E-PL6 vs E-P5
Started Dec 15, 2015 | Discussions
bwalter New Member • Posts: 4
E-PL6 vs E-P5
So I was about to order the E-PL6 kit (14-42 IIR) when I stumbled across a retailer selling the E-P5 body for the same price ($399 CAD which is about ~$300 USD).
I couldn't resist and pulled the trigger on the E-P5 body but now I'm realizing the kit lens would cost me another $250 CAD. I think it's still a really good price for the E-P5 but I'm wondering whether it's really worth it to me.
I suspect the E-PL6 would be sufficient for my needs. Mainly I want something that can take good pictures of my 20 month old son. Right now we mostly shoot with cell phones, but have tried with point and shoot (Panasonic TZ4) and the result isn't much better. I think the main challenge is speed, both in terms of shutter release and shutter speed, since it's mainly indoor.
In ideal situations, the E-PL6 and E-P5 should perform about the same, but I expect in less than ideal, the E-P5 should have an edge. It sounds like the 5-axis IS is better for video as well, which is a bit more of a secondary concern, however definitely nice to have.
I am taking a bit of a size/weight hit by going with the E-P5 but I think part of this is due to better build quality and I think it still is reasonably compact.
I assume trading the 14-42 IIR in exchange to moving up to the E-P5 should be worth it? On a side note, I'm considering picking up a used 12-50 EZ lens as this seems to be a more versatile lens than the 14-42 IIR.
I know what I really need is a fast prime, but I think the zoom will give me flexibility and let me figure out what focal length will work best for me (the ones I am considering are the 17mm 1.8, 20mm 1.7 or 25mm 1.8).
Olympus PEN E-P5 Olympus PEN E-PL6 Panasonic Lumix DMC-TZ4
tt321
tt321 Forum Pro • Posts: 13,854
Re: E-PL6 vs E-P5
Can you find Panasonic kit zooms cheaper?
Jeff4500
Jeff4500 Senior Member • Posts: 1,921
Re: E-PL6 vs E-P5
I've had an EP5 for about two years, I love it. The 14-42 II R does work well for stills and video. In darker rooms use the built-in flash. I'd look for a used 14-42 II R - often less than $100 US here on the various sites - look on Ebay in your area or one of your local stores that has used stuff.
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: E-PL6 vs E-P5
I would forget about either of those two lenses. Far better lenses are the Panny 12-32, Panny 14-42II or the Panny 14-45. If you are using flash, one of these is all you need.
I have the EPL5 and the EP5 and use the 12-32 on the PL and the 14-45 on the EP.
The best of these optically is the 20 (I have it) but it has a slightly slower focus motor compared to the other two and may not be quick enough to keep up with your kid. I do not own but have used the 17. It is a decent lens and good enough for what you want.
Allan
LeeS Contributing Member • Posts: 889
Re: E-PL6 vs E-P5
I think the EP5 is a much better camera and that you should stick with it. I had the EPL5 (which is not much different from the EPL6) and I found the EP5 to be a big step up. In addition to the factors you mention, the twin dial controls are superior to the fiddly back wheel, the LCD is higher resolution and with the  latest firmware you have access to the essential electronic first curtain "zero second" anti-shock shutter.
So do what you need to do with regard to a lens, but keep the EP5. You may also hear from forum guru, Guy Parsons, who I believe has happily transitioned from a pair of EPL5s to a pair of EP5s.
Lee
 LeeS's gear list:LeeS's gear list
Olympus PEN-F OM-1
OP bwalter New Member • Posts: 4
Re: E-PL6 vs E-P5
No, the Panasonic lenses seem to cost just a bit more than Olympus. In fact, Even the Olympus 14-42 II R is $300 unless I order it at the same time as the body, so that ship has sailed.
There seems to be a used 12-50 EZ on Craigslist for $200. Or I can order the 14-42 II R used from a camera store for $150. Craigslist also has a "new condition" E-P1 with 14-42 f/3.5-5.6 zoom lens and 2.8-16mm lens for $150 which seems like a steal for the lenses.
I'm not sure where else (forums?) to look for used gear in the Vancouver BC area.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: E-PL6 vs E-P5
In my case now E-P5, migrated from E-PL5 which is the close featured brother of the E-PL6.
Suddenly a jump in reliability of the results due to 0 second anti-shock (absolutely essential) and the 5 axis IBIS for extraordinarily good stabilisation for stills and video.
The handicap (when compared to the E-P5) of the E-PL5/6 is the lack of 0 second anti-shock and the older 2 axis IBIS that they both use.
As for lenses, early on with the E-PL5 I spent the $$$ and got the chunky but excellent 12-40/2.8 lens, now of course on the E-P5 to make a perfect match that works well in very low light when using sensible aperture and ISO choices. In daylight of course the smaller aperture kit lenses do OK, but the chunky 12-40mm is definitely king of the heap.
Otherwise the kit lens plus a suitable large aperture prime selected for your most useful focal length solves the lower light problems.
Meanwhile some help with the E-P5 menus via my page http://homepages.ihug.com.au/~parsog/olyepl1/56-ep5-custom-menus.html
And some help with the ever useful MySets at http://homepages.ihug.com.au/~parsog/olyepl1/52-epl5-mymodes.html
Regards..... Guy
Re: E-PL6 vs E-P5
Thanks for all the replies from everyone so far. I was trying to keep things inexpensive, which is why I was going to go with the "good enough/great value" E-PL6 kit, but I just couldn't pass on the E-P5 for the price, (I'm guessing it's a preview of what we will see when it's blown out for the new model) but now it's seems I'm being steered away from the "good enough" kit lens as well.
I definitely appreciate the advice though, because on the one hand I did see not being forced to buy the kit lens as a plus (even though it inevitably means more $$$.)
I do think the 17mm 1.8 might be a better choice due to focus speed and the wider angle than the 25mm, but again, it's the priciest of the primes I listed.
In any case, I need to look in earnest for a lens. I got the email that the body has shipped and it would be a shame not to be able to use it.
joachim05 Regular Member • Posts: 373
Re: E-PL6 vs E-P5
For a toddler, get the E-P5.  It is way faster.  You can see measurements of timings on imaging resource (ok, they tested the E-PL5, which in most aspects should be the same as the E-PL6).  The E-PL7 and E-M10 are also slower than the E-P5.
Considering the lenses, kit lenses are worth next to nothing, as you figured.  If you buy a kit, you get them thrown in for a song.  On the other hand for todlers they are pretty useless as well.  To slow.  IBS does not help with toddlers you need a fast shutter.  I loose many images of my girls due to motion blur.  The 45/1.8 is an excellent, inexpensive and fast lens for toddlers.  Many times it saves you from using a flash, which at least I don't like to apply to them directly.  For indirect flash one needs a powerful unit, which unbalances a Pen.  A 25/1.8 or 25/1.4 would make a good second lens in my view.
Hope this helps.
Astrotripper Veteran Member • Posts: 8,676
Re: E-PL6 vs E-P5
With a small prime lens, it will still be a pretty compact setup. And it is a different beast than the E-PL models.
Yes. That E-P5 should easily serve you for a good chunk of time, provided you don't catch G.A.S. The lack of EVF is probably the biggest complaint you could have about it, but even that can be solved if you hunt down a used attachable EVF.
Yes, if you can get one at a good price, that's not a bad idea. It will however make the camera rather bulky (the lens is rather long), even if it's actually lightweight. If I were in your shoes, I would not bother with the standard Oly 14-42 R zoom, unless you can get one for pennies.
IMHO, this would really make the biggest difference. It would allow you to shoot without using flash in many situations that would require it when shooting with a slow zoom lens. Not to mention the ability to get shallow depth of field (this should be easy when shooting a small child from close distance, even with a lens as wide as 17mm).
And there's one option which might not be for everybody, but I find interesting. Get a cheap legacy lens and an adapter to mount it. There's plenty of fast 50mm primes in a variety of mounts. You can probably get one for 20-30 bucks, and an adapter would be about $10. Most of those legacy lenses are nowhere near close to the quality of modern lenses designed for digital cameras. But still, it's a very cheap way to have some fun. And you can get nice results, especially when you have time to set things up, so a posed family portrait or something like that. Just throwing an idea. I know I enjoyed this kind of stuff when I bought my first mirrorless camera (E-PL1, body only) and only had legacy M42 lenses to use with it. Now that I have more shooting experience, I can actually notice and enjoy the unique look some of my legacy lenses produce.
And about using flash, if you actually find yourself needing it often, I highly recommend buying a proper unit. A second hand Olympus FL-36R can be had for very little (got mine for about $100). It's an old model for 4/3 system, but is compatible (except the focus assist light, which will not work on Micro 4/3 cameras). You will not believe how big of a difference it makes when you bounce the light off of a ceiling instead of blasting it straight at your subjects. And it can be set up so that the built-in flash triggers it remotely, so you can experiment with different lighting setups.
Well, that ended up being quite random and all over the place
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Re: E-PL6 vs E-P5
Adapting sounds interesting, but as you mentioned, it would take time to set up the shot due to the manual controls. I talked to my father today because I knew he had a Pentax ME Super and Pentax K mount lenses. Turns out he also has an older model with the M42 mount and the 50mm 1.4 lens for it. In the K mount he has the 50mm 1.7 lens and he thought he had a wide angle but hasn't found it. I know he had the 40mm 2.8 pancake but I think it and a second ME Super were damaged beyond repair when they fell into a lake.
In any case, I'm excited to try the 50mm lenses, as based on reviews they seem to be considered very good.
On a different note, too bad the Panasonic 25mm 1.7 lens is not available right now at the spectacular $99 price it was being sold for recently. I'm thinking that would have been a good start for a native lens on a budget.
Re: E-PL6 vs E-P5
That might be one of the Takumars. If so, this is a sought out lens due to its unique rendering. Anyway, that puts you in a very comfortable position, as a M42->MFT adapter is very cheap, so even if you won't like the experience, it's not a big loss. With modern focusing aids like focus peaking, working with a manual focus lens is not really that hard.
Yep, at that price, it's got no competition. I'm using it on E-M10 and enjoy it. Despite the fact that it's not as sharp as you would expect a prime lens to be. It never really gets very sharp, to be honest. And it's not as small as some other lenses of similar focal length. But I like the bokeh rendering. Unlike Olympus 45/1.8 for example, which makes things buttery smooth, Panasonic 25/1.7 has a bit of a character to it. It's a bit like some legacy lenses, only not as extreme. Something like this .
