Birds in Flight : Bee-eaters (40-150 pro)
Started Jan 3, 2016 | Photos
vass
vass Senior Member • Posts: 1,929
31
The Rainbow Bee-eater is my favourite bird and after a few sessions capturing them with excellent results I thought id'e try my luck with flight shots only. I looked at my exifs and from my 1st shot to the last Bee-eater shot there was just over 2hrs on the clock. I was really happy with the results and got about 40 good keepers.
I won't try post them all but here are some of the results.
I didn't use the EE-1 for these but felt confident as I still get a lot of swallows without it. Mines playing up (reticle seems to shift) but I found my framing a lot better without it. harder to keep them in the EVF but better centred once in and found I had less wasted shots due to mis focus as I can see when the camera lost focus in the EVF. I do shoot with both eyes open (1 on bird and one on EVF) which is hard at first but after getting use to it it helps me get the bird back in the EVF if I lose it in the EVF.
Here are some of my best ones
100% crop of the 1st photo to show detail captured
regards, Vas
 vass's gear list:vass's gear list
Panasonic Lumix DMC-FZ18 Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro +3 more
Comment & critique:
Olympus 40-150mm F2.8 Pro Olympus E-M1
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
Re: Birds in Flight : Bee-eaters (40-150 pro)
what a great set of images Vas, I'm envious, we have nothing like this in the UK.
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
I haven't seen them for ages. Great set.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
webber15 Senior Member • Posts: 1,600
As good as it gets...can't imagine dslr boys getting better...superb...
Dave...
 webber15's gear list:webber15's gear list
Fujifilm X-Pro2 Fujifilm XF 100-400mm F4.5-5.6 OIS WR
Opseuman Regular Member • Posts: 494
Vass,
Just gorgeous shots !
Thanks for posting.
Regards
 Opseuman's gear list:Opseuman's gear list
Olympus OM-D E-M1X OM-1 Olympus Zuiko Digital ED 14-35mm 1:2.0 SWD Olympus Zuiko Digital ED 35-100mm 1:2.0 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +20 more
nebulla Senior Member • Posts: 1,528
Absolutely nice set. A very good lens, and a good photographer behind the camera.
Cheers
 nebulla's gear list:nebulla's gear list
Sony a7 III Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 400mm f/5.6L USM Tamron SP AF 90mm F/2.8 Di Macro +4 more
joeletx Veteran Member • Posts: 4,126
Vass,
This series top out all of what you have posted. You have once again outdone yourself. The shots are sharp with nice color. Well done!
 joeletx's gear list:joeletx's gear list
Olympus E-500 Olympus E-M1 Olympus E-M1 III Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus Zuiko Digital ED 18-180mm 1:3.5-6.3 +10 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
very very good, 210mm is that with a convertor?
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Old Listener
Old Listener Senior Member • Posts: 2,028
WOW! WOW! WOW!
Envy doesn't begin to describe how I feel lookingat these pictures.  Luck to be in the right place at the right time and skill to capture what you see.  Your gear really did its job.
Keep 'em coming!
 Old Listener's gear list:Old Listener's gear list
Panasonic Lumix DMC-FZ50 Panasonic FZ1000 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +5 more
klythawk
klythawk Contributing Member • Posts: 643
Absolutely top class work Vas !!!
 klythawk's gear list:klythawk's gear list
Olympus E-M1 II Olympus OM-D E-M5 Olympus E-M1 Nikon D610 Nikon D500 +8 more
boxerman Senior Member • Posts: 1,946
Kudos, and a question on focusing
Brilliant shots!
Technical question: Assuming your high shutter speeds can stop the outer reaches of the wings (where I see de-focus), it seems the depth of field is only a body-width or two. So, it's STUNNING that the camera (and you) manage to catch the body, only a fraction of the scene, in focus. How much of this is luck...that is, is it shot selection that gets you the body at the center of focus? Or, is the camera focus that good, technically? Very hard for me to imagine. With wings nearly vertical (shot 7), why wouldn't the focusing system prefer the expanse of the wings, over the body?
With the apparently narrow DOF, I was surprised the f-stop was mostly 5.6-6.3.
The BoxerMan
 boxerman's gear list:boxerman's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +4 more
vass
OP vass Senior Member • Posts: 1,929
Thanks Trevor
Yes with the mc-14 (1.4x)
The one that doesn't exist on DPR lol, can't tag it
vass
Re: Kudos, and a question on focusing
Thanks Boxerman
I got pretty close to them on some occasions there which means thinner DOF. I try to focus on the front of the bird, head and neck area which is why the body is in focus when it is. I find the lens with tele has a very narrow DOF, guessing teleconverter doesn't help here.
I'm pretty sure on shot 7 the wings are in focus, just slightly blurred from movement. Not sure if you ever seen a bee eater fly but they are very fast.
https://www.youtube.com/watch?v=hhrhLb1EDcY this will give you idea of how they fly
boxerman wrote:
Brilliant shots!
John Byrne Veteran Member • Posts: 7,174
Re: Sensational.
Beautifully done, a really pleasing set of photographs. What metering and focusing modes were you using Vass and also where were these photos taken.
Thank you,
John
vass wrote:
Thanks Boxerman
Yes, I was thinking you must have gotten pretty close, and noted the TC would, indeed, further reduce DOF.
I looked back at shot 7, and given three things, I'm still leaning toward OOF, and not motion blur.
  1. The blur of the tip of the back wing is noticeably more than the front. Motion blur should be mostly symmetrical.
  2. The wing is at the top of its "travel," so should be going "slow" (comparatively), compared to its maximum speed.
  3. Good heavens, 1/2500 sec! I tried to do a back-of-the-envelope calculation of wingtip speed, but couldn't find data (and wasn't willing to search for high enough speed video to determine) on frequency of wing flapping, to give a good estimate of wing-tip speed.
Anyway, I have seen bee-eaters in Africa, but I don't think I got any good BIF shots. Lilac-breasted rollers, on the other hand, I have a few! Both rollers and bee-eaters are spectacularly colored birds.
The BoxerMan
John King
John King Forum Pro • Posts: 14,941
Beautiful set, Vas. Well done, mate. Thanks.
A really superb looking bird. I've never even seen one IRL ...
Regards, john from Melbourne, Australia.
Please do not embed images from my web site without prior permission
I consider this to be a breach of my copyright.
The Camera doth not make the Man (nor Woman) ...
Perhaps being kind to cats, dogs & children does ...
Galleries: http://canopuscomputing.com.au/gallery2/v/main-page/
Bird Control Officers on active service.
 John King's gear list:John King's gear list
Olympus E-1 Olympus E-510 Olympus E-30 Olympus E-M1 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II +17 more
nzmacro Forum Pro • Posts: 18,756
Jeepers creepers
SUPERB and especially in 2 hours !! Fantastic Vas, love the colours and wing positions. Truly excellent flight shots of a smallish bird. Timing is bang on and so is the lighting, my favourite position for the sun that brings out those gorgeous colours and details. All bang on.
#9 .... bang there ya go The best bee eater shot in flight I've ever seen on all the nature avian forums. Print that out large mate, its worth it.
All the best Vas, again superb work and shots.
Danny.
 nzmacro's gear list:nzmacro's gear list
Sony Alpha NEX-7 Olympus E-M1 Olympus E-M1 II Sony a7R IV Sony FE 200-600 F5.6-6.3 +5 more
DickyAus Veteran Member • Posts: 4,563
Truly excellent series Vas.
Dicky.
 DickyAus's gear list:DickyAus's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko 300mm F4 IS Pro +1 more
maggiemole Senior Member • Posts: 1,988
I am green with envy! Not only that you have such beautiful birds as subjects, but of your technique, equipment and the results! Utterly gorgeous images, thank you.
Maggie
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
vass
Re: Sensational.
Probably full metering with some at centre, can't remember really but I use all metering types depending on subject, how far it is and colour of subject. CAF H @ 9fps with 9 box focusing area.
EDIT: Photo's taken near Sydney, Australia
Thank you,
John
