DA 16-45 review
Started Jan 18, 2016 | User reviews
Yoda boy
Yoda boy New Member • Posts: 12
DA 16-45 review
I purchased this new a few years ago and have never had any issues whatsoever.  This is a great all round lens.  Only wished it was AW/WR.
To upgrade, went with DA* 16-50 which is weather sealed and has f 2.8 vs. f 4.  Colour of DA* was great but sometimes WB is really off, something I never experienced with the 16-45.  In truth, had I known how little the difference ( with the 16-45 often being superior ) I would never have spent the extra money on the DA*.  I highly recommend this lens if you can find one.
They are now discontinued but there should be some lurking around somewhere, either new or used.  Have used this on both K 5 and K 3.
 Yoda boy's gear list:Yoda boy's gear list
Pentax K-3 II Pentax K-1 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 60-250mm F4.0 ED (IF) SDM +5 more
Pentax smc DA 16-45mm F4 ED AL
Zoom lens • Pentax KAF • 21507
Announced: Dec 9, 2003
Yoda boy's score
4.5
Average community score
4.2
Joseph Tainter Forum Pro • Posts: 11,494
Re: DA 16-45 review
Yes, it's an excellent lens. I stopped using mine in favor of the DA 16-85, but only because the latter has WR. I also have the DA* 16-50, but have had SDM fail on my so I don't take this lens when I travel.
Joe
flektogon
flektogon Veteran Member • Posts: 6,226
Re: DA 16-45 review
Can I ask you for a favour? My DA 16-45 mounted on the K-x exhibits certain AF problems. For example, if a subject is let's say 2m away, my lens when set to 45mm after focusing shows exact focus distance (i.e. 2m). Now, when I change the setting to 16mm and refocus, the distance scale changes, it shows around 4m (generally twice more). I am sure that this is a camera body problem, as in LV mode the focus distance is always correct and same at any focal length setting. I am just curious whether other Pentax bodies exhibit similar problems.
Peter
klimbkat
klimbkat Senior Member • Posts: 2,659
Re: DA 16-45 review
Peter
I tried my 16-45's focus on a K5IIs.  Generally the distance (and by this, I assume you mean the distance scale on the lens itself which, in turn, indicates the actual focus point) does not change much when refocusing after changing from wide to tele or back.  At closer and farther distances there is some movement, though nothing as large as you describe.  Interestingly, at 2M there is essentially no change at all.  When your lens changes (refocuses) at 2M are both shots in focus?
Re: DA 16-45 review
Hmmm. I've never trusted the distance scales on zoom lenses.
Joe
flektogon
Re: DA 16-45 review
klimbkat wrote:
Peter
Thanks Dough. It has to be a K-x PDAF focusing problem. When the lens is set to wider angles, somehow PDAF unit gets confused, because in the LV mode the lens focuses perfectly at any zoom setting. So, for critically correct focusing I have to focus at the 45mm setting, press the shutter button half, quickly change the zoom setting and then to take exposure.
Peter
flektogon
Re: DA 16-45 review
Joe
The distance scale on the DA 16-45 is surprisingly very precise when I shoot in the LV mode. But in any case it shouldn't change when the lens focuses at a stationary subject and you change the zoom (angle) setting. My lens (I would rather say my camera) changes it significantly when using PDAF. Now I checked it again, a subject distant 1m from the camera shows exactly 1m when zoom is set to 45mm and it changes (refocuses) to 2m when I change the zoom setting to 16mm. Crazy indeed.
Peter
kitsios_spyros
kitsios_spyros Senior Member • Posts: 2,847
Re: DA 16-45 review
Hi Peter,
I am afraid that if this is the case indeed, then your lens needs servicing. If it is a parfocal lens (more or less) as Dough suggests, then you need different AF-FA adjustment for 16mm vs 45mm. Zoom lens suffer from it all the time. Even if you buy it perfectly calibrated, this problem may develop with use.
If speed is not important, you can use it in live view. For PDAF shooting, calibrate focus for 45mm on your camera(s), focus at 45mm and then zoom-out and recompose while holding AF locked.
Kind Regards,
Spyros
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Pentax K-5 II Samsung NX300 Pentax K-3 Pentax KP +13 more
kh1234567890
kh1234567890 Contributing Member • Posts: 743
Re: DA 16-45 review
One of my favourite lenses. No AF problems on a K-5ii whatever. And as far as I can tell it is parfocal.
http://www.flickriver.com/photos/kh1234567890/tags/smcpda1645mmf40edal/
 kh1234567890's gear list:kh1234567890's gear list
Panasonic ZS100 Pentax K-7 Pentax K-5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 16-45mm F4 ED AL +15 more
Fibinaci
Fibinaci Regular Member • Posts: 127
My favorite lens for pentax
This was the lens that showed me the sort of resolution I saw on my Samsung. The one stop over the kit lens at the end, which is where I shoot half my shots was a win. Colors are nice and the AF when using the viewfinder is better than any of the Sammys or Sonys I've used.
Cropped, but I love all the definition on the sprinkles and her hair.
A cropped photo of my father using the 16-45
 Fibinaci's gear list:Fibinaci's gear list
Fujifilm X-T200 Fujifilm XF 18mm F2 R
M R Padmaraju Veteran Member • Posts: 6,658
Re: DA 16-45 review
` have a DAL 16-45 F.4.0 . Quite happy with it . As others have found the distance scale has some reliability issues . Couple of pics for you .  If you like it ..... .
Regards ,
mrp .
 M R Padmaraju's gear list:M R Padmaraju's gear list
Fujifilm FinePix F40fd Pentax K-x Pentax K-01 Pentax K-500 Pentax K-S1 +8 more
Re: DA 16-45 review
` have similar problem with that lens , on K-500 and K-S1 , behaves the same . ` am circumventing the problem by using the center spot focusing . All the same one has to be  aware of it .  Happy times .
Regards ,
mrp.
KL Matt Veteran Member • Posts: 5,999
Re: DA 16-45 review
I've had focussing issues with my copy before. Apparently some internal contacts had become loose/soiled/unreliable, and that was affecting infinity focus somehow. Took it in for servicing and that fixed the issue. Clean your external contacts and if that doesn't help it may need servicing. Was the issue always there, or did it develop over time?
Matt
... interested in .... photographs? Heh? Know what a mean? Photographs? (He asked him knowingly). Nudge nudge, snap snap, grin grin, wink wink, say no more, say no more, know what a' mean? Know what a' mean?
http://www.pentaxphotogallery.com/home#section=ARTIST&subSection=183820&subSubSection=0&language=EN
kitsios_spyros
Re: DA 16-45 review
As far as I have seen, it happens with all zoom lenses. I have seen it with Pentax, Tamron, Sigma, Canon L and low grade Nikon lenses.
With parfocal designs, especially if they have a distance scale on the lens barrel, it is just easier to notice the fl (rnage) that is accurate.
Kind Regards,
Spyros
asp1880 Regular Member • Posts: 355
Re: DA 16-45 review
Peter
My 16-50 does the same thing on my K-3! Except it front focuses at the wide end, not back focuses like yours.
So it's the opposite phenomenon with a different lens and a different camera. Same thing!
Seriously though, it annoys the hell out of me.
Anders.
Re: DA 16-45 review
Thank you , K_Spyros .
Regards ,
mrp .
flektogon
Re: DA 16-45 review
Matt
Well, if there were just such problems, the lens would not focus properly even in the LV mode. So, this is only and only the PDAF related issue. I have no experience with the back/front focus adjustment, actually the K-x doesn't even allow such adjustment. But you guys, who have such experience, can you explain how it works? Can you adjust back/front focusing independently for different focal lengths? It's possible that my K-x would back-focus with any other wide angle lens. Unfortunately I have no other such lens, so I can't verify this. Again, as this lens focuses perfectly in the LV mode, I am 100% convinced that the problem is in camera, i.e. in its PDAF unit.
Peter
flektogon
Re: DA 16-45 review
kitsios_spyros wrote:
Hi Peter,
Hi Spyros,
Is it possible that the lens would be faulty if it focuses properly in the LV mode? I doubt. I still think that this is a problem of the PDAF in my camera. I have no idea how the back/front focus adjustment works in the Pentax bodies. Is this somehow done by mechanical movement (re-positioning) of the PDAF "unit"? Is it possible to make such adjustments independently for different lens angles? And I doubt that the K-x allows such adjustments at all.
Peter
Re: DA 16-45 review
flektogon wrote:
Matt
Peter, you obviously know more about the functioning of the lens and camera than I (or the person who repaired my copy) does. Sorry I can only repeat to you what the technician who successfully fixed the problem told me. My lens would not focus properly at infinity.
Matt
Fibinaci
love the detail in the first image
such intricate carving, and the color in the second.
Thanks for sharing
