My RX10 II freezes
Started Jan 2, 2016 | Discussions
valenterio Regular Member • Posts: 222
My RX10 II freezes
I just got my RX10M2 and for some reason after I take a picture, the red light stays on and on and on. I hit the off button and it still stays on. I removed the battery and the red light went off but the zoom stayed extended. After I re-inserted the battery, the zoom went back to normal and everything seemed fine. For a day. It happened again. I'm using a Sony 64 gig 4K card. Could it be the card?  Or should I just return the camera to B&H? Has anyone else had this problem?
valente
 valenterio's gear list:valenterio's gear list
Sony RX10 II Sony a7R III Sony FE 28-70mm F3.5-5.6 OSS Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS
Sony RX10 II
Rainer Eberhardt Regular Member • Posts: 231
Re: My RX10 II freezes
Let's hope it's only the card
So, has it been properly formatted _in the camera_?
Has the error happened with another card as well?
If you have only this card, check it with a tool like this: http://www.flashmemorytoolkit.com
David Clarke29 Contributing Member • Posts: 787
Ref the zoom staying out - it will, because removing the battery leaves it with no power to retract.
Dave. (UK)
OP valenterio Regular Member • Posts: 222
Dave. (UK)
Duh. Makes sense. I love the power zoom. I shot with it today and it didn't freeze at all. Odd. I haven't done anything different. Maybe a fluke?
valente
edform
edform Veteran Member • Posts: 8,449
Dave. (UK)
This can be caused by a dodgy SD card. Sometimes simply formatting the card in the camera will kill the problem, but there have been one or two reports here in the forum where the only cure was to junk the card.
Ed Form
 edform's gear list:edform's gear list
Sony Cyber-shot DSC-RX10
