Which mFT cameras offer Auto-ISO in M mode?
Started Jan 16, 2016 | Questions
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
It appears that neither my E-M5 or E-PM2 offer auto ISO in M mode. I am curious which mFT bodies do offer this option - does anyone know of a list showing this? Or if there is a trick to enabling this on an E-M5 - I haven't found one.
I am fully aware that adding auto anything to M mode no longer makes it truly an M mode, but would rather avoid that topic here, there are other threads already for that.
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Yours do
They both have auto ISO in Manual mode.
It needs to be set up in the Custom menus, try Custom Menu E - ISO-Auto - set to All and it works.
Regards.... Guy
haslo
haslo Regular Member • Posts: 411
Re: Yours do
...but what you don't get is EV adjustments with auto ISO in M.
 haslo's gear list:haslo's gear list
Olympus E-M1 Olympus E-M5 II Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
zuikowesty
OP zuikowesty Veteran Member • Posts: 4,158
Thanks!
Regards.... Guy
Thanks, I really should have dove into the menu before posting, as I do recall seeing this now!
zuikowesty
Re: Yours do
Yes, good point. Using P mode is an option in some cases, assuming you want to control the aperture, exp. comp, and let the SS & ISO float. Not helpful if you want to go below the low SS threshold though. I haven't actually tried P mode myself. For me, it's usually A, then M when I want more control.
