Panasonic 100-400mm vs others
Started Jan 15, 2016 | Discussions
Martin.au
Martin.au Forum Pro • Posts: 14,339
11
I appreciate Panasonic's design choices. There's now two other 100-400 lenses, both f4-5.6 out now.
• Panasonic 100-400 f4-6.3 comes in at almost exactly the same size as the 40-150 f2.8 + TC.
83mm x 172mm & 985gm
• Fuji's 100-400 f4.5-5.6
95mm x 211mm & 1375gm
• Canon 100-400 f4-5.6
94mm x 193mm & 1550gm (1615gm with foot).
Given those weights and sizes, I'm quite glad Panasonic went with the smaller aperture. At that size, it's compatible with all my existing bags, and anything I've built to hold the 40-150+tc (eg: my kayak deck bag).
Hopefully that lens will perform, too.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Olympus 40-150mm F2.8 Pro Panasonic Leica 100-400mm F4.0-6.3 ASPH
3dwag
3dwag Veteran Member • Posts: 4,674
Re: Panasonic 100-400mm vs others
+1
And so, the saving and scheming begins! 🤑
-Dennis W.
Austin, Texas
http://www.pbase.com/3dwag/image/97156660.jpg
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
nzmacro Forum Pro • Posts: 18,756
Interesting
Its excellent choices m4/3 is getting and wonderful to see Martin. Makes me smile and looking forward to what a few in here will take with those lenses.
Just been looking at that Fuji, another stunning lens. A good review out and saw some snake shots taken with it, phew, it's another beauty. Mind you, they are taken by one heck of an expert at what hes doing !!. All those lenses you have listed there would be among the top tele zoom lenses out there at the moment IMO, we just need to see more from the Panasonic.
Prefer heavier lenses for stability, I like the bulk I guess, but that's not what everyone is into for sure. 350-400mm is about right for m4/3, but that also depends on where you shoot and how co operative the subjects are.
All the best and this is something Sony should have done years ago. I have no idea what they are thinking. If you don't have the lenses, they won't come to start with
Danny.
 nzmacro's gear list:nzmacro's gear list
Sony Alpha NEX-7 Olympus E-M1 Olympus E-M1 II Sony a7R IV Sony FE 200-600 F5.6-6.3 +5 more
(unknown member) Veteran Member • Posts: 9,509
Thanks Martin,
That is interesting....and of course to compare them truly you have to add an adapter for M4/3 as otherwise it is apples to oranges for me.
I am in two minds about this.....optically I think it will be stunning but on M4/3 for the money, it is simply too slow for me for much use.
Sure it would have lots of use but given M4/3 has (opinion and subjective) a smaller usable ISO range and therefore smaller shutter speed range, I would just find it limited to outdoor daytime use.
I am sure that many will make perfect use from it though and it will be worth every cent for them.
Now after all that...I can beat that too!
Somehow I think maybe not for image quality though....
Cosina/Vivitar/Phoenix ETC 100-400 4.5-6.7 (even slower).....is 740g and 162mm x 74.2mm!
At the price, if I can find one for around $100 in Canon mount at some point I would love to at least try it.......and if someone wants to give me the Panasonic 100-400, I will gladly take it and cherish it.
rovingtim Veteran Member • Posts: 8,872
I'm really excited about this lens as well. I like traveling light.
Big and bright is fine until you have to carry it somewhere.
(unknown member) Veteran Member • Posts: 3,010
The extra reach and IQ of the new Panasonic is great for some but for me its too slow. I'd love a 100-300 zoom f4 at the long end. I don't care about IS or weather sealing.
Advent1sam
Advent1sam Veteran Member • Posts: 9,089
Except Pana is 200-800 (f5.6 @600mm) the others are 150-600 and the 1.4 tc makes them 200-840 (f8)
The Fuji is an APSC lens and at 400mm will be "600mm" at 5.6 the same as the Panasonic at 300mm.....don't think it can be adapted to M4/3 currently...certainly not with a smart type adapter.
The Canon, well that will depend on what camera you use it on.....on an M4/3 camera it will be just the same focal lengths as the new Panasonic lens (but faster).
The Canon can be used on M4/3, APSC (1.5x and 1.6x) and FF.
Advent1sam
You could with the Fuji I guess, but you wouldn't, it's more expensive, heavier and af will be non-existent. The Canon, well yes, but its lots more expensive and too big and af, even with a adapter will not be as good as the native lens on the designated m43 body!
You would only use these lens if, a, no option available, there is, or you already own one and didn't need another and were prepared to put up with the inconvenience!
That remains to be seen.
I actually expect the AF to be very good with the Panasonic but maybe not the greatest due to the slower aperture.....should be better than adapted similar lenses though yes.....at least for now anyway.
It does not ALWAYS follow that an adapted lens (with a smart adapter) is lesser than a native lens.....yes, most of the time it does but improvements in the last year have been rapid (even today there is a new firmware update for the Kipon AF adapter for EF lenses to M4/3 cameras).
Or if you don't like a particular quality of a lens (like bokeh), or if 6.3 is too slow and you might want 5.6 instead, or if the cost difference was greater than any other compromise difference (cost alone can be a big reason to choose one thing over another).....or if the other choice is good enough for ones needs/wants/uses.
Canon lenses now auto focus (some pretty much natively), IS lenses are stabilized ETC and some adapted lenses are little different to using native ones.....more so for manual focus but some AF lenses as well.
Weather sealing is something this lens will have in its favour....and again, form the few photos I have seen, I think it looks like it is a wonderful lens and maybe the best choice for image quality for its range on an M4/3 camera.
I would LIKE this new lens but wont buy it (cost, speed, only usable on M4/3) but would spring for a cheaper slower Vivitar 100-400 in EF mount as it would be about the price of postage for me for that new Panasonic lens from overseas, it can be adapted on several systems and it (might) be good enough....might be rubbish too but maybe worth a punt.
This new lens is a brilliant choice for many....others maybe not.
Denjw
Denjw Veteran Member • Posts: 6,853
Hand held or tripod?
Surely based on the specs the Panasonic is going to be comfortably hand held? The photos and comments in the hands on preview would seem to support this.
http://www.dpreview.com/news/5337706458/hands-on-with-the-panasonic-leica-dg-vario-elmar-100-400mm-f4-6-3-lens?slide=2
http://www.dpreview.com/news/5337706458/hands-on-with-the-panasonic-leica-dg-vario-elmar-100-400mm-f4-6-3-lens?slide=3
Panasonic are certainly marketing it as a such.
Yet this comment from one of the first users of this lens in this thread
http://www.dpreview.com/forums/post/57099561
has me intriqued.
"All need to realize that this is a larger lens than most use. It's heavier and while it can be hand held (as I did) at least a monopod is advised. This definitely transforms your camera into a nose heavy monster."
Notwithstanding aperture range I would have assumed that most people interested in this lens would be using it hand held to shoot wildlife. With IS and or Dual IS this should be easily achieved.
Or is the issue more to do with balance when zoomed out to full focal length?
Maybe people who are interested in  the versatility/reach of this lens are going to be put off by its size/weight or find it harder to use then expected.
Those coming from a background of using larger telephotos should have no issue.
In my experience the Oly 40-150mm f2.8 + MC14 (slightly smaller/lighter) on the E-M1 is easily handheld.
As is the Oly 4/3 50-200mm F2.8-3.5 + EC20 (slightly bigger/heavier with external zoom) is easily hand held.
There are users of the larger/heavier SHG 4/3 lens such as the 300mm 2.8 who can shoot with them hand held.
Just interested to know what others think.
 Denjw's gear list:Denjw's gear list
Olympus E-300 Olympus E-30 Olympus E-5 Olympus E-M1 Olympus E-M1 II +17 more
Messier Object Forum Pro • Posts: 12,724
Re: Hand held or tripod?
has me intriqued.
hi Dennis,
The 100-400mm should be easily hand-holdable for somone with ordinary hand strength. As funny as it might sound, when I haven't been using my 300/2.8 lenses for a while I use a pair of 4Kg hand weights a few minutes a day for a few days before I  go on a shoot. It definitely improves my stability.
At the moment I have a 2Kg lift limit so no big lenses for a few weeks
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
Denjw
Yes Peter I also would have thought so.
Just that comment quoted above got me scratching my head.
Even Olympus are marketing the 300mm f4 as hand holdable.
Maybe some people think m4/3 users are all puny folk or geriatrics!
Hope all went well and you are on the road to recovery.
Cheers
Dennis
has me intriqued.
"Hand held or tripod?"
There's a lot of ifs and buts in that one Dennis and you probably already know the answer
For someone that's not used to looking down the barrel of a 400mm on m4/3, get a monopod IMO at least. On fine days I would have no problem. Then again, I don't exactly throw the camera into Iauto mode or use auto ISO either. Those things and settings all come with time as you know. We are all different though, but those that already take shots like that, already know what to do.
Experienced users will have no issue in good daylight, but if you want to shoot in darker conditions, use some sort of stable platform for sure. OIS, IBIS or a combination of both can be a benefit, but its not entirely needed in good light, higher shutters speeds are more than capable of getting the shot. Once again though, that's a time and experience thing.
If people think they can take a shot at 1/30 of a BIF and stop the wings and not get movement even with all the stabilisation in the world applied, then good luck with it I actually expect to see a few shots from these lenses at ISO 1600 - 2500 and slow shutter speeds with some fairly daft questions. The likes of yourself, Trev, Martin, Peter, Vas, Ray, etc, etc, already know exactly how to shoot with these focal lengths and settings and that's a huge difference, hand held or not.
Still others will take a shot of a bird or BIF from 100-300 meters at 400mm thinking they can crop in "Hey the lens is not that sharp, there's no real details" Ya think !!
Some people are going to be in for a shock with what they see at 400mm on an m4/3 sensor, while other will take it in their stride. Just get the BIF in the frame and worry about it later sort of thing. No time for ..... pretty and fancy composition, just click the darn thing.
All the best Dennis and you folks will have no issue in knowing what to do, others, get at least a mompod.
Danny.
