Panasonic 35-100 f2.8 over Olympus 40-150 f2.8?
Started Dec 16, 2015 | Discussions
pxchoi Regular Member • Posts: 439
I think the Olympus 40-150 looks great on paper but after looking at the sample images, I'm not sure if I'm convinced. In my personal opinion, I feel like the out of focus areas in the Panasonic lens is far better than the Olympus. In certain situation, the out of focus blur just looks terrible.
The extra reach would be nice, but the Panasonic lens is so much smaller.
Am I crazy to think that the Panasonic is the better lens here? - if you don't need the extra range.
 pxchoi's gear list:pxchoi's gear list
Fujifilm X-Pro2 Fujifilm XF 23mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR +1 more
Olympus 40-150mm F2.8 Pro
Robiro Veteran Member • Posts: 6,813
Re: Panasonic 35-100 f2.8 over Olympus 40-150 f2.8?
I can only speak of Pana 35-100mm which I own. It is a stellar lens. It will not disappoint you.
As concerns out of focus areas, it will not blur the background as much as APS-C or FF lenses. A typical background blur example at f4:
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Olympus 40-150mm F2.8 Pro Olympus 100-400mm F5.0-6.3 IS Panasonic 12-35mm F2.8 Sigma 30mm F1.4 for Micro Four Thirds
Martin Muehlemann
Martin Muehlemann Senior Member • Posts: 1,463
I got both lenses. Both are stellar. While the AF is a tad faster with the Olympus 40-150 Pro.
Really depends on the body and purpose.
 Martin Muehlemann's gear list:Martin Muehlemann's gear list
Olympus E-M1 III Olympus TG-5 OM-1 OM System 12-40mm F2.8 Pro II Olympus 40-150mm F2.8 Pro +9 more
mauror17 Regular Member • Posts: 102
I have had the 35-100 f2.8 and now I have the 40-150 pro. I bought the oly for its extra reach.
They are different lenses, both are great but I prefer the output of the Panasonic.
In my opinion the Olympus renders too harshly, it gives the "wow" effect at first sight but the tonal transitions on the Panny are better.
I also confirm that the Panasonic has smoother out of focus, it's way smaller and lighter.
On the other hand the Oly is faster and accurate on focus and less vignetting at TA.
 mauror17's gear list:mauror17's gear list
Panasonic Lumix DC-S1R Sigma 65mm F2 DG DN NiSi 15mm F4 Panasonic S 24-105mm F4 Macro OIS Sigma 100-400mm F5-6.3 DG DN OS
Jorginho Forum Pro • Posts: 15,370
What you have seen and noted was noted by reviewers too. So it depends on your needs. Oly indeed has a longer reach and add to that a 1.4 TC that gives it even more reach. Panny being much much smaller, lighter and seem to be having better bokeh it seems. Also: it has OIS so the Panny is more allround clearly from that perspective..
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +8 more
The Panny is very sturdy too.
I think the focussing is largely depending on the body. On my GH4 the AF of the 35-100 is extremely fast, on a GH2 not as much nor on the EPL5.
As a testament Gh4 + lens fell 80 cm down on a wooden floor and got away with simply nothing. Not a dent. Stone would probably be less forgiving but wood is not really soft either. Of course it also matters what hits the floor first etc, so it might be luck too. Still: more than a year ago and everyting works flawlessly.
Second point: I have used it for hours in pouring rain, sleet and snow (wet kind, dry kind is no problem anyways) and not one hickup. So weathersealing of that lens seems exceptional actually.
Jon555 Veteran Member • Posts: 7,721
The Panasonic is pretty small and light (360g) so it's a no-brainer to pop in your bag. The Oly has more reach at the expense of greater size and weight. I do like how the Panasonic renders the out-of-focus stuff and will add that getting background blur is more a combination of where you stand and what focal length you use than anything else. Example:
http://www.dpreview.com/forums/post/51252546
Do check the full-size version and note (i) f5.6! and (ii) people in background are fairly close.
 Jon555's gear list:Jon555's gear list
Fujifilm FinePix Real 3D W3 Sony RX100 V Nikon Coolpix 950 Canon EOS 5DS R Panasonic GH5 +31 more
DLBlack Forum Pro • Posts: 15,865
I own both and I love both. I usually carry the Olympus for its extra reach. The one thing I don't like about the Panasonic is that it vignettes more. I haven't thought about it, but I guess I do like the bokeh of the Panasonic a little better. It is just every time I carry it I always wish it has a little more reach.
http://farm4.static.flickr.com/3571/3380136992_7c5a0986ea_m.jpg
 DLBlack's gear list:DLBlack's gear list
Pentax K-5 Pentax K-7 Olympus E-M5 II Olympus PEN-F Olympus E-M1 III +46 more
Chippy99 Senior Member • Posts: 2,182
Beware the 35-100 at 100mm and f/2.8
The Panasonic is a great lens, but do be aware that at the very long end and at f/2.8, it is a bit soft.  It's about the only flaw the lens has, but you should be aware of it.  If you are planning on using the lens under those conditions, and you are wavering between the Panasonic and Olympus glass, you'd definitely be better off with the Olympus.
 Chippy99's gear list:Chippy99's gear list
Sony RX100 Leica Q2 Olympus E-M1 Olympus M.Zuiko Digital 25mm F1.8 Olympus 12-40mm F2.8 Pro +4 more
Sample variation?
I haven't noticed it but I think I have heard about it before. Is this a characteristic or sample variation? Will loop up some reviews, some charts at least should show it.
I think the reach of the Oly as some have noted does come in really handy. With the TC it is actually a whole different lens altogether. Also the attention Oly gave to this lens in buildquality is even better. The lenshood is done so well. If it wasn't for the lack of IBIS, I would have gotten more Oly lenses than I do right now. Overall though, both companies offer a lot of very nice to sometimes exceptional (75 mm 1.8 and 42,5 mm 1.2 in particular) lenses.
Isabel Cutler
Isabel Cutler Forum Pro • Posts: 19,188
Re: I disagree....
It's sharp enough for me.  I love this lens.
It think with it's shallower depth of field it's easy to confuse out-of-focus areas as a flaw when using f/2.8.
Pictures are best viewed at original size, not at the compressed size in this message.
This image represents just 1/20 of the original image area.
Isabel
 Isabel Cutler's gear list:Isabel Cutler's gear list
Sony RX10 IV Panasonic Lumix DMC-GX7 Canon EOS 7D Sony a7 III Olympus OM-D E-M10 II +2 more
Yes
Yes, it is a bit soft at 100mm f2.8. But at f4 the softness is all but gone at 100mm.
http://www.lenstip.com/368.4-Lens_review-Panasonic_G_X_VARIO_35-100_mm_f_2.8_P.O.I.S._Image_resolution.html
IanYorke Veteran Member • Posts: 5,266
They are both excellent lenses the choice should be on size, weight and reach.  For their ranges and aperture they are both small and light.  You can't really go wrong.
Ian
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
"Better" depends on intended purpose.
I can put the 35-100/2.8 in my small camera bag for travel. No way that going to happen with the Oly 40-150/2.8
OTOH I have the 50-200/2.8-3.5 (similar in size to the 40-150/2.8 ) for wildlife and birds.
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Olympus E-M1 Olympus E-M1 II Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX7 +73 more
Adamant Contributing Member • Posts: 797
5
Reach is something you don't think you'll need until you get it.  Then you can't live without it. I'm surprised at how frequently I shoot at 100-150mm with the Olympus.
ijm5012 Senior Member • Posts: 1,889
Same here Eric. I have the Panasonic 12-35 & 35-100 f/2.8 lenses, as well as the Olympus 50-200. The size of the Panasonic f/2.8 lenses is their biggest benefit over the Olympus versions, which are larger, heavier, and take different size filters (another bonus of the Panasonic lenses, as both take 58mm filters).
When I need more reach and speed, I use the 50-200. In order to get the same reach with the 40-150 PRO, I need to buy the TC which makes it a constant f/4 lens, and that's all the further that lens will go. With the 50-200, I have a native f/2.8-3.5 lens, and I can put a 1.4x TC on it and get a 280mm f/5 lens, all in the same size and weight of the 40-150 PRO (when stowed for travel).
 ijm5012's gear list:ijm5012's gear list
Nikon D500 Nikon Z6 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED-IF VR Nikon Z 24-70mm F4 +6 more
Re: I disagree....
True. But it is still soft at 100mm f/2.8 I have tested it extensively and thought at first it was faulty, but the more perceptive reviewers pick up this flaw too.
f/3.5 sharpens it up considerably, and by f/4 it's perfect. And it is perfect at all apertures at shorter focal lengths.
I am 99% certain it is simply spherical aberration coming into effect when all the glass is needed at the long end. No other focal length nor aperture combination uses the extreme edges of the glass.
Undergrd Junior Member • Posts: 42
Re: Both are equally good and it depends on what's your priorities...
I have the Pany 35-100 and sold it to get the Oly 40-150. Mainly for the extra reach but at times I do missed the smaller size of the Pany 35-100.
 Undergrd's gear list:Undergrd's gear list
Nikon Df Olympus PEN-F Nikon D850 Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro +12 more
daddyo Forum Pro • Posts: 12,670
Mine is not soft at 100mm f/2.8.
Every lens made has a peak sharpness point, but there is no appreciable softness with my 35-100mm at full zoom, wide open. Is it sharper at f/4? Yes it is, but not to the extent that it would be noticeable at any size at a normal viewing distance.
Just one example, and I have many more:
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Isabel Cutler
Re: Not hard to understand...
I sold my Canon 100-400 because of its weight and bulk.
I really appreciate the 35-100 and it is very well balanced on the GX7.  Super comfortable combination to use and its images take to cropping quite well, retaining a good deal of detail, which makes up for its lack of reach at times.
Isabel
