Lense Panasonic G MACRO 30mm f/2.8 Question
Started Jan 19, 2016 | Discussions
Fulcanelli
Fulcanelli Contributing Member • Posts: 566
I have the Olympus 60mm macro lens and when it finally focuses, does a great job.  However, it has a difficult time focusing.  Is this characteristic of this lens?
I am thinking of acquiring the Lumix 30mm macro and need to know if it focuses rapidly?  Does it have a dial on the side to select a focus range like the Olympus?
Thanks.
Panasonic Lumix G Macro 30mm F2.8
Helen
Helen Veteran Member • Posts: 7,606
Re: Lense Panasonic G MACRO 30mm f/2.8 Question
Well, I find it's quite reasonable when you take into account the very narrow depth of field on closeups and the long focusing travel it has (when operating unrestricted by the switch). Obviously limiting it with the switch speeds things up, but I assume that you're still not satisfied.
Thanks.
I don't have that lens myself (though I've considered it, but haven't handled it). I would imagine, being a Panasonic, that it will focus quickly (but as I said, so does the Olympus in my opinion, given the spec). Being a 30mm, the Panasonic will have slightly more depth of field at a given distance and aperture; it has to go physically closer to achieve 1:1 though (10.5 cm vs 19 cm) so that equalizes things again. It doesn't have a focusing range switch, but does have OIS - relevant if you have a Panasonic body that isn't a GX7 or GX8.
Fulcanelli
OP Fulcanelli Contributing Member • Posts: 566
Thanks for the reply.
I'm wondering if the lens might be defective. I have had it for a while now (less than a year) but I have nothing to gauge it against. Sometimes (when I'm in the right focus zone) it can take 3-4 seconds to finally focus.
The close proximity won't be a problem as I don't photograph birds, bugs, drones, etc.
I was doing some photos last night in a quiet environment and I could hear the focus mechanism very distinctly. Is that normal? It's a great lens and I've gotten some great shots with it, but with the noise and focus issues, I wonder if the lens is defective. It has worked like this since I purchased it last spring.
I just watched this video review of the lens: https://www.youtube.com/watch?v=K90uhkJMt0Y
At about 3:54 the reviewer demonstrates how fast it focuses. Mine is NOTHING like this. Sometimes it will search in and out, like waves, for a few seconds. I have found that by touching the screen to force focus that it works a little faster, but that does not seem necessary based on what I saw in this video.
I really don't want to buy a second macro lens if not necessary.  I have 25mm and 40mm Olympus lenses already.
tkbslc Forum Pro • Posts: 17,527
60mm focuses very fast
The 60mm macro is an extremely fast focusing lens for a macro.  You will not improve AF speed by moving to another lens.
C Sean Veteran Member • Posts: 3,423
Thanks.
I own the 45mm Panasonic Lieca 2.8 lens and it too is a macro lens. This may come as a surprise but far as I'm aware all macro lenses has auto focusing problems when it comes to macro photography.
Your best bet is learn how to use manual focus and more importantly activate focus peaking if your camera/s has this feature. Focus peaking highlight on the screen which part of the subject is in focus and for macro photography this is very important especially if you're shooting insects. It allow you to choose what you want in focus and not the camera. By using manual focusing aided by focus peaking your keeper rate will be higher and you mastered the 'basics' in macro photography.
Thanks.
I've owned 60mm and 45mm macro.  The 60mm is noticeably faster and more "sure".  But I like the 45mm better for portraits, so that's what I ended up with.
I think that is good advice when getting in near 1:1.   For 1:3-1:2 range, I like AF if it works.
One of the main reasons it has problems is that the DOF is so narrow in the macro ranges that sometimes only a portion of the AF box is in focus.  It makes it challenging for the sensor to know what it is focusing on.   I find using single point AF and making your AF target box smaller can help.
JeanPierre Martel Veteran Member • Posts: 3,304
The M.Zuiko 60mm focuses very quickly if you set the right distance range. Never set it to "0.19 - infinity").
No the Lumix 30mm don't have any button and is very easy to use. However, you must know that for real macro, you have to use the 30mm so close to the subject that the lens will probably make shadows on it. So a LED ring flash is almost unavoidable with the Lumix 30mm for real macro.
However, for close-up photography, the Lumix 30mm is easy to use and is very sharp:
https://jpmartel.wordpress.com/?s=30mm (click on a photo to zoom)
When I want to take shots at objects to be sold on eBay, I'd rather use the Lumix 30mm because I can have the object in one hand while the other hand is holding the camera. With the M.Zuiko 60mm, the distance between them can be such that the subject has to stay flat on a surface.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
Fulcanelli
After seeing a review of the lens on YouTube, I think my lens is defective.  I am having these issues shooting it as a regular 60mm lens, not as a macro.  It happens in bright light.  As I already stated, this searching can go on for up to 3-4 seconds.  That does not sound like fast focus.  I am going to check to see if it is in warranty as I think, from what I've read here, that I would rather stay with a 60mm and skip the 30mm macro.
jeffharris
jeffharris Forum Pro • Posts: 11,409
A lot of people who do macro shooting prefer to use manual lenses because of the level of focus control you gain. You're relying on your eye + magnified view to select exactly the point you want in focus and nail it.
You'll find that you can buy and adapt a very good manual macro lens for a fraction of the cost of an electronic macro lens. Besides, manual focusing macro shooting is lots of fun!
I've adapted 3 Nikon macro lenses. 60mm f2.8D, 105mm f2.8 AI-S and a 200mm f4 IF (internal focus). They're all excellent! I tend to use a tripod and wired shutter release. That way I can take my time to compose and focus.
If you're interested, take a look at a Nikon 55mm f2.8 or f3.5 AI-S lens. You can get an inexpensive Nikon to M4/3 lens adaptor from Rainbow Imaging or Fotodiox. The whole thing should cost around $125 ±.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
