I'm sold on M4/3. Now what to get?
Started Dec 16, 2015 | Discussions
raztec Contributing Member • Posts: 595
I picked up a EPM2 that was being heavily discounted at local store, just to see what all the fuss was about. Well for $200 and a kit lens, I'm blown away by the quality compared to my LX7. It even rivals my Nikon D300s and now I'm sold on this system and looking to get into it properly.
I want to stay with Panasonic because I find the menu system of the Olympus cameras way too complicated. I need the following:
  • Relatively compact
  • EVF
  • In body IS
  • ND fliter
  • Flip out screen
Do any of Panasonic's cameras have these features and if not, what camera does?
Raz
 raztec's gear list:raztec's gear list
Panasonic Lumix DMC-LX7 Nikon D700 Nikon D300S Olympus PEN E-PM2 Nikon AF Nikkor 24mm f/2.8D +6 more
Nikon D300S Olympus PEN E-PM2 Panasonic Lumix DMC-LX7
(unknown member) Forum Pro • Posts: 11,837
Re: I'm sold on M4/3. Now what to get?
  • EVF
  • In body IS
  • ND fliter
  • Flip out screen
Raz
I changed fron the venerable D300 and was blown away too.
Try this link for starters http://panasonic.net/avc/lumix/
THe GX8 comes nearest to your needs.
Olympus has a simplified menu that you can set to default.
robonrome
robonrome Senior Member • Posts: 2,334
GX7 might also be considered... it is smaller than GX8
rob
http://hardlightimages.zenfolio.com
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
matrkr New Member • Posts: 1
i was in the same spot as you, still love my LX7, but the EPM2 (after a brief EPM1 time) was superb, especially with the primes 14mm and 20mm from panasonic/lumix.
But the closest body for your requirements would be the GX7, which i managed to buy a few months ago (shop demo, had about 100 shots on it, body only for $350 or so). The GX7 is great, especially since i was buying it for the video - and the stills aren't half bad
Every other Pana with EVF is bigger, alas; maybe you can find the GX7 if the GX8 is too big? i just didn't like the OMD style, classic tho it was, preferring the 'rangefinder' ergonomics.
 matrkr's gear list:matrkr's gear list
Sony Cyber-shot DSC-HX9V Panasonic Lumix DMC-LX7 Olympus PEN E-PM2 Panasonic Lumix DMC-GX7 Panasonic Lumix G 20mm F1.7 ASPH +3 more
aiz
aiz Junior Member • Posts: 25
8
Don't narrow your choice! Menu system should be the last thing while shooting.
BTW: Olympus has so called "super control panel", which lets you forget about menus in most cases.
 aiz's gear list:aiz's gear list
Sigma DP2 Sigma DP1 Fujifilm X20 Olympus PEN E-P2 Olympus OM-D E-M5 +12 more
tkbslc Forum Pro • Posts: 17,527
  • EVF
  • In body IS
  • ND fliter
  • Flip out screen
Raz
There are exactly zero cameras with all of those.
Impulses Forum Pro • Posts: 10,039
  • EVF
  • In body IS
  • ND fliter
  • Flip out screen
Raz
Err, are there any ILC with built in ND filters? Ignoring that, the older but still GX7 comes closest to what you want, the GX8 is newer and more full featured but also pretty large by M4/3 standards... Might not be an issue yo you given what you're coming from.
They're the only Panasonic bodies with IBIS, for any more options you'd have to start looking at Oly again. The GX8 has a fully articulated screen btw, tilt only on the GX7, not sure which of the two you meant by 'flip out'.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
alcelc
alcelc Forum Pro • Posts: 19,005
If looking for something as compact as EPM2, there is only GM1 (no evf)/GM2 (integrated evf) under Panny's camp but do not have IBIS.
Only 2 Pannys have IBIS, GX7 & GX8.
Relatively compact
GX7 is within a close range to the size of EPM2 as here. GX8 is much bigger and be closer to the size of flagship GH4/EM1 as here.
EVF
Both GX7 & GX8 has an integrated tilting evf (max 90° upward).
In body IS
GX7 offering a primitive IBIS (1st time for panny). IMHO offering 1.5~2 stops close to the effect of Oly's early models. GX8 has a better IBIS than GX7 and if compatible OIS lens be used, would offer Dual IS having effect comparable to EM5-II's 5 axis IBIS.
ND fliter
Likely ICL camera use add on ND filter instead of compact's offering.
Flip out screen
GX7 uses a titling LCD whereas GX8 use a fully articulated LCD.
Raz
Albert
OP raztec Contributing Member • Posts: 595
I meant fully articulating screen for taking video.
I guess it's a lot to ask. I probably would have gone for the LX100 if it had that.
I guess the GX8 is it. Hmm...pretty expensive. Dang. I hope it's just the beginning of they recognizing what people want
Thx all
raz
www.pbase.com/bluethermal
Ulric Veteran Member • Posts: 4,559
5
Before ruling out Olympus, check out the Super Control Panel. It's disabled by default for some mysterious reason, so you have to dive into the menu to enable it. With this done, the Olympus is easier to use than Panasonic. I have both.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Voyager03 Regular Member • Posts: 259
What is a GM2?
 Voyager03's gear list:Voyager03's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +4 more
Robiro Veteran Member • Posts: 6,813
Breaking down your needs
GX7
  • EVF
GX7, GX8
  • In body IS
GX7, GX8 (this requirement limits you to GX7, GX8)
  • ND fliter
Not needed with GX8 - it has a 1/16.000s electronic shutter and 1/8.000s mechanical shutter (GX7 also has a 1/8000s mechanical shutter)
  • Flip out screen
GX8
But you should definitely check some Olympus models.
Olympus OM-D E-M10 II is a very good proposition. I would not rule it out, if I was you. It probably has the best 16MP 4/3 sensor.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
Macintosh Sauce
Macintosh Sauce Contributing Member • Posts: 706
Personally, I'd recommend the LUMIX GX8. The OLED EVF and OLED flip out screen are both in the native 4:3 aspect. Also, the EVF has none of the color tearing that the GX7's EVF has. The menus are pretty straight forward on the GX8, which is something I like a lot.
Jorginho Forum Pro • Posts: 15,370
The sensor is better than your Nikon 300s to be exact, not much but still....
  • EVF
  • In body IS
  • ND fliter
  • Flip out screen
Not possible because of the ND filter, IBIS and flipout screen.
If you can do without flippy and ND: GX7.
If you can do without IBIS and ND: G7 (but it is not THAT compact).
GM5 is very nice too, just the EVF is kind of small actually. It is as compact as your LX7 bodywise!
Raz
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
Re: Breaking down your needs
GX7
  • EVF
GX7, GX8
  • In body IS
  • ND fliter
Depends on the lenses. E shutter gives visibly less IQ and is precisely under those conditions
(too much light) not a real option if IQ is essential.
Panny and Oly would do well to build an ND filter in.
  • Flip out screen
GX8
Not an option as the single reason he wants to leave EPM2 is the menusystem that is the way it is on every Oly cam. Otherwise I would however agree with you that Oly seems to have a lot that he wants in a small package. IQ is very good aswell etc.
(unknown member) Senior Member • Posts: 1,015
Care to point out some examples of "Visibly worse IQ" (using e shutter)
No. Well documented.
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
  • EVF
GX7, GX8, G7, G6, GM5
  • In body IS
The only two Panny bodies with IS in the body are GX7 and GX8.
But the Panny equipment is designed with the strategy that lenses with a focal length greater than 25mm have Optical IS in the lens, controlled by the camera. This works fairly well.
  • ND fliter
There are no Panny M43 cameras with a built in ND filter. I think no Olympus M43 either. But all but one lens can take an ND filter on the front.
  • Flip out screen
GX7 has a tilt screen (vertical only)
GX8, G7, G6 have a tilt and flip screen (vertical, horizontal)
I think for you the G7 may be a good fit, but I would take a closer look at the G7, GX7 and GX8
Raz
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
Where?
Instead of blindly believing everything written on the interwebz, I've actually tested it out myself. With my GX8. Back to back, using mechanical & e shutter. I can't see any difference.(for subjects other than rapidly moving ones) If anything, general consensus seems to point towards better IQ using e shutter, due to zero shutter shock.
What are your personal experiences?
Eric Nepean
Even with my GX7, I would say there is not an in use visibly different IQ between  electronic shutter  and mechanical shutter.
Although, if I had a very high contrast scene and wasn't using HDR I would probably shift to mechanical shutter so I could extract as much detail in PP as possible.
Eric
