how to set aperture on e-pm2 with legacy glass
Started Dec 24, 2015 | Questions
phituyetca New Member • Posts: 16
Hi, sorry for a noob question. I just got a hand on an e-pm2 and couldn't figure out how to set the aperture on non m4/3 lense (in A and M mode). I have no problem with m4/3 lense but when I put on the the adapter the aperture display "--" and I can't change it. Is there something I have to turn on or off ?
thanks,
Olympus PEN E-PM2
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: how to set aperture on e-pm2 with legacy glass
thanks,
Set the camera to S or M
You adjust the aperture on the lens - if it has an Aperture ring.
If it does not, you cannot adjust the aperture unless the adaptor has some kind of adjustment.
E.G. Old Nikon lenses have a ring but almost all of the new lenses do not. Therefore, one buys the appropriate adaptor.
Allan
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,433
You change it on the lens, and realize there's no communication between body & lens so naturally the aperture setting in the display has nothing to show.
IOW, that's normal.
...Bob, NYC
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
OP phituyetca New Member • Posts: 16
Thanks... I should've get a better adapter.
(unknown member) Veteran Member • Posts: 3,010
Found it ! (the "ring" on the adapter) It marked Lock <---> Open, so I thought it lock the adapter to the camera...
http://www.amazon.com/RAINBOWIMAGING-Minolta-Adapter-Panasonic-Aperture/dp/B002Z3TDM6
Once again thanks...
kcdogger Veteran Member • Posts: 4,356
If you are using an older, manual everything lens, set the aperture (and focus) on the lens using the aperture and focus rings. If you are using an auto focus lens, some of the cheap adapters have an "open - lock" function. Do not assume the "lock" part has anything to do with attaching the adapter to your camera - It doesn't (It should read "open - close," but something gets lost in the translation.) Attach the adapter to your camera as you would a lens w/o an adapter. You will also have to focus manually.
I do not have your camera, but do have an E-PM-1. I used it today with a Fotasy brand adapter and a sony auto focus lens. Put the adapter on the lens in the "open" position. You can then adjust the aperture using the "open-lock/close" ring on the adapter. There are no aperture markings on the adapter, but you can figure out what you want by watching live view.
Whatever aperture you set, the camera will adjust the shutter speed for you if you shoot in Aperture Priority. If you want to be more creative, shoot in Manual, and adjust both the aperture and shutter speed, with the ISO set to Auto.
Don't forget to set the camera to "Shoot Without Lens" in the set up menu, since the adapter has no electrical connections, the camera won't recognize there is even a lens attached if you don't do that. Happy shooting!
Peace.
John
 kcdogger's gear list:kcdogger's gear list
Olympus Stylus 1 Panasonic ZS100 Sony RX100 VA Panasonic Lumix DC-ZS80 Olympus TG-6 +37 more
I got an old minolta 50mm f1.7. I want to try out manual focus on e-pm2
See my post above. I was typing while you were posting your last. It should work fine with your 50. Peace. John
jeffharris
jeffharris Forum Pro • Posts: 11,409
phituyetca wrote:
Hi, sorry for a noob question. I just got a hand on an e-pm2 and couldn't figure out how to set the aperture on non m4/3 lense (in A and M mode). I have no problem with m4/3 lense but when I put on the the adapter the aperture display "--" and I can't change it. Is there something I have to turn on or off?
Use the aperture ring on the lens?
Thats one of the joys and beauties of using manual lenses. Direct control and simplicity!
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Thank John, I though the ring has some numbers (1.8, 2.8...) not Lock<--> Open !
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
That "shoot without lens" menu thing is only with Panasonic bodies.
Olympus happily just works with or without lenses of any type with no menu fiddles needed.
Regards...... Guy
jeffharris
Activate Shoot Without Lens ONCE and forget it. That's rough.
AlbertTheLazy
AlbertTheLazy Veteran Member • Posts: 8,683
That is the aperture ring that everybody has been talking about. If those numbers are unfamiliar maybe you need to do some basic learning.
Try Cambridge in Colour
About half way down this page
http://www.cambridgeincolour.com/tutorials/camera-exposure.htm
you'll find a simple explanation about aperture and the whole page explains how aperture, exposure time (shutter speed) and ISO work together.
Albert
(The one in France)
Every photograph is an abstraction from reality.
 AlbertTheLazy's gear list:AlbertTheLazy's gear list
Canon PowerShot G15 Fujifilm X-T1 Fujifilm X-T3 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R +6 more
Guy Parsons
It's rough that you even need to do it all.
There really seems to be no point at all in having that Panasonic menu item. Not trying to be a smartie, just really curious why they included it.
Regards........ Guy
jeffharris
You're right. It's kind of pointless having it, since there's no need to ever disable it, even if you never use manual or adapted lenses.
AlbertTheLazy
Fujis have exactly the same menu item. I haven't worked out why.
Albert
(The one in France)
It's pretty much essential to know if your lens has an aperture control ring on it and where the arperture is set. Wide open half way or closed. As far as I know the adapters with the arperture control can't change the setting in the lens so if your lens was set to closed it can't open it. It can only limit the amount of light getting to the sensor from the lens. My lens has the control ring on it so it's not a problem for me.
http://www.flickr.com/photos/90891174@N04/
Anyway I'm not sure if you just got the camera and if the SCP super control panel, or secret control panel depending on your point of view is on. If it is go to the bottom right cell and select IS. Hit the info button and set the focal length of your lens. 50mm. This tells the camera how to respond to image shake on you adapted lens. I have the same camera and I assign image magnify to one of the two programmable function buttons. That way if I want to critically check focus I can just press the button to get a magnified view.
GV27 Regular Member • Posts: 324
I've heard a couple explanations for this.
1: it protects the shutter from firing when there's a possibility of an obstruction being in the way.
2: It's a health check. If you don't have "shoot without lens" enabled, if something goes wrong with the communication between the body and the lens - there's something wrong with the lens, lens isn't properly seated etc. you are notified vs. just getting weirdness.
While I enjoy shooting with adapted lenses it is a bit of a weird situation. I would guess that 99% of m43 bodies sold will never see a non-native lens attached. It makes total sense for the camera to point out that something's wrong when no lens is attached.
 GV27's gear list:GV27's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DC-GX9 Nikon AF Nikkor 24mm f/2.8D Olympus M.Zuiko Digital 17mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH +5 more
