The Plastic Fantastic gets a Drastic Upgrade
Started Jan 7, 2016 | User reviews
shleed Contributing Member • Posts: 757
I have used my 50mm f1.8 mkII since I began photography and I loved the results I got from it. The shallow DOF, large aperture for low light, everything. However, the main things that particularly bothered me was how inaccurate it focused and how cheaply it was built. I lived with it and didn't stop me getting the results I wanted.
Once I seen the STM version come out, I was certainly intrigued. People sang praises of it but I wanted to see for myself, so I bought it.
I was floored by the upgrade in build quality. The plastic is much more robust and more akin to the engineering plastic on my 100mm f2.8L macro lens. It has a metal mount, which is fantastic. 7 curved blade aperture design = I can now finally stop down without horribly shaped bokeh. I feels good in my hand and the improved focusing ring is so much better.
The STM motor is also VERY accurate. My hit rate went from 50-60% to 80-90% with this lens. It's also quiet and faster to AF. My only gripe with it however is that it's manual focus can only be used when holding the shutter button down in AF, or when the camera is metering in MF. You cannot use it outside these as the focusing ring is only triggering the motor, rather than being directly linked to the focusing mechanism. However for the much increased AF accuracy, I can live with that.
Another grip is the filter thread, which is 49mm rather than the previous 52mm. Time to get another adapter ring methinks!
Optically, it seems a little bit better. Not much to write here, but I didn't have issues with the optical quality of my previous 50mm.
I highly recommend this over the previous 50mm. It's sold at a similar price but it's a much better lens overall.
Here's some photos I've taken with it:
f2.8 - no horrible pentagon bokeh!
Wide open it looks similar to the previous 50mm.
 shleed's gear list:shleed's gear list
Canon EOS R Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100mm F2.8L Macro IS USM Irix 11mm F4 +3 more
Canon EF 50mm F1.8 STM
Prime lens • Canon EF • 0570C002
Announced: May 11, 2015
shleed's score
4.5
Average community score
3.8
Canon EF 50mm F1.8 STM Leica SL 50mm F1.4
dzba Senior Member • Posts: 1,680
Re: The Plastic Fantastic gets a Drastic Upgrade
I enjoyed your post, both the insight from your experiences AND the pics you shared.   It seems that Canon has several STM lenes that are good value for the money.
Thanks for sharing this info here,
Mike
please do not alter,save, or repost any of my images without 1st receiving my permission to do so.
 dzba's gear list:dzba's gear list
Panasonic Lumix DMC-FZ30 Canon EOS Rebel T4i Nikon D7500 Canon EF-S 18-55mm f/3.5-5.6 II Canon EF-S 55-250mm f/4-5.6 IS STM +2 more
Steve Balcombe Forum Pro • Posts: 15,582
I don't have any STM lenses yet, but I've been thinking about picking up one of these to replace my ageing 50/1.8 MkI. However manual focus in Live View is very important to me, and I can sometimes spend several minutes setting up a subject, adjusting focus multiple times. How does that work in practice? Will I have to half-press the shutter button each time to enable focusing?
trulandphoto Senior Member • Posts: 1,019
I tried using a Cokin A series filter holder with mine and the lens wasn't happy. The focus motor just made lots of noise and couldn't move the weight.
So, I picked up cheap 49mm CPL and ND filters instead.
I do love the lens hood. With it on you don't need to be concerned with leaving the barrel extended.
 trulandphoto's gear list:trulandphoto's gear list
Canon EOS R Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F2 Macro IS STM Canon RF 50mm F1.8 STM +3 more
I had a similar problem with my MkI - in my case it was using a heavy B+W Kaesemann 72 mm CPL with a step-up ring. I know 52->72mm seems a bit extreme but it was only for occasional use, indoors on a tripod. It worked but it wasn't happy, so like you I bought a smaller filter.
OP shleed Contributing Member • Posts: 757
It works fine in live view since it's always metering.
Outside live view, you have to make sure it's metering to keep it working, otherwise half tap the shutter button. You only need to hold it if it's on AF in order to do manual override.
I wouldn't use a massive filter holder for it - I've my 17-40 for that. It works fine with my polariser though, despite all the adapter rings.
That's excellent news. Then I might invest in one while my MkI is still working.
Thanks for the info, much appreciated.
