What lens cap do I need for Samsung NX2000, 30mm f2.0 pancake lens?
Started Dec 29, 2015 | Questions
shiaoyentz43 New Member • Posts: 2
I lost my lens cap for the Samsung 30mm f/2.0 lens, mounted on my Nikon NX2000. Can anyone tell me what lens cap I need to get as replacement? Can't tell if it should be 40.5mm or 43mm.
thank you!
Panasonic Lumix G Macro 30mm F2.8 Samsung NX2000
TillmanB
TillmanB Contributing Member • Posts: 501
Re: What lens cap do I need for Samsung NX2000, 30mm f2.0 pancake lens?
Should be a 43mm, from what I gather any ol' 43mm will do the job, however if you're after the exact Samsung part try this.
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-AD97-18381A.aspx?model=EV-NX300ZBXVUS
OP shiaoyentz43 New Member • Posts: 2
Thank you so much!
laspinne New Member • Posts: 1
What lens cap do I need for Samsung NX1000, 50-200mm zoom lens?
Does anyone know what cap would fit the 50-200 iFunction lens? The diameter is 52mm, would any 52mm lens cap fit the lens? I guess I should look into one that can be attached to the camera somehow, 'cause I keep losing these...
Kisaha Senior Member • Posts: 2,300
Re: What lens cap do I need for Samsung NX1000, 50-200mm zoom lens?
Yes, there must be some with a little cord, I have one for a bigger diameter (77), but I am not sure about smaller ones. You can buy cheap from ebay, just check if the mechanism suits you (there are simpler designs for dead cheap, they work just fine).
