(unknown member)
Re: I had the exact same issue with 3 PL 15mm lenses.
Astrotripper wrote:
Bhima78 wrote:
Its the lens. I had the same problem with 3 different copies of the PL 15mm on my E-M10 about a year ago. I have since gotten the PL15 again for my work camera (GX8) and have also put it through its paces on my E-M10. My new PL15 does not exhibit this issue at all. I even did 45-degree A/B testing like you did. What I think is going on:
Our contrast detect lenses open to the widest aperture to find focus, then stop down to the desired aperture once focus is achieved and then the shot is taken. Something with the electronics is telling the camera that yes, the lens has found focus (prematurely), so stop down (if you aren't shooting wide open), and fire.
Contrast detect SHOULD prevent this from happening. However, all the camera system is doing is deciding whether something in the depth of field focus zone is in focus or not. Practically, that means that the point might be in the very front of the zone, the very back of the zone, or the middle of the zone - all of those locations would read to the camera AF system as "in focus." Focus peaking has the same issue - I've got images from a recent concert where focus peaking told me the eyes were in focus, and they were... but were at the very front of the focus zone, so the images were un-useably soft across the performers' faces.
This is why, when shooting situations where precision control of DOF is important (think portraits, close in, with an f1.2 or f1.4 lens), you really should either manual focus, or autofocus and then manually adjust.
I've seen this many, many times over the years with all kinds of cameras. Phase detect focus systems have the same issue - they detect if a target zone is in focus, NOT whether it's in the middle of the DOF focus zone. That's why you have the setting that allows you to AF and then manually tweak. It's also why many of my professional photographer friends are switching away from DSLRs from Canon and Nikon, to mirrorless systems. (Four of them in the last three months.) The focus screens on DSLRs are NOT optimized for manual focusing - what they show you is effectively f2.8 (at best) to f4 (most frequently), so trying to manual focus an f1.4 lens is a crap shoot. I know people will tell you that they can but if they do, they're not shooting enough in critical situations to know that it's impossible to do accurately. You can't beat design parameters.
Used to be you could change out focus screens for ones that showed with more precision - the tradeoff was usually that they went dark and unusable after a certain focal length and max aperture, but the last high pixel count Canon that could do that was made several years ago. The last Nikon that could do that was the D2X. This is what's now causing a number of pros who love wide aperture shooting to switch, usually to Sony (full frame so you get the max benefit of a wide aperture lens, high pixel count since they print large).
However... if a lens is de-centered, it WILL produce results like people are talking about here. That's something that sending it in for repair should fix. I've been told many times by Panasonic, Olympus, and Fuji reps at sessions they've held, that there's no focus tuning adjustment capability on contrast detect cameras and lenses. They're not the engineers so maybe they're wrong, but multiple people, multiple brands, multiple times, makes me believe them until I find out otherwise.
Stopping down might be an issue only when the lens suffers from serious spherical aberration and thus closing down the aperture causes focus plane to shift. I doubt any native MFT lens exhibits a problem like that (but I might be wrong).
Yes, many of the MFT lenses do have spherical aberration issues. I can see focus shift in the 42.5 f1.2 - although the depth of field increases usually cover that up reasonably well. But that's at the cost of precision of placement of the DOF.
One thing people miss is that m4/3 cameras (maybe others, but I know it for certain on m4/3 because I've looked through the lens from the front) do stop down when focusing. I don't know why, but the aperture does jitter down and back with AF engaged. You get people posting in forums about "my lens is making noise when I'm on constant focus" all the time. I suspect it's for dealing with focus shift.
As for contrast detect systems, you can get an idea how it works if you have a slow focusing lens. Take a note of how focus changes back and forth, but pay special attention to the final stage. You will notice that the final change into focused position is immediate. There is no further confirmation, there's no fine tuning at the last moment. It goes from well out of focus straight to focused in a single quick move and it's done. If autofocus motor is faulty in some way, or if another kind of issue prevents it from working properly and consistently, you will get focus errors because that final move does not lead to a result that the camera expects.
Remember that the final move is to being in focus - NOT to centering the DOF zone around the point being focused on, because it's impossible to determine that algorithmically and still be fast. Hence, it's very, very common to get images that look front focused or back focused. I'm in a long email conversation with someone who's a well known DSLR expert (sells books, popular web site, frequent conference speaker) on this. He maintains that contrast detect focus isn't a panacea for flawless AF on wide aperture lenses even when manually focusing. I used to disagree until my recent trip where I shot a couple thousand images with the 42.5 f1.2 and 75mm f1.8. The number of images where the DOF zone is just slightly off is massively annoying, auto focused, or manually focused. I need to learn to work with and tolerate magnified focus assist windows popping up.
Contrast detect is not a magic bullet that never misses. I mean, you could make it work in a way that it would never ever miss, even with faulty lenses. But we all want AF to be fast, so we have to live with the compromises that make it possible.
Placing thin DOF zones has always been an issue, even in manual focus days. The increased reliance on AF makes it seem worse, because now it's "happening to us", but I remember going through image review in classes 10 years ago and taking a beating from the instructor for not managing placement of the in-focus zone.
