My brain hurts - Yongnuo flash choices!
Started Dec 26, 2015 | Discussions
rxb dc Senior Member • Posts: 2,104
Re: My brain hurts - Yongnuo flash choices!
lynnG wrote:
rxb dc wrote:
Yongnuo now have the yn685 which has a built in radio receiver. I would recommend that over the the 5xx because you need one less piece of equipment i.e. the 622c.
For the transmitter, I would definitely suggest 622c-tx ii. The lcd and dedicated controls make life so much easier.
Safety Warning: Bad taste unmitigated by moderate skill
I never heard 622c-tx ii? Is this a new release from Yongnuo? I hope that they could have a new version of 622c-tx to make my EOS M3 work. The current one is hopeless for EOS M3 even with their latest firmware.
Not sure about what the version ii brings to the table or if it works with the M3.
I would have thought that the basic 622-tx would work with that camera since it takes regular Canon flashes but I suppose one can never tell.
One thing I would recommend is to get E-TTL and HSS if you can afford it - gives you many more options.
 rxb dc's gear list:rxb dc's gear list
Canon EOS 700D Canon EOS 7D Mark II Canon EF 50mm F1.8 II Tamron SP 150-600mm F5-6.3 Di VC USD Canon EF-S 10-18mm F4.5–5.6 IS STM +9 more
PhotoKhan Forum Pro • Posts: 11,932
I can't find a II version anywhere.
I believe it was originally mentioned as a result of a confusion, as the system Yongnuo naming convention is quite confusing.
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
http://www.humbertoborgesfotografia.com/
http://www.pbase.com/photokhan
(PBase Supporter)
PK...
My bad - the 622c has a ii version but not the tx.
Domingochevaz New Member • Posts: 1
I need help ..I got a canon 800d and need a flash that will work off camera ,is the YN568ex11 gonna do that ?
I would recommend Adorama Flashpoint as they have a very comprehensive system, and the quality is quite high.
yongnuo quality and reliability leaves a bit to be desired.  I ended up seeking my Yongnuo units and going all in on Flashpoint.
https://500px.com/rbhardvaj
https://www.instagram.com/rxbdc/
Disclaimer: I reserve the right to take bad photographs with any camera, irregardless of DXOmark scores.
