Does a zoom lense always need tripod ?
Started Dec 24, 2015 | Questions
Evil Nemesis
Evil Nemesis Forum Member • Posts: 90
Hi, I just bought this 55x250 EF-S STM II lens for my rebel t3. Haven't test my new lens yet but just wanna ask if I need to keep my tripod with me all the time when using a focal length of 200 or 250mm ? Even during day time and in good light, macro shots etc ?
-The Nemesis-
 Evil Nemesis's gear list:Evil Nemesis's gear list
Canon EOS 1100D Canon EF-S 18-55mm f/3.5-5.6 Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
Peter63 Senior Member • Posts: 1,529
Re: Does a zoom lense always need tripod ?
I almost never use it with a tripod. The stabilization works well and if you need a very slow shutter speed, try bracing on something or working on your technique.
 Peter63's gear list:Peter63's gear list
Canon EOS M Canon EOS Rebel SL1 Canon EOS M5 Canon EOS 77D Canon EOS M6 +30 more
kreygscott
kreygscott Senior Member • Posts: 1,285
You do not need to have a tripod with you at all times. However there are some situations which will require the use of a tripod such as in low light conditions, and macro. The 55-250 EF-S STM is not considered a fast lens regardless of its focussing capabilities. For landscape and shots I always use a tripod especially when working with a long lens. However for portraits which the 55-250 is also good at its lowest magnification or 55mm you can shoot without the use of a tripod. You can also use the techniques mentioned by Peter33 which will also reduce camera shake and improve image sharpness.
Hope this helps.
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
Stu Brennan Regular Member • Posts: 330
IIRC there was an old rule of thumb from back in the 35mm film days.  The shutter speed should be, according to the rule, faster than "1 over the focal length".  If you are at 500mm, for instance, the shutter should be at 1/500 or faster.  If you can't manage that, then you need a support or a tripod.  I assume that today's image stabilization would allow you to cheat that a little, but probably not much
Stu
WilbaW
WilbaW Forum Pro • Posts: 11,643
You do RC, but the ROT needs to include the crop factor to get the 35mm equivalent focal length (EFL), so your example becomes 1/(500x1.6) = 1/800.
That's the crucial thing - the ROT is a gross approximation, and you have to do some testing to know what you (your own self) can get away with. That testing also has to take into account your purpose, for instance, you need much faster shutters for large images of birds than you do for small images of sunsets.
You can test it by taking 10 shots at 1/2EFL, then 1/EFL, 2/EFL, 4/EFL... If you can consistently get say 90% sharp shots at a particular ratio, then that can be your personal ROT.
Actually quite a bit. I've found Canon's claims to be accurate, for instance, if they say IS is worth 3-4 steps, then I can confidently go 3 steps longer on the shutter.
I don't know about the 55-250 STM, but the older 55-250s needed a good second for the IS to settle, so you need to take a deliberate pause with those lenses.
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
Digirame Forum Pro • Posts: 41,857
No, a zoom lens does not always need a tripod. I never use a tripod for any of my outdoor Canon DSLR photos from 18mm focal length to 600mm focal length. And that includes when I was using my older Olympus DSLR cameras and lenses at different focal lengths more than four years ago.
Sometimes a zoom lens could use a tripod if the shutter speed was too slow. Practice holding the camera and lens steady. Brace the camera and lens at times also.
Dave Throgmartin
Dave Throgmartin Contributing Member • Posts: 878
I agree with the others.  Using a tripod is not always necessary when using a zoom lens, but can be nice to do at times.
The main advantages to using a tripod IMO are:
1) Careful image composition - Typically I find for myself that the images are better composed when using a tripod.
2) Typically you can use ISO 100 unless it will cause motion blur because of the slow shutter speed - Want to shoot a landscape at f/11 to maintain deep depth of field and ISO 100 during the golden hour?  If you shoot hand held the camera will likely shake.  You can bump the ISO to compensate or open up the aperture.  Neither are desirable at times.
3) Sharpness is as good as your setup is capable of when using a tripod plus careful manual focusing or focusing using live view.  Phase detect autofocus (focus through the viewfinder) is not as accurate.
Regards
Dave
Clive50
Clive50 Contributing Member • Posts: 693
with a 55-250 I wouldn't bother as it's not heavy so you should be able to hold it still. I use that lens and a 150-500 tamron and the slow shutter speed with the Tamron needs a tripod or something to hang on to being a heavy lens.
 Clive50's gear list:Clive50's gear list
Canon EOS 600D Canon EOS 80D Canon EF 50mm F1.8 II Tamron AF 18-200mm F/3.5-6.3 XR Di II LD Aspherical (IF) Macro Tamron SP 150-600mm F5-6.3 Di VC USD +5 more
ThrillaMozilla Veteran Member • Posts: 7,681
A fool asks on the Interwebs, and gets foolish answers.  A wise man just tries it.
I have a picture I took with that lens at 250 mm, bouncing around in the back seat of a car on the highway.  The picture is sharp.  That is not a fluke.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
Nemesis, in addition to what I wrote please understand that "rules are made to be broken". It depends on the individual photographer and techniques employed to take them hand-held at very slow shutter speeds relative to the focal length.
For example, when I find the wood ducks perched on a branch and I have time I can take them hand-held at about 1/100th of a second (or even slower) at 600mm FL. The technique that I use is to brace the camera and lens on a wooden railing nearby.
I have to take them at these slow shutter speeds when we have cloudy weather. I stop down the lens in my attempt to keep everything about the bird in focus including the tail feathers (as much as possible).
Here is one taken hand-held with the Canon 18-55mm lens at 1/4th of a second.
Shifter Veteran Member • Posts: 5,076
No. It's a short zoom.
How's the new lens work?
 Shifter's gear list:Shifter's gear list
Canon EOS 7D Canon EOS 5D Mark IV Sigma 50-500mm F4.5-6.3 DG OS HSM Canon EF 24-70mm F2.8L II USM Sigma 18-200mm f/3.5-6.3 II DC OS HSM +1 more
Evil Nemesis
OP Evil Nemesis Forum Member • Posts: 90
Re: No. It's a short zoom.
It's great but haven't really tested it yet in open. Will go on photo hunt with the new lens on Sunday and will try to post some pics
-The Nemesis-
It's Monday now for most of the world. ???
Evil Nemesis
Lolz, man I was talking about next Sunday as I'm busy on weekdays.
-The Nemesis-
LOL
Wow. OK. My mistake. I'd go nuts myself waiting to try a new lens that long, but that's cool.
RedFox88 Forum Pro • Posts: 30,738
Stu
No.  With aps-c you need to multiple the focal length by 1.6 to get the effective focal length. And the OP's lens has IS which provides about 2.5 stops of stabilization. So a 250 mm is 400 and with 2.5 stops brings it down to about 80 so 1/80 shutter speed minimum needed for normal hand held use.
Evil Nemesis
Alright so for example a broad day light sports (cricket) scene capture Should I go with TV mode ? or manual
-The Nemesis-
kreygscott
Shoot in full manual leaving ISO adjustment as the last resort.
Evil Nemesis
Thanks alot mate.
-The Nemesis-
kreygscott
Evil Nemesis wrote:
Thanks alot mate.
Glad I could be of help mate.:-)
