14-140 sharpness almost as good as 12-35/35-100 f2.8
Started Jan 14, 2016 | Discussions
DrPJ New Member • Posts: 8
Re: 14-140 sharpness almost as good as 12-35/35-100 f2.8
I agree, it´s a really sharp lens for what it is. Came from a Nikon APS-C system with the 18-200 VRII, this Panasonic lens is way sharper at longer focal lengths, and same sharpness at wide angle. So pleased with that lens. Plus half the weight....
Panasonic GX8 - Panasonic 14-140 - Olympus 25 mm f1.8
Ken610
Ken610 Regular Member • Posts: 245
Thanks, Mark, for that suggestion. I have the original Oly 14-150, and it's just OK.  I was not aware of a Mk ii for this.  I'll see if I can find a Mk ii to test.  Looking on line, is seems to be a fair amount less than the Panny 14-140 ii, and splash proof to boot.
Ken610
 Ken610's gear list:Ken610's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +3 more
amipal
amipal Senior Member • Posts: 1,275
codyghind wrote:
I don't wanna go off topic, but since most of us around here are reasonably happy with the 14-140mm II, I was wondering what do you think would be a good pair for it as a second, fast prime lens.
I am on the lookout currently as the f3.5-5.6 does not help much in low light situations, and logic tells me that since the 28-280mm equivalent range is already covered, I should go for a fast nifty fifty.
Performance/budget ratio looks good for the Olympus 25mm 1.8, and with the current rebate running it is even more attractive. I could also wait for the rumored Olympus 1.2 to be released, but I'm afraid they will be way out of my budget.
I've happily paired mine with the PanaLeica f/1.4 25mm and Olympus f/1.8 45mm lens, They complement each other perfectly.
Paul
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
