Fri13
Re: What you are asking is equivalence!
nejeime wrote:
In this instance though, I’m more interested in the performance – autofocus speed & accuracy - as well as people’s more subjective interpretation of image quality of these cameras..
Autofocus in S-AF mode will perform better in m4/3 than most DSLR cameras or even those small ones. The C-AF is good performed in most m4/3 cameras for semi-pro DSLR levels but only a E-M1 will be just behind D4 and 1D level top DSLR cameras since firmware 3.0 update.
The Olympus has around -3 LV performance for AF, while Panasonic has in some models for -4 LV and that performs in crazy low light so awesomely that you need to pay a lot more for DSLR to get same performance capabilities.
And when it comes to image quality, you need to be more specific about what you mean with "image quality". As it is combination of all kind features from contrast, color accuracy etc. And depth of field has nothing to do with the image quality as it is up to photographer choice to select what is in focus and what isn't.
Same thing is with the noise, it is up to photographer to choose what will reflect the character of the photo (content, what you are trying to capture) and no noise is often not wanted, as it is just too "clean" and some noise can make wonders to many photos, if the noise is just very good (and example Olympus has excellent noise characteristics) as it will increase the exposure range and as well add tonality to details, where your brains starts to fill the "missing parts".
When it comes to "image quality" as overall, m4/3 cameras can produce same quality as like any DSLR can regardless of the sensor sizes. Even a other mirrorless cameras like Sony A7r II has difficulties to top m4/3 cameras as in most common situations, print sizes (even larger than common ones) and subjects there is no such difference that would make it better than good m4/3 cameras (You really need to go to very special kind photography where the differences starts to be very clear, like hitting to very dim light environments with video where A7S models has the benefit because they can go over ISO 6400 easily without same technical limit as m4/3 bodies has or like astrophotography where then cameras like D810A is needed).
Take photos, make big prints and hang on the walls and you will not see a quality difference.
Or take photos and use them in web or computer (phones, tablets, computer screens etc) and you will not see a difference in the photos that has been taken from real world situations instead test charts.
