Anyone destroyed an EF 70-300mm L?
Started Jan 7, 2016 | Questions
Dunross New Member • Posts: 6
Hi everyone. This is my first post, so I want say a quick thank you to DPReview and to all the members of the community. I've been coming to this site for the better part of a decade, and have found the content and the wisdom of the community members to be nothing short of inspiring.
Now the Question:
After much deliberation and many sleepless nights I've decided to bite the bullet and purchase the EF 70-300mm f4-5.6L IS USM. In the end, the combination of its physical attributes, IQ, image stabilization performance, and alleged durability made it a no-brainer for the style I shoot (that being extreme sports while participating). The body I'm using is a Canon 7D (which I love). We've been around the block and I have pretty good idea of how much abuse the 7D can take, but with the new lens that threshold is a bit of a grey area.
So, has anyone here killed an EF 70-300mm L. If so, what was the straw that broke the camels back? I'd also be interested in hearing obituaries for other weather sealed L lenses.
Thanks!
 Dunross's gear list:Dunross's gear list
Canon PowerShot S40 Canon PowerShot SD780 IS Fujifilm X100T Canon EOS 7D Canon EF-S 17-55mm f/2.8 IS USM +3 more
Canon EF 70-300mm f/4-5.6L IS USM Canon EOS 7D
Gelbvieh Regular Member • Posts: 236
Re: Anyone destroyed an EF 70-300mm L?
Tried and failed over the last 4 years and mine still works brilliantly.
 Gelbvieh's gear list:Gelbvieh's gear list
Canon PowerShot G1 X Canon PowerShot G7 X Canon EOS 5D Mark III Canon EOS Rebel T4i Canon EF-S 17-55mm f/2.8 IS USM +6 more
Steve Balcombe Forum Pro • Posts: 15,582
A full day and no response at all* - I guess that must be a good sign! When mine was almost new, I tripped and fell on a rough track. The 7D and 70-300L were subjected to the double indignity of hitting the ground then having me land on top of them. The 7D gained some deep scuffs on the top, but the lens was unmarked and has continued to work perfectly ever since. One experience doesn't prove much I guess, but it was a positive one.
I have several L's now, and build quality is superb in all of them. "Extreme sports while participating" sounds like a pretty stern test, but with reasonable care you shouldn't have any problems at all.
(* - when I started writing - Gelbvieh got in just before me!)
hotdog321
hotdog321 Forum Pro • Posts: 21,141
About the only thing that can destroy a lens is bouncing them off a sidewalk, and often they survive that. Or dropping them in the ocean. Or scratching the optics, though a lens hood generally eliminates that concern.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
diness Veteran Member • Posts: 3,758
Have not used the 70-300L, but one thing to consider is that the barrell does extend when zooming. I would guess this would be the most likely thing to break. If you don't need 300mm, you could consider the 70-200 f4 is which does not extend. All the Ls are super well built though, especially these telephoto zooms
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
OP Dunross New Member • Posts: 6
Excellent! Sounds like this is the beginning of a long and beautiful friendship.
Thanks Balcombe, that's exactly the kind of anecdote I was hoping for. I hope that you came away from that spill without too many dents yourself.
I will certainly treat the L with the respect it deserves, but it sounds like it's going to be able to go everywhere I do, on the hip rather than in the bag.
Myer Veteran Member • Posts: 3,338
I Have One
I have one and have not tried to destroy it.
However, just a few things.
In Canon's wisdom the lens does not come with a tripod mount.
There is no Canon TC for that lens.
The design is such that I could not use the lens hand held without having my hand move the over-sized and ill-placed manual focus ring.
As a result I bought the tripod mount and learned to hold the lens so that the tripod mount keeps my hand from touching the focus ring.
Since I shoot wildlife and birds in flight, I'll be replacing the 70-300 with the 100-400 II when I get around to it.
Awesome! Mind if I ask you another question (after this one, obviously)?
I notice that my 70-300mm L makes a kind of buzzing sound when the IS is on and it's trying to focus (I'm no audio expert but I'm going to say that this buzz is at least three times louder than the sound of the lens focusing normaly). The sound is not present when IS is off. I bought the lens used so I can't be sure if this is a normal thing or a problem.
The sound doesn't bother me, but it does seem a bit out of place. Any insight would be much appreciated.
That's the IS working. Normal.
Geronimo73
Geronimo73 Regular Member • Posts: 201
Re: I Have One
I did get the 100-400 II for exactly the same reasons you mentioned and I'm really happy I did.
Will get an 1.4 extender with a camera that can AF at f/8 and will be even happier...
The 70-300L is a great lens but you cannot go further than 300. The 100-400L feels as strong as the 70-300L and handling it (weight) is almost the same...
 Geronimo73's gear list:Geronimo73's gear list
Canon EOS R6 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 50mm F1.8 STM Canon Pixma Pro-100
Hinder Contributing Member • Posts: 819
I didn't answer this thread originally because I thought you wanted stories on how they break, but I can no longer resist.  I have had mine for four years and absolutely nothing has happened to mine. I love it.
 Hinder's gear list:Hinder's gear list
Canon EF 50mm F1.8 II Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot S100 (2000) Canon PowerShot SD500 +21 more
TheBlackGrouse Veteran Member • Posts: 3,586
And another one...
Had my new 70-300 L for two days and when swinging the Thinktank Rotation 360 around with force, the belt bag got loose, flew through the air and bounced on the ground.
Well serious, according to the others my face went completely white in a second.
The lenscap had smashed into the lens thread and couldn't be removed. For three days I circled around it like a caged tiger before I got the courage to take the cap off. This was only possible with some tools and took me an hour, doing it as careful as possible.
But the lens was fine, and still is today.
Never trusted the bag since then
TheBlackGrouse
Active outdoor photographer, trying to become better, studying user experience.
maarensv
maarensv Senior Member • Posts: 1,106
I tried to sand off the coating on the outside by using a third party tripod mount ring, and I succeeded in that. Some of the white coating missing now. Definitely my own mistake.
For anything else, being not overly cautious using my photographic gear, the L survived all my mistreatments pretty well. Stopped using protectionfilters quite a while ago and the coating on the front element is still perfect.
Sandor.
 maarensv's gear list:maarensv's gear list
Canon 6D Mark II Canon EOS R Olympus E-M5 III Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM +22 more
bigfatron Contributing Member • Posts: 777
Sandor.
I had a similar experience where i'd rubbed a tiny bit of the paint off with a third party collar.  Still irks me that one wasn't supplied with the lens and the official one is criminally expensive.
I had another L lens (24-105L) survive having the front 1-2cm immersed in running water (low shot on a mini-tripod and the camera overbalanced forward into the edge of a stream) for a couple of seconds with no ill effect.  Fortunately it had a filter attached at the time.
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Canon Extender EF 1.4x III Canon EF 35mm F2 IS USM +3 more
StevenLeavin New Member • Posts: 1
I just purchased this lens as well. It is built like a tank. However my IS does not make any noticeable noise. I purchased new. I suppose that if its working for you then it will be fine.
 StevenLeavin's gear list:StevenLeavin's gear list
Canon EOS 6D Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EOS 450D Canon EF 85mm F1.8 USM +3 more
Would call it a soft rattling sound, a bit like the cooling fan of a computer. Sometimes it seems loud, other times not but that depends on the the acoustic characteristics of the environment and the other sounds. In a quiet hide it can make some noise.
TheBlackGrouse
