Followup: 25mm is FRONT FOCUSING on G7 (examples)
Started Jan 3, 2016 | Discussions
clengman
clengman Senior Member • Posts: 1,991
Re: Mine too
Big D in SP wrote:
JConrad wrote:
My 25/1.7 also front focuses, most notably at infinity. Closer up it seems fine (though it has more problems on the GX8 than on my E-M10 II). Near infinity, it almost always front focuses a fair bit, causing softness even stopped down.
Landscape shots were one of the first to suggest to me that the softness of indoor shots was something more than poor resolution and why I tested the focusing accuracy.
It's interesting that the lens seemingly focuses better on the EM-10 II than the GX8. Why, I wonder, would that be?
Warren
One thought that occurred to me was that it might have something to do with DFD. Focus distance lookup table not quite matching the actual behavior of the lens?
 clengman's gear list:clengman's gear list
Olympus E-M1 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Rokinon 7.5mm F3.5 UMC Fisheye CS +4 more
tobicy68 Contributing Member • Posts: 700
Re: Followup: 25mm is FRONT FOCUSING on G7 (examples)
robjan245 wrote:
I had the same issue with my G7 with the 14-140 lens. I ended up returning the G7 for the Sony A6000.
I have the same issue with my GM1 mounted with the 14-140 II. Focus seems fine in most focal lengths except at the tele end.
I at first thought it's just my technic and not know this lens enough but after reading similar issues with different lenses at their tele ends, I might have to keep this in mind when shooting at tele ends.
 tobicy68's gear list:tobicy68's gear list
Canon EOS M100 Canon EF 85mm F1.2L II USM Canon EF-M 22mm f/2 STM Sigma 18-35mm F1.8 DC HSM Art Canon EF 50mm F1.8 STM +1 more
opiecat Senior Member • Posts: 2,410
Re: Mine too
JConrad wrote:
My 25/1.7 also front focuses, most notably at infinity. Closer up it seems fine (though it has more problems on the GX8 than on my E-M10 II). Near infinity, it almost always front focuses a fair bit, causing softness even stopped down. Manaully focusing will sharpen it up (though it's only 'good' stopped down anyway). For close up work, it works fine for me...nails focus for the most part and is decently sharp at f/1.7. Really have to be careful for shooting landscapes with it though.
i know this is an old thread, but i've had my 25mm f1.7 for almost a year but didn't use it much until recently.  and so i noticed that something in the AF was really wonky particulary at longer distances.  i couldn't put my finger on why that's happening.
until i read this thread ...
it's front-focusing and/or decentered.  i'm sending it to Panasonic for repair.
just curious. anyone send it to panasonic for repair and did it get fixed?
'when 900 years you reach, look as good you will not' -- master yoda
http://opienc.wordpress.com
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
Re: Not sure, however....
I see that back in May 2018 there was a firmware update for several cameras and lenses - including the 25mm f/1.7 - model H-H025
http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/index2.html
Perhaps not the solution - they say it's purpose is... "Improved focusing stability when using the Lens Position Resume function." ... but thought I'd give a try tomorrow.
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
Peter
thanks. i did that f/w update but the lens was still front-focusing.
strange. i thought contrast detect shouldn't have this issue.  maybe it does focus correctly, but just when the shutter opens the focus shifts?  DK.
eques Veteran Member • Posts: 4,115
Also Sony A7iii
I also have been thinking, this would not happen in mirrorless camera, but obviously it does.
https://www.dpreview.com/forums/post/61068247
Here the OP seems to refer to 2 other samples of the A7iii.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
