olympus 75-300 lens for birds
Started Jan 12, 2016 | Discussions
Phocal
Phocal Veteran Member • Posts: 3,262
Re: some comments on your photos and advice
Joanel wrote:
here is the last one edited a bit in elements , they all seem to get softer when posted.the edited one is cropped and may be softer due to that as well. will wait for a sunny day - if we get one - to try again before I post any more. thanks for all the help. comments still appreciated. I know tripod would be better maybe but want something that can do hand held if possible and is light to carry. and in jpeg mostly. (anyone have the canon sx50 and compared this to that???)
edited but not cropped
original
edited
Part of the problem is you have not exposed the bird properly.  I see you dialed in -1/3 EV but you really need more then that.  I have found that when photographing white birds -2/3 EV and even higher is needed. In really bright light even up to -2 EV is needed.
-1 EV and still the highlights are close to be blown if not slightly (which is where I try to land depending on conditions).
-2 EV on this shot
Go to the zoo to try testing things out, it is my favorite place to test new lenses and such.  For me the Flamingos are the perfect test subject.  I can get close to them and there is nothing blocking the view to them.  Perfect test photo subjects with lots of detail.
 Phocal's gear list:Phocal's gear list
Olympus Zuiko Digital ED 150mm 1:2.0 Olympus M.Zuiko 300mm F4 IS Pro Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +6 more
Astrotripper Veteran Member • Posts: 8,421
Astrotripper wrote:
 I'll try digging out some samples from my archive to see how it really did.
Well, looks like I won't have much to offer in terms of sample photos. Since I was shooting airplanes with that lens, all the shots have varying degrees of motion blur and those at 300mm are heavily affected by air turbulence and haze. This is the best I got, at around 200mm, but I see others have offered some better samples already.
From RAW file, no noise reduction at all, and just a tiny bit of local contrast boost, instead of normal sharpening
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +14 more
Ken Gosden Senior Member • Posts: 2,902
Re: olympus 75-300 lens for birds
Tried to run a test of differences in the noise reduction settings, but the light was changing too much to day.  The only subject I found that would sit still outside was a tree about 40 feet away.  Not as much difference as I expected.
all 100% crops at ISO 1600
Pprobably a better sample ISO 800 NR off about 25 feet away.
 Ken Gosden's gear list:Ken Gosden's gear list
Olympus XZ-2 iHS Olympus Tough TG-3 Canon G5 X II Olympus E-M1 Olympus E-M1 II +19 more
Gary from Seattle Veteran Member • Posts: 5,492
Joanel wrote:
I have till Jan31st to return the lens. home the 22nd to take care of this.
Nothing wrong with the lens. Some of your shots are quite sharp, as sharp as other's examples. It sounds like you are still not using a tripod "sort of".
I think pics with the shorter lens are ok. see attached. not edited or anything. hard to get sharp head of anhinga! since so narrow
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +5 more
Jan Krux Contributing Member • Posts: 510
The 75-300 needs practice to use IMO. It's a very light combo, and you need to learn to be "gentle" with the shots.
Results can be pretty good though. Lots more in my gallery.
really stunning shots Martin!
congratulations!
Jan
 Jan Krux's gear list:Jan Krux's gear list
Olympus E-1 Olympus E-5 Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +9 more
ozuiko New Member • Posts: 10
Tried 70-300mm in a recent visit to Long Beach Aquarium. Here are few Lorikeets handheld shots at around 200mm ... IMO, anyhting between 250 to 300 mm needs some level of practice for handheld especially when birds are moving.
https://www.flickr.com/photos/ozuiko/23816029083/
https://www.flickr.com/photos/ozuiko/24416601486
ozuiko
www.flickr.com/ozuiko
OP Joanel Contributing Member • Posts: 998
Digital Dick wrote:
The camera and the lens are fine. You just missed the focusing on the bird and instead placed the focus on the branches to the left of the bird. If you are using the smallest center focus box to focus on the bird (say in S-AF) press the shutter half way down and hold it to lock the focus on the bird then recompose the scene to put the bird where you want in the frame then press the shutter button down the rest of the way to take the image. The camera's auto focus box needs to be placed on a contrasty vertical line to get an accurate focus. Any twigs covering the front of the bird or vertical branches within the focus box but just in front of or just behind the bird can present a better target than the bird for the auto focus to lock on. I try to place the smallest focus box on the eye or head of the bird and make sure there aren't twigs also in inside the focus box. That should give you the bird in focus and the twigs slightly out of focus.
Dick
pretty much thought that was what i was doing.  but maybe not.
 Joanel's gear list:Joanel's gear list
Olympus E-M1 Sony a77 II Olympus E-M1 II Olympus 14-150 F4-5.6 II Panasonic Leica 100-400mm F4.0-6.3 ASPH +5 more
how come standard is SO different than all the others? darker.  seems strange.
ozuiko
have to sign in to see.  password is home. and also says adult content???
if these are the ones below that you think are sharp they are with the 14-150 lens.  it is the longer lens ones in a different post previous to this that I am concerned with.
Oops forgot to set the restriction to safe for viewing...I believe the default is to have restricted.. Try to access the images..
ozuiko
original
edited
-2 EV on this shot
yes I know they could be minus more stops.  it is the sharpness rather than the details in the whites that I am concerned with.  also no flamingoes at the zoos in Mass.  too cold. and some of them close for the winter.
webber15 Senior Member • Posts: 1,600
Joanel...there really isn't anything wrong with the 75-300 f6.7...at maximum focal length I still found it sharp,,less contrast but the detail still there (in good light)...
Dave...
 webber15's gear list:webber15's gear list
Fujifilm X-Pro2 Fujifilm XF 100-400mm F4.5-5.6 OIS WR
Re: Some birding today
Phocal wrote:
dv312 wrote:
in rainy and gloomy weather
Your shots of the Snowy seriously blew the highlights. Why would you dial in positive EV when shooting a white bird? Typically in those situations the camera would be over exposing already and would need negative EV to the detail back in to the whites.
EV is on a different wheel on this camera then all my others cameras.  have to change it. same with the F stop is reversed from what  I am used to.
I was in manual mode and the light was changing quickly.   I was more concerned with keeping the shutter speed and aperture the same for all of them.
The EM-1 is pretty flexible as to what can be assigned to the control dials.   You can probably get it set pretty similarly.
Phocal
But you show a photograph of a white bird and ask about sharpness.  Hard to see if any of the bird is in focus when all the detail is blown out.  I would assume you placed the focus point on the eye but you cannot tell that by the photo.
Do not have to photograph flamingoes, was just giving an example.  Any zoo animals that do not move much and you can photograph without shooting thru wire or glass are good test subjects for stuff like this.  Did not know your location or local zoo situation.  If no zoo is open, can always set up a stuffed animal in good sun.  Anything that has a lot of detail and not perfectly flat will work as a test subject.
It seems as if the op is inexperienced with the subjects and the gear being used...if the oly 75-300 doesn't do what to op needs...move to som that does work...
Dave...
Dave...
inexperienced with the gear but not the subjects.  trying to go lighter with my gear if possible.  what does "som" mean?
Dave...
what images are your referring to?  something you have taken in general or something posted here?
