Does a zoom lense always need tripod ?
Started Dec 24, 2015 | Questions
Digirame Forum Pro • Posts: 41,857
Re: Does a zoom lense always need tripod ?
Here's another 600mm focal length picture that I took this past Monday at 1/60th of a second when I dropped the ISO level to 800 on a dark cloudy day. I was able to brace the camera and lens and the bird stayed still. I thought about using ISO400 afterwards, to see whether I could do it at about 1/30th of a second. It's a challenge sometimes to get the most out of our gear without a tripod. This is an extreme example but I thought I would show you or anyone else that's interested. When I was using my older Olympus DSLR system I was mostly limited to ISO800 (for usable pictures) so I had to try techniques to be successful on days with little light. The more modern DSLR cameras that allow us to use ISO1600 and higher make this a whole lot easier to keep the shutter speed higher and still retain enough depth of field with the chosen aperture.
Even though all of my wildlife photos are now taken with the Tamron 150-600mm lens, I found that the Canon 55-250mm IS lens to be adequate if the photographer had patience. It was a matter of letting the birds have trust in you and then they would come closer or allow you to be closer if you walked extremely slow step by step. I took pictures that way for about three years. The smaller Canon 55-250mm IS lens that I used in the sample below was also easier to take pictures in the rain under an umbrella (without a tripod).
Evil Nemesis
OP Evil Nemesis Forum Member • Posts: 90
Re: LOL
@scottcraig
@Shifter
Here are some shots using the new lens
Captured in T.V mod mostly.
http://imgur.com/a/k6MST
-The Nemesis-
 Evil Nemesis's gear list:Evil Nemesis's gear list
Canon EOS 1100D Canon EF-S 18-55mm f/3.5-5.6 Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM
kreygscott
kreygscott Senior Member • Posts: 1,285
Re: LOL
Evil Nemesis wrote:
@scottcraig
@Shifter
Aha someone who plays cricket. Pictures are not bad but next time try to get in a bit tighter on the shots.
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
Evil Nemesis
Re: LOL
Thanks, agree about what you said but as it was my first time in open with the camera I was a bit shy.
-The Nemesis-
kreygscott
Re: LOL
That's okay. Keep practicing and you'll soon get the hang of it.
Shifter Veteran Member • Posts: 5,076
Re: LOL... Batter up!
Some are pretty good. Some not. If you got tighter in with less background, they could be great. Did you use a tripod?
The lens you used seems very good.
 Shifter's gear list:Shifter's gear list
Canon EOS 7D Canon EOS 5D Mark IV Sigma 50-500mm F4.5-6.3 DG OS HSM Canon EF 24-70mm F2.8L II USM Sigma 18-200mm f/3.5-6.3 II DC OS HSM +1 more
Evil Nemesis
Thanks for commenting mate, nops I didn't use a tripod and to be honest with you all shots were taken from the same place and the one wide shot was taken to just check the focal length.
-The Nemesis-
Clive50
Clive50 Contributing Member • Posts: 693
I started off 2 years ago on the same camera and lens and my 1st shot that I really liked was this guy. So your on to a good start. You seem to have captured the movement fine.
 Clive50's gear list:Clive50's gear list
Canon EOS 600D Canon EOS 80D Canon EF 50mm F1.8 II Tamron AF 18-200mm F/3.5-6.3 XR Di II LD Aspherical (IF) Macro Tamron SP 150-600mm F5-6.3 Di VC USD +5 more
MyPupEllie
MyPupEllie Junior Member • Posts: 35
Dave Throgmartin wrote:
Phase detect autofocus (focus through the viewfinder) is not as accurate.
I didn't know this. It doesn't make sense to me; Live View should be less accurate.
so you're saying if I set my SL1 Live View to use Phase Detection (so the mirror flips up and back down to focus), I'm getting worse results than with the Live View system? Does this explain why Live View takes longer to focus compared to the view finder?
 MyPupEllie's gear list:MyPupEllie's gear list
Fujifilm FinePix S1800 Fujifilm FinePix S2 Pro Canon EOS Rebel SL1 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Canon EF-S 18-55mm f/3.5-5.6 IS STM
ThrillaMozilla Veteran Member • Posts: 7,681
Live view maximizes contrast in the actual image; phase detection uses separate detectors that may not be perfectly aligned with the sensor.  Because live view uses the actual image, it's usually as accurate as any autofocusing method can be, although it may work slowly or not at all.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
