Early days with new Oly 14 - 150
Started Dec 22, 2015 | Discussions
Noku Dzu Regular Member • Posts: 307
Some of you know that I decided on the Oly over the Panasonic 14 - 140mm zoom. Thanks for all of the helpful ideaas and comments on that thread (http://www.dpreview.com/forums/post/56885887).
I'm learning about the strengths (tremendous zoom range) and weaknesses (a little soft at f8 and above). It's fun to use.
If you like, you can see samples of my rather amateurish work while getting acquainted with the lens here: http://www.dpreview.com/galleries/6719738940/albums/testing-olympus-14-150
We are seeing the last of our roses, here's an image:
One of last ones, still trying to hang on ...
 Noku Dzu's gear list:Noku Dzu's gear list
Canon G5 X II Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro +5 more
Olympus 14-150 F4-5.6 II Panasonic Lumix DMC-GX7
jonikon Veteran Member • Posts: 7,434
Re: Early days with new Oly 14 - 150
Did you consider the Tamron 14-150mm? The build of the Tamron seems better.
- Jon
dv312
dv312 Veteran Member • Posts: 9,215
A great all around travel lens: small, light, weatherproof, and sharp enough for most purposes
I use it more often than my 12-40mm which is relegated to important shooting with less light
I just wish it had  the 12mm at the wide end and it'll be 'perfect'
It's my kit lens mounted on the EM5 II by default
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
OP Noku Dzu Regular Member • Posts: 307
Jonikon - Re: Early days with new Oly 14 - 150
I only considered Panasonic and Olympus. Right now, I guess you could say I have 'brand loyalty' to them.  Of course, my loyalty could be misguided.  I had a Tamron lens a long time ago, in my 35mm days, but I did not consider other brands with my new m43 system.
Highest f stop you use? - Re: Early days with new Oly 14 - 150
I think I probably hurt myself on image quality by using too high an f stop at times.  What do you recommend as the upper limit if you want the best quality out of the lens?
Re: Jonikon - Re: Early days with new Oly 14 - 150
I understand. Third party lenses can sometimes be a mixed bag. I am not into m43 (yet), and still have a lot of research to do before buying anything. As chance would have it, I just read a review of the Tamron yesterday and so I asked the question. It is my understanding correct that the Olympus 14-150mm that you have is a recent update to a previous model?
- Jon
Yes, mine is the latest and current model. The size and handling is just fine for me. FWI, I have used manual focus some and it is smooth and quite visible on my GX7.
Peter Del Veteran Member • Posts: 7,988
Most of my pictures are taken with the 14-150 mk1 on an E-M5 mk1. It is so convenient for many subjects. Avoid f/22 if you can.
Peter Del
Gallery: http://www.dpreview.com/galleries/8804053911
 Peter Del's gear list:Peter Del's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 +5 more
dv312
Re: Highest f stop you use? - Re: Early days with new Oly 14 - 150
Since the lens is rather slow I'd leave it on f4 most of the time; of course it'll be 5.6 at the longer end but it's OK still
I'd also leave the camera on Auto ISO to compensate for movement blur with the limit setting at ISO 6400
The only few times I set to higher aperture is when I want to have motion blur or on long exposures
I also just acquired the 75-300mm to keep this lens company on trips
I'd also pack a couple of fast primes just in case where shallow DOF and/or low light are called for
(I'd leave the 12-40mm at home this time )
