Unreadable x3f files repair
Started Jan 1, 2016 | Discussions
Scythian New Member • Posts: 4
Couple of days ago, while I shot with DP1s, I found that the pics could not be viewed with the camera. When I returned home and connected the SD card to PC, most files could be copied to PC but were unreadable by SPP. The others could not even be copied from the SD.
It should be a problem of the SD card, this happened before. The other day I mistakenly took it with me.
I later tried to use several software to repair the unreadable files including this one (http://www.x3frepair.com/) but did not work. Then I used “7DataCardRecovery” tried to recover the files from the SD card again. Strangely, the uncopyable files now can be recovered. They are also readable by SPP. The others, still not accessible by SPP.
I traveled a long way from Tokyo to Shirakawago for these pics, I don’t want them to be lost just like that. Here is an example of unreadable x3f RAW. Is it still repairable?
https://www.dropbox.com/s/7a8khjc3wh62j1r/SDIM1200.X3F?dl=0
 Scythian's gear list:Scythian's gear list
Sigma DP1s Nikon D3200 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +2 more
Sigma DP1s
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,587
Re: Unreadable x3f files repair
It's hard to say if the X3F files can be repaired.  I would look at the Kalpakana threads and perhaps try using them to open the files...
The other thing to look for is something that would extract the JPG file embedded in the RAW files, so then at least you'd have the base image.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
papillon_65
papillon_65 Forum Pro • Posts: 27,030
Unlikely, I deleted some files on an SD card after taking some shots and then my hard drive crashed. Obviously the files are not really deleted, just the reference to them, so in theory they are easily recoverable. Unfortunately, no matter what I tried I could not recover them from the SD card. I had a similar problem a few years ago and had no problem recovering RAW files from other brands. It seems that X3F files are particularly tricky when there are problems.
"Wow! look at the sharpness...." said no non photographer ever....
http://bit.ly/1K1oqkv
 papillon_65's gear list:papillon_65's gear list
Fujifilm FinePix X100 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sony Cyber-shot DSC-HX50V +7 more
Dark slide Contributing Member • Posts: 972
I used to use an SD14, it would sometimes produce unreadable X3F files that showed an about right file size for a normal X3F file. The solution was to use Irfanview (freeware), download both the program and the add-on file. The latter contains the X3F recognition information. Via Irfanview I could access the RAW files and convert to tiff, you lose some SPP adjustment features but you do at least have an image. You might be able to access the X3F files with the SD card still in the camera.
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
All the meta data is inaccessible or gone, according to ExifTool.
Without meta-data, the pointers to the image data (thumb, JPEG, raw) are gone
In support of that, FastStone Viewer will neither show a thumbnail nor a JPEG review image.
File size is 13MB - did you shoot low res? If not, the prognosis is not good, sorry.
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
(unknown member) Senior Member • Posts: 1,857
Yes, it's a DP1s, its "low resolution" is very well implemented
xpatUSA
Nice camera, had one for a while.
I'll try ArvoJ's recovery utility for SD14 on it. Ya never know . . .
the good news, courtesy of ArvoJ's 'X3FRestore':
the bad news: nothing I've got will open the X3F so as to see either the raw or the full-size embedded JPEG.
Looks like the image data might be in there somewhere but I lack the hacking expertise to find and display it. Maybe someone else can . . .
Ted
It's funny that i even see some other images, unfortunately also just very small thumbnails:
OP Scythian New Member • Posts: 4
Thanks for the attempts. Here are a couple of pics I managed to recover using "7DataCardRecovery".
Nice and quiet village, hope more pics can be eventually repaired.
cquarksnow Contributing Member • Posts: 523
If that can help, below is a display of the beginning of the data in the top half, and then an undamaged X3F file in the bottom half, with X3F headers and pointers.
Your data looks like compressed chunks with five x"FC FF D9" delimiters, so jpg recovery are more adapted that X3F-oriented tools or utilities as I don't find the common X3F raw section delimiters in the data.
The file 14072352 bytes in size (multiple of 32)
Chris
Hexadecimal view ; top is recovered file, bottom is normal X3F
 cquarksnow's gear list:cquarksnow's gear list
Sigma DP1 Merrill Sigma SD10 +4 more
ArvoJ Senior Member • Posts: 1,444
Unfortunately this file is corrupted beyond repair. Thumbnail can be saved, about 20% of JPEG preview image too - but RAW data is gone (or blocks of it are fragmented over entire file, what makes similar result).
You can try my utility for other corrupted files - some of these may contain more recovereable data.
http://www.stv.ee/~donq/sigma/X3Fix-20141124.zip
Unpack both files into same place, run X3Fix.exe. Choose one working X3F file from same camera and of similar shooting conditions for template, select single corrupted file (or entire folder) to recover. My utility saves recovered files under new names, including signature of recovered parts (other parts are copied from template file), like this for example: SDIM1200.__tj_.00.X3F - means that thumbnail and jpeg part are somehow recovered, other parts not.
Arvo
Sigma/Foveon information collection and little galleries:
http://www.stv.ee/~donq/sigma.htm
http://www.stv.ee/~donq/images.htm
 ArvoJ's gear list:ArvoJ's gear list
Sigma SD14 Sigma 10-20mm F4-5.6 EX DC HSM Sigma 105mm F2.8 EX DG Macro +1 more
Looks the other files are also beyond repair, if I applied your tool correctly.
Most files were classified "medium":
https://www.dropbox.com/s/49ay44wqcvpmu28/SDIM1196.X3F?dl=0
https://www.dropbox.com/s/4ge1mcwir23jrj1/SDIM1199.X3F?dl=0
When tried to open some repaired x3f, I saw the "template" image only. Other files still unreadable.
Template file: https://www.dropbox.com/s/25o8bxnu24e8f5a/SDIM1187.X3F?dl=0
Seems no way to get images back.
For me, SDIM1196.pctjr.00.X3F (repaired) displays different image than template (thumbnail and RAW are different from JPEG preview either). Sure it can be some other file content - looks like your files parts are mixed.
("r" in file name "pctjr" part means that raw data is taken from current file, not from template; this of course doesn't mean that it is properly readable. I reencode all data to ensure SPP will read it, but sometimes decoding/encoding may succeed with corrupted data too and then SPP may crash anyway. Analyzis result (low/medium/etc) is not very reliable - it doesn't decode data, it just searches for file sections.)
You could try different recovery programs first to recover image files from card. My utility can read data from sequently numbered files (while recovering entire folder), but for that files need NOT to be truncated to correct file length. Good recovery programs usually read file size from directory and cut their length; bad recovery programs may leave file size as multiple of SD card cluster size. For bad programs file names tend to be incorrect too - could be good sign for you
Sometimes you can get different results even with same software - if memory card has some internal instability, then different sessions may give different results. Put your SD card into freezer for an hour, then let it warm to room temperature (another hour to avoid condensation) and try again.
Arvo
Another file allows to save JPEG part - file name like SDIM1199.pctj_.00.X3F means that raw data is unreadable, but "j" (JPEG preview) is usable (and for this file it looks pretty good). You can check "Save JPG sections of corrupted images" in my utility, this way it saves JPG files along recovered files too.
Arvo
