Helen
The new "Auto" shutter type setting for the G7 and GX8
Dec 21, 2015
Just some additional observations to add to the ones previously made by others.
The Auto option that's been added as a third choice (alongside On and Off) for the electronic shutter facility on the G7 and GX8 with the recent firmware updates does indeed seem to function differently to the straightforward behaviour of the Auto shutter setting on the GM1, GM5 and GF7 (where it simply takes over at the shutter speeds that the mechanical shutter cannot reach) - though sometimes it acts the same way as those, according to the lens in use.
Lenses I've tried it with, where the behaviour is totally "standard", like the GM1/5/GF7, are the 14-42 II (or A - the current, small manual zoom), the 25mm f1.7, the 45-150 - all Panasonic lenses with the latest firmware. However, the petite 35-100mm behaves very weirdly - the electronic shutter symbol flashes erratically on and off, apparently between 1/60 and 1/320, and totally at random - it even flutters if the shutter speed is manually set, so it's a complete lottery as to which mode the shutter will fire in, even on the same speed, from shot to shot, and the fluttering has no regularity or pattern at all. That's been the same on both G7 and GX8, and pre- and post-updating the lens firmware. So either my (not very old at all) 35-100 has something weird going on, or they're all that way. It would actually benefit from switching to e-shutter consistently at those speeds, as it does suffer when the shutter's on mechanical in my experience - mind you, so can the 45-150 occasionally, and it doesn't seem to trigger the e-shutter at all in the normal mechanical range.
I also tried the 12-32 which several have reported is vulnerable to shutter vibration issues on the G7, GX8 etc., but mine shows no tendency to switch them to E shutter at any point inside the mechanical speed range.
Since I don't have a 14-140 II to test, I was beginning to think the reports of observable auto-switching to E-shutter in the speed range that could be affected by shutter vibrations for that lens were perhaps wishful thinking, but then I remembered the 14-42 X PZ sitting in a corner of a camera bag of mine. It's one of the other lenses that has a pretty widespread reputation for double images caused by shutter vibration in the otherwise normal shutter speed range, and yes - it consistently switches automatically to E-shutter from 1/60 to 1/320, whether the speed is automatically or manually set, on both the G7 and GX8. That's a relief, since mine behaves badly on Panasonic bodies in that speed range unless they are in E-shutter (though of course the GM1 is OK with it, even in mechanical shutter mode).
