Panasonic Lumix 12-32/3.5-5.6 vs Olympus 14-42/3.5-5.6 II R MSC
Started Jan 20, 2016 | Questions
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
Shutter shock is not a mFT problem.
Oleksak wrote:
photofan1986 wrote:
I sure would. But be aware that there might be shutter shock problems with this lens on the Epl5. I know there were on the Epm2.
Frankly speaking I had never seen shutter shock problems on my images with E-PL5 before I saw Your post. May be I was not careful enough. But when I looked through a number of posts about the problem in MFT forums I was shocked that it is considered as a so big problem of MFT, that can destroy all the advantages of any high-quality optics. Is it worth to invest in MFT then?
Shutter shock is a universal problem, and is not new, not even new to digital. This is why we had mirror lockup on SLRs 40+ years ago. Higher resolution sensors are just making it more noticeable. But it is not universal in mFT or any other system either. As in other systems, certain mFT lens/body combinations are more prone to SS than others.
Here are just the first examples found on the topic in other systems:
http://www.dpreview.com/forums/thread/3836204
http://www.dpreview.com/forums/post/55591675
http://blog.kasson.com/?p=4674
Personally, I have seen examples of SS with the 40-150R lens on my E-M5. Once I confirmed this, and did some reading on it, I set 1/8s anti-shock on both my E-PM2 and E-M5 and don't worry about it anymore. I will turn off the 1/8s AS if I know that I need instant shutter response or that SS will be above 1/250s consistently, or if I want to be quieter, since the 1/8s results in a noisier shutter sound. But it doesn't affect my IQ or shooting otherwise.
I have never seen evidence of SS on my 12-40, which is now used for 90% of my work.
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
Hitherto Contributing Member • Posts: 812
Re: Panasonic Lumix 12-32/3.5-5.6 vs Olympus 14-42/3.5-5.6 II R MSC
Allan Brown wrote:
Hitherto wrote:
e_kjellgren wrote:
Cyberphoto gives the edge to either the Panasonic G X Vario PZ 14-42/3,5-5,6 or the Olympus M.Zuiko Digital 14-42/3,5-5,6 II R.
http://www.cyberphoto.se/info.php?article=pana1232silverbulk
/Evert
This is pretty good for a kit lens
http://www.imaging-resource.com/lenses/olympus/14-42mm-f3.5-5.6-ii-m.zuiko-digital/review/
The 12-32 is slightly off it in the centre according to SLR Gear but its not bad either. You can't go wrong unless you go for the 14-42 EZ pancake lens from Olympus.
http://www.imaging-resource.com/lenses/panasonic/12-32mm-f3.5-5.6-asph-mega-ois-lumix-g-vario/review/
What do you mean by that? All the reviews and my experience shows that the lens is very sharp in the centre.
Allan
I don't mean anything by it, just look at the sharpness test above. Both lenses are sharp but the 14-42 would appear to have 1 less blur unit in the centre. The 12-32 suffers some barrel distortion at 12 also, but aside from the 12-50 its the only lens that goes to 12 and it's sharper than the 12-50. If you don't need weather sealing and you want 12mm on the short end its a good lens.
 Hitherto's gear list:Hitherto's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +2 more
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
zuikowesty wrote:
Allan Brown wrote:
/Evert
Allan
Note that the 14-42 review above is for the II version, not the IIR. I believe the IIR might be a bit softer.
My understanding is that the only difference was cosmetic with a minor change to the focus motor. Both lenses have the same glass and coatings.
I didn't use my 14-42IIR much, since I had the 12-50 on my E-M5 at the time, and I shoot at 12mm a lot. But I used the FT 14-42 for four years on my E-410, and it seemed to perform better than the MZ 14-42. Since I wanted the 12mm, the 12-32 was the answer, although at almost as much as I paid for the E-PM 2 lens kit, it was more than I wanted to pay. But the lens is very small, well built, and performs well across the frame. I have not done any testing, but the corner softness I often saw on the 14-42 is gone on the 12-32.
The only things I don't like:
- CA can be an issue on Oly bodies (E-M5 and E-PM2 in my case)
I use mine on my EPL5.
- will miss focus occasionally even though focus confirm light is on, often with close subjects. I have to watch for this, as I have ruined some shots due to this. Close focus also not quite as good as 14-42.
I find this to be an Oly body problem, not a lens problem. I can easily get all my Oly bodies to misfocus with non-Oly lenses (Panasonic and Sigma) whereas, my Panny G5 does not care what lens is on as it will focus properly every time.
Even when set not to take a photo until it is in focus, the Oly bodies will. Panny bodies will not.
- zoom ring turns the wrong way!
- no manual focus ring
Not even close to being an issue for me.
Allan
Allan Brown
Hitherto wrote:
Allan Brown wrote:
/Evert
Allan
I had the Oly 14-42 IIr and I can see that the 12-32 is the better lens. Yes, the Oly is good at 14mm but that is it.
Allan
SpinOne Veteran Member • Posts: 4,059
Oleksak wrote:
Would You exchange Olympus 14-42/3.5-5.6 II R MSC with Panasonic Lumix 12-32/3.5-5.6 for IQ reasons and not taking focal range into account? Body - Oly E-PL5
I wouldn't.
IMO the 14-42 has a nicer look, renders better, and has a manual focus ring. The 12-32 tests well (*yawn*) but doesn't make substantially better images.
I'd rather save up my dinero for a nice fast prime, rather than spend money on another kit lens.
zuikowesty
Yes, this may be true, I just noticed it was and older review.
Yes, it may be so; I've never used a Pany body. But I've also never experienced this with Oly lenses. Perhaps this will be addressed in newer bodies, or already has been. It's not a big deal now that I am aware of it.
Nor for me really. I just like to be thorough. The zoom ring takes seconds to get used to, and AF lock on a subject then re-compose solves the lack of MF problem. It's not like the DOF is razor thin...
dylanear Veteran Member • Posts: 3,441
Anyone using the 12-32mm on an E-P5? I just got a 12-32mm with a GM1 used. Works perfectly on the GM1 and my E-M1, but on my E-P5 it gives a dark image in live view, roughly a stop dark, then if I take an image it looks about a stop too bright? Everything has the latest firmware.
Not a huge problem as I'll mostly use that lens on the GM1 it came with, but it would be nice to use it on the E-P5 without having to put up with the inaccurate LV and exposure.
 dylanear's gear list:dylanear's gear list
Nikon D300 Nikon D700 Olympus OM-D E-M5 Nikon D800E Olympus PEN E-P5 +7 more
