How slow is NX20? It sells for $200
Started Dec 20, 2015 | Discussions
VYC Majoris Junior Member • Posts: 49
As you can see from the title I can buy it for $200. I had used it for 10 minutes in a store when it was launched a few years ago and it was painfully slow. It was probably on the first firmware. Did it get better with an update? I'm planning to use it with my 8mm fisheye lens. I won't be taking images in continuous mode. I am ready to buy the fastest sd card on the planet if it makes a difference.
Olympus 8mm F1.8 Fisheye Pro Samsung NX20
wpstl Senior Member • Posts: 1,251
Re: How slow is NX20? It sells for $200
If that includes the kit lens it's a very good deal. And, if it's only to be used with the fisheye, focus isn't an issue. I never found it particularly slow. I have one I converted to IR so CF is not a need and writing to the card isn't a big deal. I never really found that particularly slow either.
"Sometimes I like to throw a grenade and run away."
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
OP VYC Majoris Junior Member • Posts: 49
Yes it includes the kit lens. Thank you.
Kaziklu Senior Member • Posts: 1,301
It will take about 7-9 shots in a fast burst. But will cause a 15-30 second delay while it writes. Which is much better then it was at launch. No point in having a card faster than about 40mb/s which is about as fast as it can write.
Sadly the NX20 was never updated to write to the card while shooting. It will fill the buffer up and then write, it starts writing after a short delay between shots (which is long enough that I can fill the buffer just shooting normally)
I love the NX20. It frustrates me at times but that is more because I out grew it.
the Focus system is Contrast Detect and is a few years old. As long as you aren't expecting more than the system can offer (at fish eye likely you won't have an issue) you should be fine.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
jonathanj
jonathanj Contributing Member • Posts: 999
I'd say it's worth it for $200, but it doesn't get much faster with firmware updates. The problem I found is that I'd take a shot, realize I have the settings wrong, then have to wait for the file to save before I can change them. If you have the (good) habit of always checking your settings *before* shooting, you'll be much less affected by this.
 jonathanj's gear list:jonathanj's gear list
Panasonic Lumix DMC-GX85 Sony a7R III Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH +8 more
alex_virt Veteran Member • Posts: 3,044
It is certainly worth $200, but it's very slow if your shoot RAW. A fast card won't help.
Oddly enough, while commands in the body are locked while writing file to card, iFn functions much better. It's not always available but it regains function much faster (especially while you are waiting for a single raw + jpeg to be saved, fn button just says Processing but iFn and focus ring work). Makes you wonder why they locked other controls.
Faith Yeung Contributing Member • Posts: 600
See my dirty test under
http://www.dpreview.com/forums/thread/3907726
Faith
 Faith Yeung's gear list:Faith Yeung's gear list
Sony SLT-A77 Sony SLT-A37 Sony Alpha a99 Nikon 1 V2
Thank you. I bought it and it's much faster than that actually. I can view the photo after 2.5-3 seconds. I shoot raw+jpeg(normal quality).
mordor_74 Contributing Member • Posts: 622
I'd like to suggest you to shot in RAW only and use Instant Jpeg from RAW later. You will get the same result and wirte less bytes on the SD.
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
Glad you bought it, I used it right up to the point I got the NX1, It is still there as my second body, but I haven't needed it since.. February. It is a good little camera though.
Bryan M
Bryan M Contributing Member • Posts: 956
I'd you need a viewfinder then the NX30 is your camera, its a much better choice. I'd you don't need a viewfinder then the nx300 would be a nice choice is you are budget conscious.
Bryan
 Bryan M's gear list:Bryan M's gear list
Nikon D750 Nikon Z6 Tamron SP 70-300mm F4-5.6 Di VC USD Tamron SP 70-200 F2.8 G2 Nikon Z 14-30mm F4 +2 more
How is the writing speed of NX30? I always shoot RAW.
Bryan M
I used a fairly fast card and never had issues with it.
Bryan
