No, those "Inch" designations have very little to do with the sensor dimensions. They are related to the size of the glass envelope that contains the sensor in TV applications.So is it the height that is shown by 1 inch, four thirds, 35 mm, 1/2.3 and 1/1.2?
For no good reason at all, manufacturers have standardized on an archaic engineering standard carried over from the early days of picture tubes. It's explained on this DPR page.35 mm, 1 inch, four thirds, 1/2.3, 1/1.2....... .. Are they the diagonal lengths of the sensors?
Here is a link to sensor size and the relative crop factors:35 mm, 1 inch, four thirds, 1/2.3, 1/1.2....... .. Are they the diagonal lengths of the sensors?
And many don't think that. The terminology has developed organically, with different usages following in succession. Each of those usages had a good reason for coming into use. As soon as the second came along the first was (by the simple logic of wanting everything the same) outdated and redundant, so the first should have been superseded by the second.Welcome to the confusing world of sensor sizes! Many of us think the marketing socket-heads at the various camera companies do this on purpose to confuse customers. "A confused customer is an easy mark!"
On the other hand, the diagonal is an easy way to compare the relative sizes of different sensors. There are, of course, cameras with different aspect ratios and it's useful to know. Consider my Pentax Q with sensor 6.17 x 4.55 mm. I know it's 4:3, of course, but it's not immediately apparent from the stated dimensions. If we are to go to a new system I'd much prefer 7.6mm (4:3) as a description.You will run into many different terms:
There is only one way to properly describe the size of a rectangular object: Give the two dimensions, the X and Y values. A diagonal dimension also requires the aspect ratio; this is too complicated for many people to understand.
- 35mm
- FF
- Crop-sensor
- 1/3.75"
- MF
- FX and DX
- APS-C
- APS-H
In fact it's not so much that the sizes were different but that two systems were used to name them.For MANY years, we did rather well. All camera sizes were things like 8" x 10", 4" x 5", 2.25" x 3.25", 2.25" x 2.25", etc. There were also metric sizes, like 6 x 7 cm.
Not really. It's true that the 3:2 35mm film format was devised by using twice the number of perforations for a horizontally run film as was used (in a different medium) for vertically run film. But 35mm stills framing was never really linked to 35mm cine framing.Then we started naming the sizes for the "container" that held the image; like 8mm, 16mm, 35mm, and 50mm film used in movie cameras. And when video cameras first appeared, we "sized" the Vidicon tubes used in them by stating the outer diameter of the glass envelope [which was larger and pretty much unrelated to the size of the photo-sensitive scanned area]. That VERY confusing scheme was used when we invented Silicon sensors for video cameras.
When 35mm film [used in movie cameras] was "borrowed" to use in still cameras, the inventor, Oskar Barnack, turned the film sideways and sorta doubled the frame size to the 24 x 36mm size we still use today and call "Full-Frame" or "FF". BUT it is really a double frame if you understand the history.
And, for many people, X and Y will be confusing.Until we can get EVERYONE to simply use the X and Y dimensions of the sensors we have in our cameras, it will eternally be confusing.
35mm film is 35mm wide. For stills, it is also known as 135 film. Most 135 film cameras expose a frame of 24 x 36mm, but there were also 24 x 24mm and 18 x 24mm frame cameras.Just to make it thoroughly confusing, what we call 35mm film size has a frame that is 24mmx36mm.
You imply that there are only two possibilities: Naive and paranoid. I prefer "insightful".And many don't think that. The terminology has developed organically, with different usages following in succession. Each of those usages had a good reason for coming into use. As soon as the second came along the first was (by the simple logic of wanting everything the same) outdated and redundant, so the first should have been superseded by the second.Welcome to the confusing world of sensor sizes! Many of us think the marketing socket-heads at the various camera companies do this on purpose to confuse customers. "A confused customer is an easy mark!"
But then the third was different so the renamed first (to match second) and second ones should have been superseded by the third. And so on ... Think of the sweat of renaming everything that had gone before; and that wouldn't have reduced confusion because everything made earlier would still have its original label so we'd still need to understand all the terms anyway.
Trying to blame all this on the makers is naïve and/or paranoid.
With HS math, any kid can find the aspect ratio [just divide X by Y]. Of course that gives numbers like 1.333 or 1.5. With a college degree, we know how to get 4:3 or 3:2. ;-)On the other hand, the diagonal is an easy way to compare the relative sizes of different sensors. There are, of course, cameras with different aspect ratios and it's useful to know. Consider my Pentax Q with sensor 6.17 x 4.55 mm. I know it's 4:3, of course, but it's not immediately apparent from the stated dimensions. If we are to go to a new system I'd much prefer 7.6mm (4:3) as a description.You will run into many different terms:
- 35mm
- FF
- Crop-sensor
- 1/3.75"
- MF
- FX and DX
- APS-C
- APS-H
Huh? What two systems? The list above your remark uses only one system!In fact it's not so much that the sizes were different but that two systems were used to name them.For MANY years, we did rather well. All camera sizes were things like 8" x 10", 4" x 5", 2.25" x 3.25", 2.25" x 2.25", etc. There were also metric sizes, like 6 x 7 cm.
There were a few still cameras that took a "half-frame" image on 135 film, mostly in the 1960's. They had a 24 x 18mm format.Not really. It's true that the 3:2 35mm film format was devised by using twice the number of perforations for a horizontally run film as was used (in a different medium) for vertically run film. But 35mm stills framing was never really linked to 35mm cine framing.Then we started naming the sizes for the "container" that held the image; like 8mm, 16mm, 35mm, and 50mm film used in movie cameras. And when video cameras first appeared, we "sized" the Vidicon tubes used in them by stating the outer diameter of the glass envelope [which was larger and pretty much unrelated to the size of the photo-sensitive scanned area]. That VERY confusing scheme was used when we invented Silicon sensors for video cameras.
Simple but confusing.The origin of FF as presently used comes from the fact that early digital sensors were so expensive that the ones used in DSLRs were smaller than the 36x24mm frame of SLRs. Even the users who understood the reason still would have preferred to use the lenses they already owned (and which gave different results on their DSLRs) to display the full frame size they had been made for. Describing DSLRs as "full frame" is no more than a way of telling customers that they can use their lenses to display the full frame size they had been made for.
No more confusing that a 4' x 8' sheet of plywood or 2x4 lumber! You want to have customers go to Home Depot and ask for a sheet of 8.944 foot plywood? ;-)And, for many people, X and Y will be confusing.Until we can get EVERYONE to simply use the X and Y dimensions of the sensors we have in our cameras, it will eternally be confusing.
And this is not confusing?And, for many people, X and Y will be confusing.There is only one way to properly describe the size of a rectangular object: Give the two dimensions, the X and Y values. A diagonal dimension also requires the aspect ratio; this is too complicated for many people to understand.
I didn't say it wasn't; that's a straw man argument.And this is not confusing?And, for many people, X and Y will be confusing.There is only one way to properly describe the size of a rectangular object: Give the two dimensions, the X and Y values. A diagonal dimension also requires the aspect ratio; this is too complicated for many people to understand.
The Fujifilm X20 has a 2/3-inch (8.8mm by 6.6mm) sensor while the Canon G1 X has a 1.5-inch sensor (18.7mm by 14mm).
No, I didn't imply it - I said it. You may prefer insightful but that preference doesn't make it right.You imply that there are only two possibilities: Naive and paranoid. I prefer "insightful".And many don't think that. The terminology has developed organically, with different usages following in succession. Each of those usages had a good reason for coming into use. As soon as the second came along the first was (by the simple logic of wanting everything the same) outdated and redundant, so the first should have been superseded by the second.Welcome to the confusing world of sensor sizes! Many of us think the marketing socket-heads at the various camera companies do this on purpose to confuse customers. "A confused customer is an easy mark!"
Of course. But dividing 6.17 by 4.55 is quite a lengthy process to do accurately and mentally.With HS math, any kid can find the aspect ratio [just divide X by Y]. Of course that gives numbers like 1.333 or 1.5. With a college degree, we know how to get 4:3 or 3:2. ;-)On the other hand, the diagonal is an easy way to compare the relative sizes of different sensors. There are, of course, cameras with different aspect ratios and it's useful to know. Consider my Pentax Q with sensor 6.17 x 4.55 mm. I know it's 4:3, of course, but it's not immediately apparent from the stated dimensions. If we are to go to a new system I'd much prefer 7.6mm (4:3) as a description.You will run into many different terms:
- 35mm
- FF
- Crop-sensor
- 1/3.75"
- MF
- FX and DX
- APS-C
- APS-H
I don't need to find the diagonal: we are discussing a naming convention so I'll be told the diagonal.Finding the diagonal definitely takes a PHD. The diagonal is the square-root of X-squared plus Y-squared.
Why is it better? Why do I need to know the sides of a sensor? If we are talking about ease of comparing sensor sizes one dimension is easier than two. For image circle purposes (comparative focal lengths) it's the diagonal that matters. It's much easier to compare 43mm (3:2) to 7.6mm (4:3) than it is to compare 36x24mm to 6.17x4.55mm.7.6mm (4:3) is OK, but 6.17 x 4.55mm is better. Why hide the REAL dimensions? If you give 7.6mm (4:3) to an average person, they will be unable to figure out the ACTUAL dimensions of the rectangle!
Inch system and metric system.Huh? What two systems? The list above your remark uses only one system!In fact it's not so much that the sizes were different but that two systems were used to name them.For MANY years, we did rather well. All camera sizes were things like 8" x 10", 4" x 5", 2.25" x 3.25", 2.25" x 2.25", etc. There were also metric sizes, like 6 x 7 cm.
I'm familiar with the Wiki article. I can't see what any of that has to do with my paragraph above it.There were a few still cameras that took a "half-frame" image on 135 film, mostly in the 1960's. They had a 24 x 18mm format.Not really. It's true that the 3:2 35mm film format was devised by using twice the number of perforations for a horizontally run film as was used (in a different medium) for vertically run film. But 35mm stills framing was never really linked to 35mm cine framing.Then we started naming the sizes for the "container" that held the image; like 8mm, 16mm, 35mm, and 50mm film used in movie cameras. And when video cameras first appeared, we "sized" the Vidicon tubes used in them by stating the outer diameter of the glass envelope [which was larger and pretty much unrelated to the size of the photo-sensitive scanned area]. That VERY confusing scheme was used when we invented Silicon sensors for video cameras.
You might want to read: https://en.wikipedia.org/wiki/35_mm_film#Common_formats
It describes the many different 35mm film formats. They varied from 24.89 x 18.67 mm to 20.32 x 15.24mm to 21.84 x 20.83mm. They danced around the 22 x 16mm format.
In what was is it confusing?Simple but confusing.The origin of FF as presently used comes from the fact that early digital sensors were so expensive that the ones used in DSLRs were smaller than the 36x24mm frame of SLRs. Even the users who understood the reason still would have preferred to use the lenses they already owned (and which gave different results on their DSLRs) to display the full frame size they had been made for. Describing DSLRs as "full frame" is no more than a way of telling customers that they can use their lenses to display the full frame size they had been made for.
Well, you've hit the nail on the head. For large things like sheets of ply simple, round numbers are adopted for convenience. Ditto for the old 5x4" etc film/plate sizes.No more confusing that a 4' x 8' sheet of plywood or 2x4 lumber! You want to have customers go to Home Depot and ask for a sheet of 8.944 foot plywood? ;-)And, for many people, X and Y will be confusing.Until we can get EVERYONE to simply use the X and Y dimensions of the sensors we have in our cameras, it will eternally be confusing.
Yes, that is confusing, but it is not what either Gerry or I suggest.And this is not confusing?And, for many people, X and Y will be confusing.There is only one way to properly describe the size of a rectangular object: Give the two dimensions, the X and Y values. A diagonal dimension also requires the aspect ratio; this is too complicated for many people to understand.
I was simply pointing out that the "Inch" designations are completely unhelpful unless you are in the know.Yes, that is confusing, but it is not what either Gerry or I suggest.And this is not confusing?And, for many people, X and Y will be confusing.There is only one way to properly describe the size of a rectangular object: Give the two dimensions, the X and Y values. A diagonal dimension also requires the aspect ratio; this is too complicated for many people to understand.
I would rewrite it thusly:
The Fujifilm X20 has a 8.8mm by 6.6mm sensor while the Canon G1 X has a 18.7mm by 14mm sensor.
We are in agreement.I was simply pointing out that the "Inch" designations are completely unhelpful unless you are in the know.Yes, that is confusing, but it is not what either Gerry or I suggest.And this is not confusing?And, for many people, X and Y will be confusing.There is only one way to properly describe the size of a rectangular object: Give the two dimensions, the X and Y values. A diagonal dimension also requires the aspect ratio; this is too complicated for many people to understand.
Since we are all familiar with the pixel numbers such as 6000x4000, it's only logical to stick to actual sensor dimensions.
I think the diagonal is of academic interest only. It does not inform about anything useful, IMO.Diagonal dimensions are only of interest if you want to refer to the diameter of the image circle, perhaps as a way of normalising for different aspect ratios.
I know that we call it the Metric System. There are "systems" other than units. For example a system of referencing the size of a rectangular object by stating it's X and Y dimensions. In THAT sense, the above uses ONE system.No, I didn't imply it - I said it. You may prefer insightful but that preference doesn't make it right.You imply that there are only two possibilities: Naive and paranoid. I prefer "insightful".And many don't think that. The terminology has developed organically, with different usages following in succession. Each of those usages had a good reason for coming into use. As soon as the second came along the first was (by the simple logic of wanting everything the same) outdated and redundant, so the first should have been superseded by the second.Welcome to the confusing world of sensor sizes! Many of us think the marketing socket-heads at the various camera companies do this on purpose to confuse customers. "A confused customer is an easy mark!"
- 35mm
- FF
- Crop-sensor
- 1/3.75"
- MF
- FX and DX
- APS-C
- APS-H
You said, "But 35mm stills framing was never really linked to 35mm cine framing." That is because there was never ONE cine framing to use as a reference. That is precisely why I said Oskar "sorta" doubled the frame size. :-0I'm familiar with the Wiki article. I can't see what any of that has to do with my paragraph above it.There were a few still cameras that took a "half-frame" image on 135 film, mostly in the 1960's. They had a 24 x 18mm format.Not really. It's true that the 3:2 35mm film format was devised by using twice the number of perforations for a horizontally run film as was used (in a different medium) for vertically run film. But 35mm stills framing was never really linked to 35mm cine framing.Then we started naming the sizes for the "container" that held the image; like 8mm, 16mm, 35mm, and 50mm film used in movie cameras. And when video cameras first appeared, we "sized" the Vidicon tubes used in them by stating the outer diameter of the glass envelope [which was larger and pretty much unrelated to the size of the photo-sensitive scanned area]. That VERY confusing scheme was used when we invented Silicon sensors for video cameras.
I think "FF" mostly refers to the sensor, not the lens. I simply got confused when I read that paragraph; therefore, it must be confusing. ;-)In what was is it confusing?Simple but confusing.The origin of FF as presently used comes from the fact that early digital sensors were so expensive that the ones used in DSLRs were smaller than the 36x24mm frame of SLRs. Even the users who understood the reason still would have preferred to use the lenses they already owned (and which gave different results on their DSLRs) to display the full frame size they had been made for. Describing DSLRs as "full frame" is no more than a way of telling customers that they can use their lenses to display the full frame size they had been made for.
I never suggested how many decimal places should be used. It's OK to do some rounding for the masses. Like a 2x4 is not actually 2" x 4"; it's 1.5" x 3.5". Everyone knows that after the first time they buy one and measure it!Well, you've hit the nail on the head. For large things like sheets of ply simple, round numbers are adopted for convenience. Ditto for the old 5x4" etc film/plate sizes.No more confusing that a 4' x 8' sheet of plywood or 2x4 lumber! You want to have customers go to Home Depot and ask for a sheet of 8.944 foot plywood? ;-)And, for many people, X and Y will be confusing.Until we can get EVERYONE to simply use the X and Y dimensions of the sensors we have in our cameras, it will eternally be confusing.
But when we get into decimal fractions (especially with two or more places) it's not so easy.
This may have to do with education. People my age don't have difficulty dividing 6.17 by 4.55 and getting 1.333...then writing that as 1 + 1/3 and then simplifying it to 4/3. You may not have gotten as good an education as we did? ;-)Your 8.944' is comparable in that way to 6.17mm and that's why I don't like your suggestion for sensor sizes.
Similarly, it's easy to see a 4x8' has an aspect ratio of 2; fairly easy to see that 36x24mm is 3:2; downright obscure that 6.17x4.55mm is 4:3.
You used inches and cm. Those units are part of what are commonly called "inch" (or "Imperial") and "metric" systems. While there are plenty of other systems and naming conventions you used only those two, and those are the two I identified in my reply ...I know that we call it the Metric System. There are "systems" other than units. For example a system of referencing the size of a rectangular object by stating it's X and Y dimensions. In THAT sense, the above uses ONE system.Inch system and metric system.Huh? What two systems? The list above your remark uses only one system!In fact it's not so much that the sizes were different but that two systems were used to name them.For MANY years, we did rather well. All camera sizes were things like 8" x 10", 4" x 5", 2.25" x 3.25", 2.25" x 2.25", etc. There were also metric sizes, like 6 x 7 cm.
... so I can't imagine why you'd bring this into the discussion of that paragraph.If you were referring to the strange "system" of describing the sensor by reference to the outer diameter of a mythical, nonexistent glass vacuum tube ...
Of course it does, and that's what I said: a FF sensor allows people to use lenses the way the lenses were intended rather than with restricted FOV.I think "FF" mostly refers to the sensor, not the lens.In what was is it confusing?Simple but confusing.The origin of FF as presently used comes from the fact that early digital sensors were so expensive that the ones used in DSLRs were smaller than the 36x24mm frame of SLRs. Even the users who understood the reason still would have preferred to use the lenses they already owned (and which gave different results on their DSLRs) to display the full frame size they had been made for. Describing DSLRs as "full frame" is no more than a way of telling customers that they can use their lenses to display the full frame size they had been made for.
How is writing something to three places of decimals not sugestive of that?I never suggested how many decimal places should be used.Well, you've hit the nail on the head. For large things like sheets of ply simple, round numbers are adopted for convenience. Ditto for the old 5x4" etc film/plate sizes.No more confusing that a 4' x 8' sheet of plywood or 2x4 lumber! You want to have customers go to Home Depot and ask for a sheet of 8.944 foot plywood? ;-)And, for many people, X and Y will be confusing.Until we can get EVERYONE to simply use the X and Y dimensions of the sensors we have in our cameras, it will eternally be confusing.
Please escribe the full process you'd use, step by step.It's OK to do some rounding for the masses. Like a 2x4 is not actually 2" x 4"; it's 1.5" x 3.5". Everyone knows that after the first time they buy one and measure it!
This may have to do with education. People my age don't have difficulty dividing 6.17 by 4.55 and getting 1.333...then writing that as 1 + 1/3 and then simplifying it to 4/3.Your 8.944' is comparable in that way to 6.17mm and that's why I don't like your suggestion for sensor sizes.
Probably better, as the answer isn't actually 1.333... but 1.35604...You may not have gotten as good an education as we did? ;-)
