflakes but problem is to get it far enough from snow and camera not to overexpose the close flakes.
Jonathan Gladstone Regular Member • Posts: 448
what about setting his on-camera flash to lowest power to activate the slave to take the shot?
 Jonathan Gladstone's gear list:Jonathan Gladstone's gear list
Canon PowerShot A520 Panasonic Lumix DMC-G3 Panasonic G85 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +3 more
It can work but it can be difficult to get the external flash to illuminate flakes in nice way.
Mark Thornton Veteran Member • Posts: 4,570
Some sort of shelter to eliminate the really close flakes.
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
Yes, or simply just keep the flash further behind/side you so the inverse square law allows to illuminate flakes evenly from further distance.
P Langham Regular Member • Posts: 157
Here is how to take snow photos. They are easily the best I have ever seen.
http://www.exposureguide.com/culture/chicago-in-flash-street-photography/
"It's" is the contraction of "it is".
"Its" is the possessive pronoun.
Example:
The camera and its viewfinder. Correct!
Michael J Davis
Michael J Davis Veteran Member • Posts: 3,755
We - in the UK - don't often have the really heavy stuff that you get, and I would advise against using flash on camera - back lighting is always best for snow. At night the street lights can help.
Choose shutter speed to get slight motion - otherwise it all blurs together, and with the right (back-) lighting choose a focus point that gets some of the nearer stuff in focus. A couple of night shots to illustrate:-
https://www.flickr.com/photos/watchman/8420044289/
https://www.flickr.com/photos/watchman/8418318424/
Best of luck! (And remember don't take a cold camera back indoors without a protective bag round it, so you don't get condensation inside the gear.)
Mike
Mike Davis
Photographing the public for over 50 years
 Michael J Davis's gear list:Michael J Davis's gear list
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +6 more
K25 Regular Member • Posts: 296
This is the snow photo I took yesterday while arriving home after vacations: 1/30", but snow was falling slowly
... and just for information: a few hours earlier at Medano (Tenerife). Sigh...
drj3 Forum Pro • Posts: 12,634
You do not indicate exactly what you want to capture.  If it is a blizzard, snow will be failing at a very high rate, there will not be a lot of light, and backgrounds will quickly become covered with snow, so you do not see the snow flakes.  You probably want to pick some location with a darker background ( like an evergreen tree).  If you include a lot of distance, then it will become a white spotted image with a relatively fast shutter speed.  See the attached taken at the beginning of the last "blizzard" in northern NJ.  However, I was simply trying to see how many cardinals I could include in the image.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Michael L NYC 99
Michael L NYC 99 Veteran Member • Posts: 5,239
Besides the E-PL6 for time lapse, you don't mention what body and lens you plan to use.  I assume you have weather sealed gear for this purpose.
As others have mentioned, a flash is needed to freeze and see the individual snow flakes.
Daytime is not a problem for flash sync speeds as it will undoubtedly be overcast when snowing.
I used the E-M5m2 with Panasonic 12-35 last year along with both the small accessory flash that came with the camera and the FL-600R.
My recollection is that I had to dial down the flash intensity on most occasions as it was too bright otherwise. Pointing the flash up a bit reduced the intensity in a nice way but leaves the bottom part of the image (if shooting in landscape orientation) without flash. This can still look good.
Here's a shot from Sunday when we had a light dusting of snow in New York.
https://www.flickr.com/photos/52836039@N02/24389508141/in/dateposted/
I used the small accessory flash and pointed the flash up about 45 degrees. Much of the bottom of the image has been cropped out, but I like that the ground isn't filled with snow flakes.
I tried wireless off camera flash last year with the FL-600R, but it was difficult because it is triggered by line of sight. It was hard to hold the camera in one hand and the flash in the other hand in a position that's in the line of sight of the on camera flash.
Michael
See my website here MichaelLeePicsNYC
See my Flickr photostream here Michael.Lee.Pics.NYC
See my gallery on Getty Images here
 Michael L NYC 99's gear list:Michael L NYC 99's gear list
Olympus E-M5 II Sony a7R II Nikon AF Nikkor 85mm f/1.8D Panasonic Leica D Summilux Asph 25mm F1.4 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +15 more
n3eg
n3eg Veteran Member • Posts: 3,316
This is where I usually push the red dot button and stop down.  Yes, I'm a vidiot.
It ain't easy being me, but someone's gotta do it.
 n3eg's gear list:n3eg's gear list
Kodak DCS Pro 14n Olympus PEN E-PL5 Panasonic Lumix DMC-GM1 Kodak Pixpro S-1 OM System OM-5 +73 more
TomFid Veteran Member • Posts: 3,999
Yes - a little distance is key, not just for even flash illumination, but also to avoid having a strange mix of flake sizes, with a few giant blobs from out of focus flakes close to the lens.
Paulmorgan Veteran Member • Posts: 9,499
Your not going to need anything particularly flashy, I went out and shot in a snow blizzard one night with nothing more than an Olympus trip and 400 iso film, the shutter speed most of been something like 1/40s.
Skeeterbytes Forum Pro • Posts: 23,184
Confess I laughed. What a juxtaposition!
Welcome home?
Rick
Welcome home?
There are 10 hours difference between the photos. A temperature shock: enough for changing an iron man to a steel one (what a shame I am not of the iron kind so had no benefit).
For remaining in the thread: at the doorsteps I took another shot using 1/20" and was too slow: the snowfall looks more like a white rain. So I guess 1/50" would produce the best effect. A blizzard of course is a different tale.
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
I'm going to suggest an off-camera hot shoe flash extension cord instead of doing the wireless slave, as an option.  Might be easier than trying to position multiple flashes.
I'd wrap some plastic over everything before going out into the blizzard with non-weather-sealed gear and then blot everything really well with paper towels after coming back inside, and wait to turn on and use until everything is well dry and room temperature.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
OP alexisgreat Veteran Member • Posts: 6,459
Re: Talk about dynamic range!
Talk about a high dynamic range  I wonder what you would get if you combined the two photos (in a creative way so you could see details of both.)
Thanks I love this shot!  I want to capture individual snowflakes against a background of evergreen trees, which gives the image the nice contrast it needs.  But the snow is falling at 3 inches per hour (it's actually happening right now.)  16 inches down, maybe another foot plus to go!
Thanks I'm using the E-PL6 and an E-M5 (original version) I just procured.
