NX1 photo iq & focus issues
Started Jan 3, 2016 | Discussions
lebigmac New Member • Posts: 16
I have been shooting with the NX1 for a while now, with several different lenses (16-50 kit lens, 16-10 s lens, 30 mm, 2.0) and I am experiencing some problems that are obviously not lens related. It would be interesting to know for me, if these are common issues to other NX1 users:
focus: autofocus fails even when locked on to subject. Manual focus fails as well, i.e. peaking area is not sharp at all on the stored image. Many pictures are mushy all over the place, like the pictures was taken in the fog. it is very difficult to find a focused area at all. Interestingly, this is not happineng all the time.
I suggest, it could be an issue of earlier versions  of NX1 hardware.
I made some comparison shots with a NEX 5t, 50/1.8, both cameras resrt to defaults, P, center AF
NX1 wiht kit lens
Shot with Nex 5t 1.8 50mm
Nx1, 30mm, 2.0 lens
NX1, AF locked on van
nex 5-t, af locked on van2
NX1, 16-50 Kit lens
NEX-5T Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 30mm F2 Pancake Samsung NX1 Sony DT 50mm F1.8 SAM
Kinger
Kinger Contributing Member • Posts: 549
Re: NX1 photo iq & focus issues
I have issues with the 30mm in low light missing focus. About 10-25% of time in low light it will go green but not be in proper focus. I no longer have a 16-50 PZ because I must have had a bad copy and always got slightly out if focus shots with it. My 16-50 S is reliable and fast as are the 45mm and 16mm primes. The 30mm is awesome in moderate to bright light, but pretty bad otherwise. I always use my S in low light or my NX mini with 17mm 1.8 ois lens. I have not noticed NX1 camera related focus issues.
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
MikeDPR Regular Member • Posts: 241
#1: Looks fine to me
#3: DOF and focus distance difference. Non issue.
#4: Blurry due to shutter speed being too low. (#3 Sony benefits from OSS)
#6: Looks darn sharp to me.
#1 and #6 do look a bit hazy. Are you saying it wasn't actually hazy like that?
 MikeDPR's gear list:MikeDPR's gear list
Samsung NX300 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 85mm F1.4 ED SSA +2 more
ttbek Veteran Member • Posts: 4,869
... are you complaining that you can see the effects of the fog in your shots of foggy days? Of course it varies with the lighting conditions and the fog moves around. I would be more concerned about why your reds are orange on your Sony, and actually your NX1 is looking a tad pink. Unfortunately I can't look more closely at the shots at the moment (mobile version is not amenable to that).
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
On the van shot you have shaken your camera in a V motion (you can see it clearly on many point light sources just above the van - they are all like flattened V) due to quite long exposure (1/13s for 30mm is too long by at least two stops). Sony lens has optical image stabilization which compensates camera shake.
OP lebigmac New Member • Posts: 16
What I find disturbing is that it seems also the case with manual focus. Even you have the right area peaked, you'll find it out of focus on the stored image. I'll have to look if it is limited to low light situations.
Hi Mike
If you zoom into the traffic signs in the distance, you'll see, that they are blurry on the samsung. Both cameras where focussed to inifinity,i.e. the bridge.
Yes, you're right, that's probably the reason here
]#6: Looks darn sharp to me.
Yes, it was quite a normal day, no direct sunshine but by far not foggy as it seems. Once in a while, I get grainy wall shots like that, with virtually no detail in it. It's like a cellphone shot from the 90ties, with nothing to work with in raw. I can't say if it's related, but occasionally I do get pictures at low isos (100 / 200) with lots of noise in dark areas.
So far, with in NX1, I can't predict really how the camera reacts.
Well, it was definitely not as foggy that day. I often get pictures like behind a foggy curtain in bright but diffuse light.
You're right, none of the cameras is getting the reds right, the neon sign is definitely not pink. I would attribute this to the awb i used, that does not work totally accurate in dark enviroments.
Yes, I think you are right, I didn't take the is into account. The van is not a good example for making my point. I have another typical example with 1/100 shutter and center AF/AE on the kit lens.
zipcode Regular Member • Posts: 312
I agree with all of the above.
Also, the last picture is pretty much all the kit lens can do at 50mm 5.6. You need to stop it down more (you had the light). I now have 2 copies of the lens and it's just all it can do at 50mm. The more towards 16mm, the better.
Edit" I see the first pic is also at 50mm. Same reason for the bluriness.
Well, if you really can confirm that it's not an technical issue, that is quite a deception. I own a olympus e410 with kit lens (which costed in its time 1000€ less than the NX kit), which never let me down with results like these. And considering that the 30mm has its quirks as well... I understand that a more 'pro' cam is more challenging to the photographer than a entry level one, but it should at least deliver comparable results under comparable settings.
I also made some comparisons between the nex with the 1.8 50mm and the nx1 with the 16-50 S lens (night at a fun fair). Here again, I find the nex delivering more constant results, often less noise in raw, more accurate to the scene and desired focus area, and seems just more reliable to me. Only by zooming in to max, you'll see that the NX has a more detailed resolution in the fine textures.
Unless you focused on the top left corner (it's sharp) there is something very wrong with your camera or lens. Center looks like camera shake or severe decentering but top left is in focus (though it's blown out and it's corner on wide angle kit lens with field curvature and everything). What were you focusing on?
You are right, there's a sharp spot on the upper left. It was center AF focussed on the center of the iron grid gate.
Tugela Contributing Member • Posts: 755
You need to use the magnified view to get accurate peaking. This is true for Sony cameras as well btw.
This is because it is easier to find an apparent contrast boundary on the whole image than on a magnified image.
When done properly, manual focusing using peaking is absolutely accurate. But remember, it is just a tool, and a tool used incorrectly will not do the job.
 Tugela's gear list:Tugela's gear list
Nikon Coolpix P900 Sony RX100 V Nikon Coolpix P1000 Samsung NX1
Cameras will pick up light scattering from haze much more effectively your eye might.
Specifically, the area relatively in focus is far in the distant background. That means the lens was not focussed at all, and is probably set on or close to infinity.
If all of his lenses are doing this I am betting it is user error rather than anything to do with the lens.
Well, I was using center AF, focusing on the gate, focus priority on release. I find hardly anything in focus. If it is a user error, I'd be very grateful for an advise to avoid them. (I got MF peaking set to 5* magnification).
Stan Still Regular Member • Posts: 227
I think your problem may be camera shake.  I put the image through "Shake Reduction" in Photoshop Elements 14 and it has sharpened it up a lot.  I am not sure if it shows on this thread but it is much better on my computer. Try taking a photo using a tripod and see if it makes a difference.
 Stan Still's gear list:Stan Still's gear list
Panasonic FZ1000 Panasonic LX100 Panasonic ZS100
Looks defintetly better. But at 1/125 & the lens OIS, shake should not be an issue. I had DIS switched on as well.
lamer01 Junior Member • Posts: 48
So, you are saying the OP needs to cut down on coffee and Red Bull? hehehe
