25mm f1.7 comparison shots...disappointed
Started Dec 31, 2015 | Discussions
Big D in SP Regular Member • Posts: 436
5
I finally received the new Panasonic 25mm f1.7 lens yesterday afternoon.  Initial shots with it were disappointing, so today I compared shots with various lenses on both my G7 and G6.  At first, I wasn't sure the 25mm was focusing accurately since the images were visibly "unsharp"  So, this afternoon I did some careful comparisons.
Long story short, the lens is, simply, only worth the $49 price it cost during the Adorama Black Friday Sale.  The 14-42II kit zoom is sharper at 25mm at its widest available aperture than the 25mm stopped down to equivalent aperture.  The Sigma 30mm, which is nice and sharp, though nowhere near the equal of the 60mm, is significantly sharper than the 25mm.  I felt the lens would at least equal the Sigma.  It doesn't.
Following are some comparison shots which display the difference for anyone who may be interested.
Of course, quality of product can vary.  This may simply be a poor example, but it doesn't encourage me.  I'd send it back but for fact it came as a package with the G7 and 14-140, neither of which is going back!  They are both superb.  Unfortunately, this lens is not.
25mm @ f1.7
25mm @ f2.8
25mm @ f4
25mm @ f5.6
14-42II kit zoom wide open at 25mm @ f5.3
Sigma 30mm @ f4 (Lens is equally sharp w/o @ f2.8)
Have a Happy New Year, everyone!
Warren
Panasonic Lumix DMC-G6 Panasonic Lumix DMC-G7 Panasonic Lumix G 42.5mm F1.7 Panasonic Lumix G Macro 30mm F2.8
(unknown member) Senior Member • Posts: 1,015
Re: 25mm f1.7 comparison shots...disappointed
7
Not sure that using ISO 1600 represents the best procedure & results for testing sharpness. Try it again in good light, at base ISO. I've found mine to be quite good. As good as the 20 1.7 to my eye, maybe not quite as sharp in the extreme corners.
Also, how do yoy shoot at f/1.7 with the kit lens & the Sigma in low light?
wrxpat Forum Member • Posts: 63
I find mine to be quite sharp, I compared it to my PL25 and it held up quite favorably. Perhaps theres some QC issues going on...?
 wrxpat's gear list:wrxpat's gear list
Sony RX100 III Panasonic Lumix DMC-GH3 Olympus OM-D E-M10 Panasonic Lumix DMC-GX85 Panasonic Leica Summilux DG 25mm F1.4 +3 more
Ummmmmm..........no. The only thing he/she has tested, is the NR effectiveness of whatever software he/she is using. I wouldn't even dream of testing lens sharpness at ISO 1600, on my full frame camera -let alone m4/3
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
This is a problem with the shooter and not with the lens.  ISO1600?  Not the best for sharpness by any stretch.  Don't blame the lens, a copy of which I do not own nor have ever used, for that.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
Noku Dzu Regular Member • Posts: 307
Try it at a reasonable ISO - Re: 25mm f1.7 comparison shots...disappointed
before testing for the best sharpness you can get out of the lens/camera combo.  Certainly not ISO 1600.
 Noku Dzu's gear list:Noku Dzu's gear list
Canon G5 X II Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro +5 more
John King
John King Forum Pro • Posts: 14,941
Gidday Warren
Agree with others that ISO 1600 is hardly ideal for testing anything except ISO 1600 ...
There appear to be loads of sharpening/noise reduction/compression artifacts in all these shots too.
Perhaps check your camera settings?
I recently bought an Olympus 14-42 EZ pancake as a small, unobtrusive social photography lens. Its IQ is certainly not up to a high standard, but suits my intended purpose/s. Not exactly a replacement for my FTs 14-54 MkII .... .
Sorry you are disappointed.
Happy New Year to you and yours, mate.
Regards, john from Melbourne, Australia.
Please do not embed images from my web site without prior permission
I consider this to be a breach of my copyright.
The Camera doth not make the Man (nor Woman) ...
Perhaps being kind to cats, dogs & children does ...
Galleries: http://canopuscomputing.com.au/gallery2/v/main-page/
Bird Control Officers on active service.
 John King's gear list:John King's gear list
Olympus E-1 Olympus E-510 Olympus E-30 Olympus E-M1 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II +17 more
OP Big D in SP Regular Member • Posts: 436
speedync wrote:
I think you may be right. As I mentioned, mine may be a poor example.
Ummmmmmm.......no, they were shot JPG so the processing was in-camera and identical for each. Does 1600 ISO make a good lens bad or a poor lens better? Or different?I shot several hundred shots before deciding to do an identical test. By that time the sun was dropping so ISO went up. But, the results didn't change.
The 25/1.7 is not as sharp as either of the other lenses tested.
However, to please you, I'll duplicate this for you tomorrow at base ISO. I'll venture the difference will be even more apparent.
Warren
Tom Axford Forum Pro • Posts: 10,100
My 25/1.7 is equally disappointing compared to my other lenses. It is not a bad lens, just very mediocre, whereas many MFT lenses are very good indeed.
In its favour, I find the resolution drops off very little towards the edges of the frame - the IQ is much more uniform across the frame than almost all the other lenses I have (except perhaps the Sigma 60/2.8, which was designed to cover APS-C format sensors and gives very uniform quality across the MFT frame).
That's part of the problem. Shooting in jpeg is not really a good indication. Better off to shoot raw, then convert with the same settings in the same raw converter to be able to see the real differences.
ISO 1600 will be inherently noisy, knocking back the sharpness of any lens. Look at all the artifacts around the black text. No way you can make judgments with that as an example. Well, I couldn't anyway. If you're going to post examples to support your view, at least post some decent examples taken in good light at low ISO. We can't see all the shots you took earlier in the day. The whole point of an f/1.7 lens is to be able to open it up, & shoot 3 or 4 stops (roughly -I don't know exact apertures at all focal lengths) lower ISO than your kit lens. Which will make a huge difference as opposed to any tiny bit of sharpness you'll see pixel peeping anyway.
Warren
No need to please me. I got my 25 for free, (part of a bonus promotion) & the only thing I'm disappointed with, is that I paid $360 odd for the 20 f/1.7. Actually, I'm not. I'm just happy with an absolute bargain. Even at full price though, I'd still be satisfied with it. I've either got a very very poor 20, or a really really good 25. Or perhaps I have realistic expectations?
There is far more to a lens than just plain sharpness. Like I wrote earlier, how do you shoot your kit lens at f/1.7 in low light? How do they render contrast & colour? Isolate your subject? No doubt there are sharper lenses out there, but that doesn't automatically make the 25 cheap rubbish.
I'm not picking on you, just giving a bit of perspective is all.
Loga Senior Member • Posts: 1,981
I'd worry rather...
about the not really good in-camera NR of the G7. What it did to the fine details is really awful. As for sharpness, I don't see any problems with this lens - in the centre of the picture. Quite above my acceptance level of sharpness.
However, it is a $99 lens as you mentioned, so I would not expect $5000 Leica lens sharpness. Instead, I would do some really interesting picture with it (at base ISO), and would enjoy the 50mm equivalent fix perspective. Try it on street, make it black&white, and be the new Henri Cartier-Bresson
 Loga's gear list:Loga's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 +6 more
Astrotripper Veteran Member • Posts: 8,676
How does that make any sense? Are you saying that the camera deliberately smudges only images from this particular lens?
Based on the samples OP showed us, we can blame the lens by all means. A lens I also own and use, and I can confirm that it's not really as sharp as one would expect a prime to be. I don't think mine is as bad compared to kit zoom, though. I've yet to do more in-depth testing.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
I can't see the differences
But then, I can't download those full frame files. how about posting a 100% crop or three after you have done a somewhat more valid test. Base ISO, brighter light (with a bit of contrast in it).
I like the test subject, actually, but it needs to have cross lighting on it.
The 14-42 II is a very, very good lens, by the way.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
MatsP
MatsP Senior Member • Posts: 2,629
Thank you...
..now I know I don't need that lens. It's definitely cheap, but a cheap lens that doesn't deliver is just disappointing. Like the Sigma 19/2.8 was to me to take another example.
 MatsP's gear list:MatsP's gear list
Canon EOS RP Canon EF 50mm F1.4 USM Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM Canon RF 24-105mm F4.0-7.1 IS STM
Re: Thank you...
Yeah, it's terrible. Lol. Without looking at the exif (can't be bothered removing it) you tell me which is which. Both shots taken at f/1.7 in testing conditions, hard on contrast, which shows up a "poor" lens, converted from raw with the same settings in LR.
And again. With the subject on the border of the frame, where a "bad" lens will show differences
Time to stop shooting test charts boys, & get out into the real world
Ulfric M Douglas Veteran Member • Posts: 4,828
I disagree, whenever I am testing lens-v-lens-sharpness I use in-camera Jpegs with a very low sharpness (varies with camera) so that there can be no inadvertant/hidden messing by a chosen RAW-converter depending on the lens. One less step to reduce error.
The camera willl produce Jpegs which are processed the same (plus auto lens correction, but that is known) and the sharpness differences will be apparent.
Cheksa wrote:
You're evil Ulfric.
(unknown member) Veteran Member • Posts: 6,192
Re: I'd worry rather...
It is not a $99 lens except in very local situations. You can see why Panasonic pulled this pricing stunt if people talk about it as such and excuse problems against this price.
Even at £150 it is very affordable so you can excuse some things but to talk about it as a $99 lens is absurd.
MatsP
Re: Thank you...
It was real world shooting that made me disappointed with the 19/2.8. Of the four pics from you the two in the middle are sharpest to my eyes, looking at my phone. Can't see exit.
Re: Thank you...
It delivers f1.7 which my other lenses do not. I think the sharpness thing rather misses the point of a fast lens avoiding high ISO's which lead to smudging and worst of all colour contrast loss. Of course if you can afford a more expensive lens it may perform better but that hardly needs discussion.
Re: Thank you...
Lol. You're trying to tell me you can see a difference in sharpness on your phone, with images compressed to the size of a postage stamp? Pull the other one
