A Bit Disappointed with the G5X
Started Jan 11, 2016 | Discussions
redsars Forum Member • Posts: 60
I picked up a G5X after Xmas as an upgrade to my G12. The G12 has been my trusted travel companion when I don't want to lug around my DSLR gear.  I have to say I am a little disappointed. It has all the features I wanted and the OVF is great. But the the lens and noise performance is not what I had hoped.
Looking at the same RAW images taken on both cameras,  the lens resolution seems to be around the same,  so that there appears to be no benefit in having almost twice as many pixels,  the G5X lens is definitely soft,  particularly at the wide end.
There is slightly more noise on the G5X than the G12 also.
Maybe I will forgoe the OVF and stick with the G12 or give the G1X a try.
How are others who are upgrading Don older G cameras funding it?
Canon PowerShot G12 Canon PowerShot G5 X
boogisha
boogisha Senior Member • Posts: 2,858
Re: A Bit Disappointed with the G5X
I would find it really strange that G12`s 1/1.7" sensor (with its 10 MP and an f/2.8-f/4.5 lens, and yes, I know 4.5 is at 140 mm equivalent) is giving a better image quality than a G5X`s 1" one (with its f/1.8-f/2.8 lens, and 20 MP). Maybe, but just huge maybe in a really good light (as G12 has a CCD sensor which some consider sharper), but as soon as shooting conditions get out of "ideal" zone, G5X`s light gathering abilities should win hands down (because of both the sensor size and lens speed).
That said, if you`re comparing both images at 100%, then I think you`re simply doing the wrong thing. One of the ideas of higher resolution cameras is not (just) to allow for bigger print sizes (or viewing at higher resolution screens) - while you can do that, of course (but usually without much noticeable improvement in quality), the biggest gain is in having a better image at the same (physical) size as before (but with more mega-pixels now, thus a possibility for more data/details, and a better image).
I can`t say I don`t know the feeling - coming from a 3.2 MP CCD camera (Canon A75) to a 12.1 MP CMOS one (Canon IXUS 220HS) I was shocked with the decrease in image quality... when looking both at 100% But what happened is that camera market made a shift in the meantime, blowing up mega-pixels and changing its philosophy - and yes, actually printing the same sized image was now at least the same, or usually better, with that important difference that shots which were impossible to make (because of difficult/missing light) with A75 were now more or less easily achievable with IXUS 220HS.
p.s. Ok, I re-read your post, and being a dSLR user, I guess you don`t need me to tell you about the stuff I previously wrote (I`ll leave it as it may come of some use to others)... But then, I must say that I`m really surprised by your disappointment - could you post some images (even better - RAW files), helping us to see where/why your expectations failed?
I`m interested because I have G7X (sharing the same sensor/lens combo with G5X), and I`m nothing short of impressed with it`s capabilities so far (and all the data inside the RAW file)... but yes, I understand that not everyone has the same needs/views
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
Digital Nigel Forum Pro • Posts: 17,852
7
There's a reason that the corrected G5X and G7X images look soft at the wide end: the original image suffers from heavy barrel distortion and vignetting. The image needs a lot of stretching to correct it, which softens it:
Uncorrected image shows strong barrel distortion and vignetting. The projected image circle doesn't cover the full sensor area.
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +22 more
Jim Senior Member • Posts: 2,666
p.s.Ok, I re-read your post, and being a dSLR user, I guess you don`t need me to tell you about the stuff I previously wrote (I`ll leave it as it may come of some use to others)... But then, I must say that I`m really surprised by your disappointment - could you post some images (even better - RAW files), helping us to see where/why your expectations failed?
I don't think that the sensor is at issue with the G5X as outlined by the OP; it's the lens that's the problem.
Jim
 Jim's gear list:Jim's gear list
Canon PowerShot Pro1 Fujifilm FinePix F30 Zoom Canon PowerShot G1 X Canon PowerShot SX50 HS Canon G1 X II +10 more
boogisha
I was talking about sensor/lens as a combo that works together, providing the image you get in the end. We shouldn`t discuss them apart as we are not shooting them apart.
While G5 X`s lens is probably (not to say - certainly) more compromised than G12`s one (as it needs to cover decently bigger sensor area in a similar, compact package), its overall output as a result of both sensor/lens combination (and 20 MP RAW) should win over G12 in most of shooting situations (probably not all, but close to it, and not if viewing both images at 100%, as previously explained).
I imagine G12 might, just might produce sharper/better images when both cameras are shot at their wide(st) ends (most noticeably in the image corners), and with a lot of light in the scene - but as soon as you start zooming in or amount of light starts decreasing, G5 X should be a pretty clear winner. And we shouldn`t forget that G12 starts at 28 mm (equivalent), so it should be even closer with 28 mm on G5 X (in comparison to 24 mm, like the image Digital Nigel posted).
That`s why I`m interested in discussing concrete RAW examples from both cameras, getting to see why redsars (original poster) formed an opinion like that. In the end, might be that he got a defective G5 X unit...?
I think there is probably a consensus that G5 X`s lens is more compromised (I never owned G12, but it could make sense), but even so I don`t think the overall result (RAW image) should be worse than G12`s one - it should even be much better nonetheless, except (maybe) in a few situations where G5 X`s lens is pushed to the limit, and that`s what I`m interested in.
If redsars  finds G12 output to be better than (or up to par with) G5 X in a majority of situations, then it seems like something is wrong there, don`t you think?
lanefAU
lanefAU Veteran Member • Posts: 6,348
My I ask where was that photo taken?
 lanefAU's gear list:lanefAU's gear list
Samsung Galaxy Note 5 Canon G1 X II Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED +3 more
Varadero, Cuba. More in:
https://www.flickr.com/photos/recliner/sets/72157663285759165
or for more sets from the same trip last month:
https://www.flickr.com/photos/recliner/collections/72157662076870009/
peter42y Senior Member • Posts: 2,204
In good light CCD sensors were awesome indeed.
 peter42y's gear list:peter42y's gear list
Ricoh Caplio R8 Canon IXUS 310 HS Nikon 1 V1 Canon EOS M
AdamT
AdamT Forum Pro • Posts: 62,282
6
When I heard about the arrival of a G5X, I thought GREAT, finally a real serious upate for the traditinal G compact . when I then read that it was using the Horribly compromised optic from the G7X , well that was the end of that ........
What a Waste Canon ! it`s one thing sticking a lens like that on a cam the size of an S90 but the G5X deserved - no, DEMANDED a no compromise lens, sadly canon decided to cut corners hoping no one would notice.
Ahh well, back to the big bulky G1X
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
(unknown member) Veteran Member • Posts: 5,590
9
A "no compromise lens" with similar specifications / price might have made it totally unattractive to most potential users, certainly in terms of size. The cynics may say they should have done better and accuse Canon of cutting corners (probably without any experience of the compromises required in lens design); the pragmatists might argue that the product meets their needs at a price they are prepared to pay.
(unknown member) Veteran Member • Posts: 6,192
You do have to wonder if getting a large sensor in to a tiny camera with large aperture is as much as a marketing numbers game as packing lots of megapixels in to a tiny sensor was.
Sony have not managed to get more than 3x zoom in to their version of the type and the stretched zoom in the GnX's just possibly pushes it a bit far.
I wonder if the G9X which is not pushing zoom or aperture may in fact be be the classier act. I hope Cameralabs put the G5X and G9X images side by side when they test the latter.
damian5000 Senior Member • Posts: 1,948
This G7X compromised lens nonsense is just that... nonsense. All of these cameras are compromised to some degree. Every few days there's a new experienced photographer coming from DSLR posting to praise G7X IQ.
 damian5000's gear list:damian5000's gear list
That's possible. As well as an attempt to create new niches in photo equipment that might just help slow down the decline in interest in cameras a little. On the one hand we complain when manufacturers try things and castigate them when they don't.
Of course you're right.  All lens designs are compromised in some way or another.  Now I'm looking at a Leica Q.  It's £3K compact, has only a fixed 28mm lens (which by all accounts is very good) but apparently it still uses software correction.
kodakrome
kodakrome Senior Member • Posts: 1,026
Horribly compromised??
Compact cameras all have compromises. Their appeal is in their small size, which can't be attained without making compromises. However, comments like "horribly compromised optic" are just absurd exaggerations - almost always made by someone that doesn't own the product. I've been using a G7X for 15 months, and I don't see anything that supports the idea that it has a bad lens. Here are a few examples of why I'm calling bull on that comment.
Please look at the 3rd photo - taken in a candy store. This shot was at the widest end of the zoom range - reportedly the weakest part of the lens. The shot was taken at 1/40th of a second with my arms stretched out from my body, so maybe there could be a little softness from camera movement. But a bad lens? That's just total nonsense.
NWT Contributing Member • Posts: 744
Sony is limited because it does not spend money to design or produce its lens.
jp4 Senior Member • Posts: 1,202
I wouldn't have bought the G5X if it had been the "classier act" with the more limited (in range and aperture) lens.
j-p
 jp4's gear list:jp4's gear list
Canon PowerShot G5 X Canon EOS 80D Tokina AT-X Pro 11-16mm f/2.8 DX II Canon EF 100-400mm F4.5-5.6L IS II Canon EF-S 18-135mm F3.5-5.6 IS USM
Sony reduced the zoom range in the later RX100 models, compared to the earlier ones, in order to improve image quality, particularly at the wide end. Canon went for a more ambitious zoom range, at the expense of IQ at the wide end. Both are understandable decisions, and no-one should be surprised that a wider zoom lens is more compromised. My personal preference is for Canon's wider zoom range in a compact package, because when I want high quality wide angle shots, I have other cameras that do that better anyway.
Where Canon really cut corners was in the electronics, where it skimped on the buffer size, so burst mode is very slow, particularly with RAW shots, and a number of RAM-intensive nifty features that Sony does very well are missing altogether, such as in-camera panorama, various multi-frame NR options and good HDR. Sony also managed to squeeze in an EVF without making the body any bigger.
Actually you are making an assumption there aren't you?
Sure you can. That's like saying you shouldn't discuss an engine and transmission separately in a car because you use them both together. It doesn't work that way. The lens and sensor are separate components that have their respective characteristics, good or bad, and should be judged accordingly.
Jim
