Filter system needed for 17mm TS-E tilt shift - help/advice sorely needed!
Started Jan 21, 2016 | Discussions
Peter too Contributing Member • Posts: 909
Re: Filter system needed for 17mm TS-E tilt shift - help/advice sorely needed!
With two 100mm filters you will get about 3mm shift up or down before vignetting starts.
OP Jayaus New Member • Posts: 19
Yeah, thats why I figure a 150mm system will be needed if I want to make full use of shift.
 Jayaus's gear list:Jayaus's gear list
Canon EOS 6D Canon TS-E 17mm f/4L Canon EF 70-300mm f/4-5.6L IS USM Canon TS-E 24mm f/3.5L II Canon EF 24-105mm f/4L IS USM +4 more
neoroblitz wrote:
Aside from thicknesses, is it safe to assume 150x150 filters will work in any of the 150mm holders then?
Pretty much so!
one note, I used to try Firecrest on the 100x100 filters but experienced horrible image degradation from it - Maybe you shd check around in Amazon for a bigger pool of users if they had solved this issue.
Really?
Interesting. I thought I'd read some good reviews (specifically about how the Firecrest were the premium range of Formatt-Hitech) regarding colour cast, especially as Lee seems to have a noted cool cast to their ND filters.
Must admit, I havent thought of using Amazon much as a resource simply as in Australia, there are many sellers who dont ship here at all. Will suss out reviews.
neoroblitz Forum Member • Posts: 59
Jayaus wrote:
Pretty much so!
Really?
Here you go
http://www.amazon.com/Formatt-Hitech-Firecrest-Neutral-Density-stops/dp/B00LP3EOWQ
