XTi pop-up flash ... sometimes it works, sometimes it doesn't?
Started Dec 25, 2015 | Discussions
MrsKJr New Member • Posts: 1
Hi all and Merry Christmas for those who celebrate!
I've got a 9-year-old XTi (got it for Xmas 9 years ago today in fact) and today the pop-up flash decided to go on the fritz. It will pop up, no problem. Sometimes it will fire and sometimes it won't. Usually the first attempt to use it after turning the camera on will work. Sometimes it fires full-force (brightness) and other times it fires with a much lesser strength. I've tested in auto mode and in manual modes. No real difference.
Is my strobe just dying a slow death given its age?
Any thoughts? Thanks in advance for any insight!
Camperman New Member • Posts: 6
Re: XTi pop-up flash ... sometimes it works, sometimes it doesn't?
Make sure that it is actually "popping" open fully. I've had that problem in the past and it was because the flash didn't open fully.
photonius Veteran Member • Posts: 6,895
may also be batteries, flash needs recharging.
as to strength of flash, if the exposure is right, nothing wrong. or perhaps it's doing pre-focus flash?
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
Digirame Forum Pro • Posts: 41,857
It might be normal. I'm not saying it is normal, but it might be normal. It might be because of the flash recycle time. You can read about it on the internet. It happens to me also with all of my cameras. I was told that if the ISO level is higher than the issue is not as much, so I usually take pictures with my on-body flash at ISO400. That may be because it doesn't have to use as much energy at higher ISO levels (that's my guess). I know I can use the on-body flash about two or three times. Then I have to wait a few more minutes. It's all good as long as I remember to not keep pushing the shutter button continually and I allow for some time in between snaps.
A little edit: I'm not familiar with your camera as the ones I have are the Canon T2i (550D) and Canon T3i (600D).  I believe that an off-body external flash would be better.  I don't know a whole lot about those either, as I don't take a lot of flash pictures.  But if I got more serious about it, I think that's the way to go.  It sounds like you are ready to upgrade also, with a camera that is that old.  I keep thinking of upgrading also, but the 18mp cameras that I have seem to be sufficient for my outdoor activities.
