Wide angle converter for Panasonic 14-140?
Started Dec 16, 2015 | Discussions
Richard Southworth Contributing Member • Posts: 569
Just purchased a G7 with the 14-140, very pleased with this rig.  I am interested in adding a wide angle lens or converter.  I went to B&H, filtered on wide angle converters for 58mm, came up with 9 entries, ranging from $12 to $300.
So the obvious question is do any wide angle converters work well on this lens?  Any recommendations?
Thanks,
Richard Southworth
 Richard Southworth's gear list:Richard Southworth's gear list
Panasonic Lumix DMC-ZS50 Panasonic ZS100 Panasonic G85 Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
Panasonic Lumix DMC-G7 Panasonic Lumix G 14mm F2.5 II ASPH
Spectre38
Spectre38 Regular Member • Posts: 466
Re: Wide angle converter for Panasonic 14-140?
I have one that I used on my 14-42 and it had severe vinetting on the wide end. If you ar ok with cropping out the center horizontal section you can use it.
It was advertised as a 0.45x but was really 0.85x. The 2.5x was really 1.3x.
IQ dropped a bit also, but not bad. I still got great pictures, but dont use it anymore because you can do can just take a step or two back and get the same FOV.
 Spectre38's gear list:Spectre38's gear list
Olympus PEN E-PL2 Panasonic Lumix DMC-G6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Sigma 30mm F2.8 DN | A Sigma 60mm F2.8 DN Art +4 more
Mark Thornton Veteran Member • Posts: 4,570
Try 9mm bodycap instead
For those occasions when 14mm isn't nearly enough.
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
Robiro Veteran Member • Posts: 6,813
Thanks,
Richard Southworth
There is a reasonable chance this one will work:
http://www.bhphotovideo.com/c/product/219741-REG/Raynox_HD_6600PRO_58_HD_6600_Pro_58mm_0_66x.html/prm/alsVwDtl
At 14mm and f8 it should give you acceptable corner sharpness and 9-10mm wide angle experience (18-20mm equivalent).
If not, just return it.
I would not go lower than 0.66x.
In fact, this 0.7x one could be a better choice.
http://www.bhphotovideo.com/c/product/292491-REG/Raynox_HD_7000PRO_HD_7000_Pro_58mm_0_7x.html/prm/alsVwDtl
The reviews are positive.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
