big wave surf photos with EM5-II and Panasonic 100-300
Started Jan 8, 2016 | Discussions
OP 2chicos Regular Member • Posts: 211
Re: big wave surf photos with EM5-II and Panasonic 100-300
Thanks again Ronald. Here is another attempt using your suggestions to the extent of my ability. The biggest change is the black/white level adjustment. I'm using Highlight -79, White +36, black -45, Clarity +20, Medium contrast curve, Sharpen +70, Calibration: Adobe Standard.
Is this better? I also went through the others and definitely prefer the changes you suggested.
Thanks again
John
Thank you doccy.  This looks good.  Are you using LR?  If so can you share your adjustments?  Thanks.
doccy Regular Member • Posts: 359
Cheers. Mainly lightroom - +0.75 to exposure then used the sliders to spread the contrast / set the white point to avoid clipping. This image doesn't need a low black point as it makes the sea look bad. Some clarity and dehaze.
I then added some local contrast in photoshop which really helped bring out detail and took out some of the blue saturation - but then forgot to reset my highlights when I brought it back to LR so it was clipping a bit.. duh!
This is a better image with that fixed...
https://500px.com/docwheeler
StillLife
StillLife Regular Member • Posts: 229
Fantastic pictures
 StillLife's gear list:StillLife's gear list
Olympus OM-D E-M10 Olympus E-M5 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
