S90 and G11 color profile for RT and Lightroom
Started Jan 14, 2016 | Discussions
markanini Forum Member • Posts: 76
If you are not completely satisfied with raw colors this is for you. Here I'm sharing color profiles generated with with the cutting-edge DCamProf using a Colorchecker shots posted on Imaging-Resource. These profiles use the neutral-plus operators which means subtle tweaks that give enough flattery and pop for various subjects without getting in the way of any subsequent post processing. You can see it as an alternative to the Adobe Standard profile and I encourage you to A/B against it. Should work for S95, and G12 too as they share the same sensor, at least RT will allow you to load any profile without restriction.
Get them here: https://www.sendspace.com/filegroup/yGaveCmklbL38i1qYcY%2BeQ
I would like to request Colorchecker CR2s taken with the G9 if anyone has them.
 markanini's gear list:markanini's gear list
Sony RX100 II Canon EOS 600D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II
Canon PowerShot G11 Canon PowerShot G12 Canon PowerShot G9 Canon PowerShot S90 Canon PowerShot S95
