20mm f1.7 vs 40mm 2.8 vs. 75mm f1.8 DOF/Bokeh/Perspective Comparisons
Started Dec 28, 2015 | Discussions
AngelicBeaver Contributing Member • Posts: 804
Panasonic 20mm f1.7 pancake @ f1.7:
Olympus 12-40mm f2.8 @ 40mm f2.8:
Olympus 75mm f1.8 @ f1.8
I thought these might be of interest to people trying to see the different levels of background blur for different focal lengths.  I did this by myself, so the framing was a bit rough, and the sun went down for the 20mm shots, but I found them useful.
Here are some less scientific examples, but also useful for DOF and blur analysis (all shots wide open) for the Olympus 75mm f1.8 and the Panasonic Leica 25mm f1.4:
75mm f1.8:
No. The 75 f1.8 cannot blur out distracting backgrounds.
25mm f1.4:
I thought someone might find these helpful for the always confusing lens selection process.
 AngelicBeaver's gear list:AngelicBeaver's gear list
Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Panasonic Leica 100-400mm F4.0-6.3 ASPH
(unknown member) Veteran Member • Posts: 3,010
Re: 20mm f1.7 vs 40mm 2.8 vs. 75mm f1.8 DOF/Bokeh/Perspective Comparisons
There are depth of field charts that give an accurate measure of the various lenses.
OP AngelicBeaver Contributing Member • Posts: 804
Thanks for adding the link.  That definitely adds to the topic, but there's also a big difference between a chart and a photo, and combining that with the compression effects of various lenses makes it even harder to visualize.
I jut wish I had the Panasonic/Leica 42.5 and the Oly 45 1.8 for the comparison shot. I need to do one for the 25.  If anyone has similar full body/ lens wide open kind of shots with either of those lenses, I;d be grateful if you'd post them on this thread.
I have no signature.
EarthQuake Veteran Member • Posts: 3,240
Thanks for putting in the effort to post these, photos are certainly a lot more helpful than charts. If you're interested in how blurry the background will be, DOF charts are borderline useless anyway (they only show how much is in focus, not the extent to which the background will appear blurred).
I really cool site for calculating background blur is: http://www.howmuchblur.com
Tony8232 wrote:
Here is a comparison.
http://www.cameralabs.com/reviews/Panasonic_Leica_DG_Nocticron_42-5mm_f1-2_H-NS043E/bokeh_comparison.shtml
Thanks again.  I'd seen these too, and that's part of my frustration.  Whenever people show off the blurring capabilities of their lenses, they tend to take pictures of small, inanimate objects from close up.  This guy took pictures of beer apparatus.  I want pictures of people from common working distances.  That's why I made my test shots.  They show what each lens is capable of from a set framing point.
I think that people buy lenses based on pictures of beer apparatus, and then are frustrated when they think their lens is going to deliver that creamy, out-of-focus background when they are taking group portraits, particularly with the wider angle, fast aperture lenses.
averagejoe576 Regular Member • Posts: 498
I am in your exact shoes, thanks for the pics.
One thing helpful to people researching, took me a minute to get this as well, you and I are interested in "shallow DoF" more so than Bokeh, the former being how easy it is to get backround blur, and the latter being how the blur looks *if*/when you can get it. I do want it to look good if I get it (e.g. good bokeh), but the main struggle is just to get human subject + background blur at all.
So if you search '[lensName] bokeh' its correct to expect to see the macro object shots, since they show the bokeh the best. I think the reason serious reviews don't do many shallow dof examples is they expect enthusiasts to know this behavior simply from the aperture, wheres bokeh varies from lens to lens.
Another thing that took me a while to get, is that long lenses are only "sort of" better for shallow DoF for the same subject composition. There is less background due to perspective, so decreases the chance of having unwanted background, and the background is zoomed in so the blur is more apparent, but *same* level of actual detail loss. Also subjectively better for portraits due to distortion, but I personally have several portrait keepers shot at effective 24. I definitely wont be forgoing the usefulness of a more verstile faster prime (the 25mm 1.4) for the supposed portrait benefits of ~80mm. May have both one day but its really far down the list
While I have only tried 2.8 so far (the pany 12-35mm), I've found that if I just do a head, maybe a collarbone, and background is 20yrds + I can get moderate bokeh wide open. Plan to get the 25mm 1.4 soon and, as you have shown in the last photo, expect reasonable blur capabilities for head + upper body shots but probably not full body.
 averagejoe576's gear list:averagejoe576's gear list
Fujifilm X100T Panasonic LX100 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
brianric Veteran Member • Posts: 8,980
Will this place help.
http://dofsimulator.net/en/
 brianric's gear list:brianric's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX8 Sony a6400 Sony a9 II +6 more
That's something they are going to have to learn the hard way I guess. On wide angled lenses the aperture would have to be huge using m43 lenses. There is always software. On group shots to blur the background effectively there is a risk of blurring the subjects unless they are all in the same horizontal plane. Separating the subjects further the from background would make the effect greater. For example the young man standing by the bushes. The background is too close to the model.
bluevellet Veteran Member • Posts: 4,172
I think those charts have their uses for online debates and theoritical differences but they often don't really give a real idea of what an image will look like in the end. The various sensor crops make things muddier.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
Panasonic/Leica 25mm f1.4 added to comparison 20 vs 25 vs 40 vs 75
25mm f1.4 @ f1.4 (taken today):
75mm f1.8:
25mm f1.4:
I just grabbed a couple of shots with the 25mm f1.4 and added them to the straight comparison series.
The difference between the zoom and the better primes can be staggering. The Leica 25mm and especially the 75mm really shine here.
One of the common criticisms of the 12-40 is that even at f2.8, the bokeh can be "distant" and it's plain to see in your photos. Though bringing the subject closer to the lens will help.
I was really surprised by the difference between the 20mm and the 25mm.  I expected a bit more blur in the background, but the little bit of extra speed and 5mm really seems to make a difference.  I wonder if the less sharp edges of the 25mm are enhancing the effect.
Serhan2 Senior Member • Posts: 1,473
Hopefully these will help...
PL 42.5 1.2
Panasonic 42.5 1.7
Those are great examples.  Thanks.
