XF 14mm f2.8 r not sharp?
Started Dec 15, 2015 | Discussions
gabito New Member • Posts: 4
Hello,
I have been trying out the XF 14mm f2.8 and feel quite disappointed as its not very sharp. It was very expensive too and I have read that its a very sharp lens everywhere. Even the images I have shot with a decent handheld shutter speed are looking a bit soft. I'm a total noob so please let me know if the softness is normal or if I'm doing something wrong or the lens is faulty. Thanks!
Here are a few:
The only sharp images I have gotten from it are the close up ones where I am like 15cm away from the subject like these two:
Any suggestions?
Thanks!
Vic Chapman Forum Pro • Posts: 10,694
Re: XF 14mm f2.8 r not sharp?
Just check that the manual focus on the lens focus ring is not engaged. This lens manual focus is engaged by sliding the focus ring backwards and will also reveal the distance scale so if you can see that it means you have the manual focus engaged and need to slide the focus ring forward. In fact - if you can turn the focus ring then you have manual focus engaged.
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
OP gabito New Member • Posts: 4
I checked that already its on autofocus. I find it hard to use the lens on manual focus as it doesn't show up on the viewfinder screen very well.
georgehudetz Veteran Member • Posts: 6,299
7
There's nothing wrong with your lens.  A few suggestions:
  • Stop it down - depending on the scene.  At F2.8 only your focus point will be in focus.  Peak sharpness for the center if F4, and for the edges F5.6-8.  Using a smaller aperture will bring the whole scene in focus, like your street scene.
  • Use ISO 200 whenever possible.
  • For static scenes, if you have steady hands, you should be able to shoot at 1/30 of a second.  1/60 if there are people moving.
  • Experiment with the sharpness & NR settings.  Make sure the NR is not cranked up when shooting low ISO scenes.  Probably can bump sharpness in those situations as well.
For static scenes, I suggest setting SS to auto, and engage auto ISO with a min shutter speed of 1/30 & max ISO of 6400.  Then choose the aperture that gives you the depth of field you want.  If the scene has a moving element, and the shutter speed comes up too low, just move the SS dial to 1/60 temporarily and let the auto-ISO do it's thing.
 georgehudetz's gear list:georgehudetz's gear list
Panasonic Lumix DC-S1R Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Sigma 14-24mm F2.8 DG DN Panasonic Lumix S Pro 16-35mm F4 +4 more
Thank you very much! I will go out tomorrow and shoot with your suggestions (its dark out) and see what happens.
pluton Veteran Member • Posts: 3,515
You obviously don't realize how lucky you are to possess a very wide angle lens that is that sharp, and that sharp across the frame, wide open at f/2.8.
Your lens looks fine.
-KB-
oscarvdvelde Senior Member • Posts: 1,421
It looks perfectly fine to me too. If the original poster thinks it is still a bit soft, then it could be the JPEG processor. It always gets much better in a good raw converter.
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
Obviously.
win39 Veteran Member • Posts: 5,560
I don't think they are unsharp. They are just low contrast. Give them a little less exposure in post and maybe a touch of clarity and they look pretty nice.
57LowRider Veteran Member • Posts: 4,240
I have a 20x30 landscape print on my wall, shot with the X-E1 and 14 at f8 handheld, it's sharp across the board.
At the other end of the spectrum, f2.8 can give you decent bokeh for this focal length. The front element was touching the central petal here, you have to get right in there! -
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +11 more
