Another convert to m43
Started Jan 12, 2016 | Discussions
Chi Pham
Chi Pham Senior Member • Posts: 1,163
Looks like I was able to persuade my brother to join the m43 bandwagon.
But at the same time, I feell I have violated a cardinal sin against the Equiv God. After all I have learned throughout the year, why I cannot tell the truth?
I told him that the lens are Equiv is 28mm-300mm DLSR wise!!!
Now I fear my karmic retribution will be heavy for this lie.
How many levels of hell are there, 9?
Do you think I can take picture with my m43 sensors there?
Best
Here's a history dialog:
FROM ME:
This is a very good deal.
Zoom range 28-300mm 2 lens.Small package as you want that takes as good a picture as my camera.Chi
FROM HIM:
CHi,I'm sold on the Olympus e-PL series. Last time you emailed me the e-PL5 model. This one is a e-PL6 series.
The e-PL6 series is a bit cheaper and seems to have the same specs. I'm still trying to determine why the difference in price. Do you know? Does the PL6 has the ability to swap out lenses?
FROM ME:
EPL5 is the older generation, inferior to EPL6. EPL7 if the latest model and cost $399 just for the body. You get two lens covering 28-300mm with the EPL6 and there are many more lens available that you can use.This format is called Micro-Four Third and is supported by both Olympus and Panasonic. Meaning you can use Panasonic lenses too! Lens can go from $100 to $2500!Many PRO photographers are using this now for their main gear so don't be concern about any limitation.It's very good.
FROM HIM:
e-PL6 it is.
 Chi Pham's gear list:Chi Pham's gear list
Olympus E-3 Olympus E-500 Panasonic Lumix DMC-GX7 Sigma 70-200mm F2.8 EX DG Macro HSM II Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +8 more
Olympus E-PL7 Olympus PEN E-PL5 Olympus PEN E-PL6
Brian Steele Contributing Member • Posts: 638
Re: Another convert to m43
How is the E-PL5 inferior to E-PL6?
Brian Steele
 Brian Steele's gear list:Brian Steele's gear list
Olympus C-2100 UZ Olympus E-520 Olympus E-620 Olympus PEN E-PL5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +9 more
Skeeterbytes Forum Pro • Posts: 23,184
Yes, you have indeed sinned but since you also brought a convert into Our Cult, you are forgiven.
Now go forth and sin no some more.
Rick
Astrotripper Veteran Member • Posts: 8,676
As we all know, smaller is inferior to bigger, hence 5 is inferior to 6, hence...
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Mistajolly Regular Member • Posts: 352
Why do you need to convert anyone? Is it a religion?
I do agree that if the user base was bigger there might be more native lenses from third parties. I think that's the only weakness in my view of m43.
 Mistajolly's gear list:Mistajolly's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Olympus OM-D E-M10 II
rodriguezPhoto
rodriguezPhoto Veteran Member • Posts: 4,260
Don't anybody tell the E-M10 this...
~~~ Kim
 rodriguezPhoto's gear list:rodriguezPhoto's gear list
Olympus E-1 Olympus E-3 Canon EOS 6D Olympus E-M1 Olympus E-M1 II +55 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Inferior?
Yup, "inferior" is a strong word. It's the same camera but with a couple of little changes, like adding a level gauge (which I find irritating on my E-P5 so never use it). Plus intervalometer added, but only for up to 99 shots with interval from 1 second to 24 hours. Has "Short Release Time Lag Mode" to cause a shorter delay from shutter press. Base ISO still 200 but the "ISO 100" has been added, which anyone can do on any camera by over-exposing 200 by one stop and being careful with highlights.
If none of those are important (none are to me) then either E-PL5 or E-PL6 does exactly the same job and looks and handles the same.
For Pens it wasn't until E-PL7 (or E-P5) that the better IBIS was installed and 0 second anti-shock was available. Those two features make a truly significant improvement.
Olympus USA blatantly or foolishy lied in the E-PL6 specs where they said it is "3 axis" IBIS when it is truly the 2 axis IBIS of old. The E-PL6 was a Japan only release in May 2013 but later was also sold outside Japan in some more countries.
As well as my timeline http://homepages.ihug.com.au/~parsog/olyepl1/80-Oly-timeline.html also my messy E-PLx chart may help sort out features http://homepages.ihug.com.au/~parsog/olyepl1/21-epl1-vs-epl2.html
Regards..... Guy
Hitherto Contributing Member • Posts: 812
The E-PL6 was initially also packaged with a Toshiba Flash Air WIFI memory card so you could use Olympus's Image Share WIFI app, and share your images at the same time.
 Hitherto's gear list:Hitherto's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +2 more
Chi Pham
OP Chi Pham Senior Member • Posts: 1,163
Re: Inferior?
Thanks for the very informative information.
That's still useful things added IMO.
BUT I do have one theory for newer body.   Even with same sensor,  they had more time to work out the bugs and improve sensor efficiency at the backend.   For example, the EM10 II  has the EM1 but seems to have better IQ test results.
Best
Ask not what the camera can do, ask what you can do with the camera.
Klarno
Klarno Veteran Member • Posts: 4,239
Speaking as an equivalence "apologist", I have no problem with someone stating the equivalent focal length on its own, unconnected to anything else. It's a very useful way to describe the AoV range of a lens. Probably the only useful way, as no one seems to "get" degrees. My only problem would be if you said the lenses were equivalent to 28-84 f/3.5-5.6 and 80-300 f/4.0-5.6. That is a misrepresentation easily overturned by evidence.
But I feel that the representation by luddites of equivalence "apologists" as being religious in their devotion is a problem. We are the Bill Nye to your Ken Ham, and the very website you are using has acknowledged that much. The real religion here is the Church of the Holy Trinity of Exposure (In the name of the f-number, the shutter speed, and the ISO, amen).
 Klarno's gear list:Klarno's gear list
Sony Alpha NEX-6 Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +9 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
Re: Inferior?
If you ever shoot ultra wide, give it a chance. I tried using it with my GX8 and 7-14mm shooting some interiors and keeping the camera level made the images MUCH better, with fewer exaggerated lines, etc..
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Chi Pham
That's correct.   It still comes with the free WiFi.
Best
Chi Pham
It seems to be preached everyday like one.
This exercise prove to me that the average consumer does not know anything about the M43 format.
It's a shame really.  Sigma did join the 4/3 party with some gold tele lens. 70-200, 50-500.
Guess it didn't payoff to return to m43.
Best
Henry Richardson Forum Pro • Posts: 21,959
E-PL6 or E-PL7?
Chi Pham wrote:
FROM ME:
FROM HIM:
FROM ME:
FROM HIM:
e-PL6 it is.
Did he get the E-PL6 or E-PL7? Both are mentioned in your post. I seem to recall here on the forum talk about the E-PL7 having the 0-second anti-shock setting, but the E-PL6 doesn't and the E-PL6 really needs it a lot. Doesn't the E-PL6 also have the old, not so useful IBIS?  Might want to investigate about that.
Henry Richardson
http://www.bakubo.com
Fri13 Veteran Member • Posts: 3,116
Well.... In the sales you need to talk in the sense the customer understands from where they are coming.
Like how much they can save and how much they can gain. That is marketing talk. But then you need to explain the truth what really matters and why the marketing talks still mattered.
And your sin was to call m4/3 as format, it is just the bayonet and 4/3 is still the format as sensor is still the same 4/3" and there is nothing micro in it
Guy Parsons
Re: Inferior?
Useful if they are of use to the individual. Some can live without those features.
It's really an E-PL5, just released a few months after the E-PL5 for the Japanese market, any updates would have also sneaked into E-PL5 updates.
E-M10ii has a Sony sensor (like the E-PL5/6) and the E-M1 has a Panasonic sensor, they deliver different results.
Regards...... Guy
Guy Parsons
Re: Inferior?
Yes, I use the 12-40mm, 9-18mm and Samyang 7.5mm and never use the levels, I use the LCD to get things right by judging what is happening to verticals and horizons, I find that way easier than trying to satisfy the level indicator.
I see the results that I need, and do not concentrate on the levels which seems to actually hinder the framing for me.
Regards........ Guy
jeffharris
Re: Inferior?
I tend to trust my eye more than the camera, too.
I don't know if you've ever shot with one of the 7-14mm lenses, but shooting interiors @ 7mm requires quite a bit of subtle camera positioning to minimize distorted lines at the edges of the frame. Raising and lowering the camera vertically is the trick. The level gives subtle visual feedback while composing that doesn't cramp creative style.
Chi Pham
Re: E-PL6 or E-PL7?
Thanks Henry for the reminder.
I did some investigation and it looks like it does not have 0-sec antishock.
However, I think 1/8 sec is OK when needed. The GX7 is 1 sec which is much slower if I remember correctly.
As the the IBIS, that's true that it's only 2-AXIS.
That equates to 1-2 stops which is similar to GX7?
Bottom line, for $319 with body and 2 kit lens, it's a good deal still.
Best
Chi Pham
Before you feel almighty with your new understanding of things you should know:
Your evidence is only meaningful to you and your followers.
You wish to undertake photography as a factual science full of meanings.
I wish to look at it as an art, unbound by rules and meanings.
When I see shallow DOF photos, I say that's nice in it's way and different.  No dislike, hatred, and fully respect it's characteristic as portrayed by the photographer. When I see more DOF, I say it's nice and different.  No dislike ,hatred, and fully respect it's characteristic portrayed by the photographer.
So next time when you impose your view that science say it must be so, think how foolish it is to impose your views on others.
That's the beauty of a photo.  There's millions of different views on it and none of it is wong.
PS: Whos' Bill Nye and Ken Ham?
Best
