Sensor size and diffraction.
Started Jan 2, 2016 | Discussions
Erik Ohlson
Erik Ohlson Forum Pro • Posts: 22,390
"Hmm, I wonder if my better pics were taken using A mode...
Now I need to experiment. Thanks for the comment (should have read all the posts earlier!).
It is very likely that this is, indeed, the case.
"A" mode is the best for any of the pocket zooms, by any manufacturer.
It's technical - physics, actually. The sensor is quite small, therefor the lens must have a very short focal length - usually about 4.3mm (that is approximately 1/3inch).
The 'aperture' is the "hole" the light comes into the camera. The aperture can be changed, and the numbers used to keep track of this are the RATIO of focal length to the size of the opening. (Divide the size of the opening in millimeters into the focal length in millimeters = the "ƒ/number" value.
There is nothing magical about this - but where the "Magic" comes in is that - due to physics again (sorry!) when light passes through a hole, it "scrapes" on the edges. All waves do this, including light and water. Here is a picture of water waves passing through an aperture, notice how the wave pattern changes and smooths (blurs) out.
The waves are coming toward you in this photo:
View: gallery page
When light does this, it blurs the image. It's called "diffraction". It can NOT be avoided.
The wider the hole, the less blur.
There is a critical size "hole" for visible light - approximately 3mm (1/8 inch).
This 3mm hole happens to be about ƒ/3.3, and going smaller than that (larger number - yes, its confusing) the blurring effect gets much worse.
So setting the Aperture to ƒ/3.3 and LEAVING IT THERE will ensure the sharpest image the lens is capable of. Period.
There is no "downside" to this: the camera will then choose a shutter speed (from 1/2000th second right down to 1 full second). This "wide open" aperture is best for "low light" too - it lets in more light.
When you zoom out, you will see larger ƒ/ numbers although the actual "hole" remains the same, the changing numbers are just how many times the diameter is divided into the focal length - which is changed by zooming.
Forget all you have ever heard about "stopping down for depth of field" - with this extremely short focal length you have extremely deep depth of field (Physics again, sorry).
Once you become more familiar with photography, you can use different apertures at the long zoom focal lengths where the diffraction effects do not apply. (Yep, physics, again.)
So, set it on "A" mode - about -.66 EV is a good idea to control the brightest parts of the picture and improve the general appearance of your images, and the camera takes totally automatic pictures by changing the shutter speed.
That's all you really need to know for using this type of camera.
"Measure wealth not by things you have but by things for which you would not take money"
www.flickr.com/ohlsonmh/ ohlsonmh@yahoo.com
Holger Bargen Veteran Member • Posts: 4,906
Re: Sensor size and diffraction.
View: gallery page
Thank you, Erik, for letting us know this fact. It is important for me. I do a lot of macro work and a couple of days ago I found a video at youtube where a photographer told, that he prefers macro photos with a long focal length and extended DOF as he does not like to do image stacking with short focal length and the time consuming process at the computer, afterwards. I did not know why this should work - but now I know it.
I could also imagine that these macro photos done with e.g. Lumix cameras which are great most of the times, use the same effect. If the sensor size is very small the light will hit the sensor with a sharp angle and thus less diffraction at the aperture.
I could also imagine that it is best to have the aperture in the middle of the optical construction we use e.g. a distance ring, a zoom lens with a nice (many blades) and very small closing aperture and a lens in reversed position in front of it with aperture wide open.
I plan to do some testing the next days and I also have an extremely long lens (an old Novoflex 600 mm) which could be part of strange constructions ...
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
drh681
drh681 Forum Pro • Posts: 20,742
You should do a math check.
4 mm is much closer to 1/6 of an inch.
Sorry, that just popped right out at me.
Photons by the bag.
Gravitons no longer shipped outside US or Canada
The best photographic tool is between the photographer's ears, not in front of his nose.
 drh681's gear list:drh681's gear list
Canon EF 40mm f/2.8 STM Lensbaby Composer Pro with Sweet 35 Optic Nokia Lumia Icon
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Actually, most small-sensor cameras simply don't have an aperture to adjust when the sensor is already at the diffraction limit -- this is why so many Canon PowerShots have a built-in ND filter (which is motor driven to go in/out of the optical path).
The ones that have an adjustable aperture iris generally have a long enough zoom range so that the smaller apertures are usable at least at the longer focal lengths. In fact, the fully automatic program modes will generally do the right thing in terms of avoiding the potentially worthless combinations of focal length and aperture.
However, the principle is correct, and especially when using fully manual lenses adapted to a smaller-than-expected-film-size sensor camera (Pentax Q, Nikon 1, etc.), the smaller apertures (higher f/numbers) should be avoided.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Erik Ohlson
OP Erik Ohlson Forum Pro • Posts: 22,390
Quite correct, and the cleaner, rounder opening [usually matt black as well] may well reduce flare as compared to the metal polyhedral openings of adjustable apertures.
Certainly the familiar "starburst" flare we see in most cameras is very much reduced in my Casio ZR700 as compared to my Panasonic ZS25. [the Casio ZR700, 800 & 850 have some very interesting "tricks" such as in-camera macro-focus "stacking" achieved through very rapid burst shooting and dual-core processing]. A visit to the Casio forum may interest you.
Yes, again, although I can't really agree RE: the fully automatic modes which usually go to tinier apertures too quickly.
This post is one of several versions which I have used over the years, trying to help new users on the Panasonic Compact Camera forum. Unfortunately, so much of the literature is hung up on larger format that the considerations of diffraction limits are rarely discussed and, indeed, many "authorities" do not understand it themselves.
Thank you for your input.
I actually just "parked" this post in this fairly inactive forum to check some editing I'd done without confusing the issue on the panasonic forum in case there were typos, and decided to leave it here
Erik Ohlson
Re: You should do a math check.
And "well-popped" it is.
I was not looking for mathematical accuracy - the salient point being that, in round figures, the "breaking point" is around 3mm, 1/3" depending on which physicist one consults - there was quite a "dust-up" some time ago between followers of two different [real: Ph.D] Physicists on another forum.
Thanks for your input.
Erik Ohlson
View: gallery page
Depending on just what you are doing with focus-stacking, you may want to at least check out the capabilities of the Casio "ZR" series of compact cameras; ZR 700, 800 & 850 which have a mode in which a series of exposures are taken in a very rapid "burst" and stacked in-camera automatically. The cameras are quite inexpensive.
The Casio forum may be of assistance:
http://www.dpreview.com/forums/1015
Interesting thought, perhaps the Professor will have something to say about this.
Best regards
Holger
drh681
Perhaps this is where the confusion comes in...
1/3" is a camera sensor size but it's not related to any dimension of the sensor!
Photons by the bag.
BobORama
BobORama Senior Member • Posts: 2,842
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
Erik Ohlson
BobORama wrote:
Cute cartoon, but you are obviously not considering the SMALL sensor, diffraction-limited cameras under discussion.
BobORama
Your f/3.3 rule is bunk as it does not take into account the size of the sensels, which is about the only thing you don't mention, and the only thing that matters other than f-stop.
Tom Axford Forum Pro • Posts: 10,067
The conventional definition of depth of field does not depend on pixel size
Your rather blunt response suggests that you are one of the small minority who believe that depth of field should be defined in terms of the number of pixels in the image rather than just the overall size of the image in the camera (i.e. the sensor size).
If the conventional definition of depth of field is accepted, then Erik is entirely correct. By conventional definition, I mean that used for the past hundred years; e.g. the definition used when depth of field scales are engraved on manual focus lenses and also the definition used by popular online DoF calculators.
If you wish to start yet another argument about the "correct" way to define depth of field, it might be better done by starting a new thread on that topic.
ProfHankD
CoC issues with old lenses
No, Bob's right: you need a well-specified resolution reference to give a CoC (circle of confusion), and that can be taken either by pixel dimensions or by approximating human visual acuity for a specific print size and viewing distance. The old depth of field scales from different manufacturers rarely used to agree, because there was not a universal agreement about the desired CoC with film.
In fact, this is part of the problem with infinity focus of some old lenses. It turns out that it was not uncommon for the infinity hard stop to be placed not at infinity, but at the point where infinity is covered by the DoF as they computed it. Unfortunately, for film most folks used a larger CoC, so using these lenses on high-resolution digitals reveals that they don't quite reach infinity. This is one of several reasons that adapters are often built just a little short....
Re: CoC issues with old lenses
Well, you seem to want to re-open that argument. I'm not biting, I stick by what I said. We have been through it all before!
BobORama
Re: The conventional definition of depth of field does not depend on pixel size
My rather blunt response suggests I know optics, physics, math, and causality.
What y'all seem to be taking about is matching the resolving power of the lens with the resolution of the sensor to maximize the overall performance of the camera as a system.   However this ignores several contributing factors to overall IQ.  ISO, NR, and the desire to manage DoF, managing shutter speed.  So of course picking an particular f-stop as "ideal" is ludicrous.
I am not sure I ever mentioned DoF in my original post. Can you please argue with something I actually wrote? 'Cuz that would be great.
ProfHankD
DoF is a function of assumed allowable CoC.
What? Yeah, Bob's post was a bit inflamatory, but I'm not opening an argument, I'm ending one with the formal definition (and even gave some useful implications which you handily edited out in your response).
DoF is computed based on an assumed allowable CoC. That's all there is to it; even wikipedia gets it right. You can argue that a particular sensor format should be associated with a particular CoC based on the magnification needed to create a specific print size to be viewed from a particular distance, and the wikipedia article even quotes some common CoC assumptions for various film formats and explains some of the subtleties of CoC choice, but go back to the OP:
"There is a critical size "hole" for visible light - approximately 3mm (1/8 inch)."
That's completely wrong. There is only a particular diffraction limit once you pick an allowable CoC. The exception to that rule would be an aperture close to the wavelength of the light, which would be a lot smaller than 3mm. 3mm wavelength would be well beyond what cameras can see (deeply into the IR band)... and yes, CoC does vary with wavelength -- diffraction comes earlier for reds than for blues. (Actually, there's also the recently discovered extraordinary optical transmission (EOT)  that sort-of breaks all the rules and allows apertures smaller than the wavelength of the light, but that doesn't really apply to refractive lenses.)
Anyway, as I posted earlier, most engineers designing cameras are not complete idiots and hence don't bother putting an aperture iris in that can go way beyond any reasonable diffraction limit -- this is why so many Canon PowerShots have an ND filter insertion mechanism rather than an iris. On properly-designed cameras with permanently attached lenses, the only thing that can get you in trouble is wide-angle use of small apertures (large f/numbers) that were intended to accommodate the long end of the zoom range. That is not what the OP said, but what he said is useful in that it roughly corresponds to application of this fact.
BobORama
While we are posting things not in any way salient to the discussion...   I'm going to let my photography do the talking.   With micro-photography, managing the overall resolution is pretty much the only consideration.   You guys posting cut and past from Google I'm Feeling Lucky searches is rather boring, especially when you get it wrong.  Post something that demonstrates you know what you are talking about.
The FoV is about 3mm wide.
In terms of diffraction, the following was created by placing two of these tiny, fine patterned  honeycomb metal screens about 3mm apart.  The FoV is about 4mm wide.   The image below is the screen BEHIND the front most screen.  So we are seeing through the front most screen.  The image of the rear screen is rather intact, however the diffraction caused by the front most screen creates the fine honeycomb pattern.
FoV about 4mm wide.
Yeah, so why view diffraction limited performance from a technical perspective when you can cut and paste stuff from the Internet?
At least if I am going to post stuff that has nothing to do with the discussion, its my own work.  Well, except for the Sponge Bob thing.
BobORama
Re: DoF is a function of assumed allowable CoC.
Just remember, inflammation is the first phase in wound healing.
I view the OP as the optical equivalent of "everyone should drink only orange juice, its the best juice."   Really?   Why?   Based on what?   How about diabetics?   People with ulcers?  Do you even know what juice is?   Or what an orange is?
Erik Ohlson
This will be my last response on this thread.
I created this thread to help relatively new photographers to understand what's going on with small-sensor cameras as opposed to large sensor &/or larger film.
I have had many thanks over the years during which this and preceding threads have been posted.
Thanks for checking it out.
But of course it attracted some ditz with a forehead inflated by ego who just wants to argue how many angels can dance on the head of a pin.
Don't bother replying, as the "Ignore" button, so thoughtfully supplied by DP, is invoked.
-Erik
BobORama
Re: This will be my last response on this thread.
Other than posting inaccurate information in the wrong forum, thereby failing in that mission....
Stockholm syndrome, I suspect.
Actually I didn't argue that at all.   But while we are talking pins...   salt and pepper on the head of a pin...  made it with a $2 lens.
No Angels, just seasoning.
Much like infants do when they want to make the world disappear.   Good news, only you have your eyes closed.
