What type of new 50mm f1.4 lens you want from Canon?
Started Dec 15, 2015 | Discussions
KLO82 Senior Member • Posts: 1,527
Canon 50mm 1.4 is an old lens and needs o be updated according to many users. It is an older design where the lenses are somewhat hazy at the largest aperture (due to spherical aberration) and gain contrast by stopping down to f2 and beyond. Other lenses of similar design are Zeiss Planar T* 1.4/50 and Nikon 50mm f1.4G, they show similar characteristics. But the advantage of these lenses are, they have fewer optical elements and so they are light and small, and are relatively cheap.
On the other hand there are modern 50mm lenses from Sigma and Zeiss, which are better performer at wider apertures. These lenses have more optical elements to correct spherical aberrations and so they are heavier and larger, and pricier and much better performer at wide apertures.
Here is a comparison between these lenses:
Lens - No. of optical elements/ groups - weight
Nikon 50mm 1.4G - 8/7 - 280 grams
Canon 50mm f1.4 - 7/6 - 268 grams
Zeiss Planar 50mm f1.4 - 7/6 - 380 grams
Zeiss Otus 55mm f1.4 - 12/10 - 1020 grams
Zeiss Milvus 50mm f1.4 - 10/8 - 922 grams
Sigma 50mm f1.4 Art - 13/8 - 815 grams
One example of older design lens vs newer heavier better performer replacement is Zeiss Planar 50mm 1.4 vs Milvus 50mm f1.4.
So what type of new 50mm f1.4 lens you want from Canon? Older design, moderately priced, light lens (though of course comparatively better performer with better focusing than the current lens, because otherwise there would be no point of releasing a new version). Or a newer design, larger and heavier and much better performer at a higher price point?
 KLO82's gear list:KLO82's gear list
Canon EOS RP Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 24-70mm F2.8L II USM Canon RF 35mm F1.8 IS STM Macro
Great Bustard Forum Pro • Posts: 45,641
The sharpness of the Nikon 50 / 1.4G...
...with better bokeh, less CA, and IS at 400g and $699 would be the ticket.  But, that's not gonna happen, of course.  I'm hoping the 50 / 1.2L II will be just as good, if not better than, the 35 / 1.4L II.
tonym38 Forum Member • Posts: 99
Re: What type of new 50mm f1.4 lens you want from Canon?
I would like to see:
Improved optics, along the lines of the 24mm f2.8, 28mm f2.8 and 35mm f2 lenses that Canon released a short while ago.
Ring type USM focusing motor, as opposed to the current USM micro motor.
Image Stabilising, although this would not necessarily be a deal breaker for me in a lens with a f1.4 aperture.
The above improvements would probably result in a heavier lens, but the weight needs to be kept down as much as possible.  The Sigma Art and Zeiss lenses may well be very good performers, but in my opinion, they are too heavy for this focal length.
Once again, the above improvements would probably result in a higher price tag.  However, this needs to be kept down as much as possible.  As in the case of the weight issue mentioned above, the Sigma Art and Zeiss lenses are too expensive, relative to their focal lengths (IMO).
If Canon could achieve the above, I  think they would outsell the other 50/55mm lenses by a long margin.
Cheers, Tony
 tonym38's gear list:tonym38's gear list
Canon EOS 10D Canon EOS 40D Canon EOS-1D Mark IV Canon 6D Mark II Canon EF 50mm F1.4 USM +9 more
Timbukto Veteran Member • Posts: 4,988
I prefer the light uncorrected 50mm 1.8 STM at the moment.  At wide open apertures, having it sharp frame to frame is great for test charts, otherwise the spherical aberration is fine for some portraits along with very simplistic and pristine bokeh highlights compared to onioned ones.
I'd rather they revamped the 85mm 1.8 and do away with sample variation like they did the STM.
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
I'm not a fan of the wide open haze, thing.  Lower resolution, sure, but I hate the haze.
I think an 85 / 1.8 IS is the most important update Canon could release at the moment, assuming it has the same IQ improvement from the 85 / 1.8 that the 35 / 2 IS had from the 35 / 2.  Myself, I'm anxiously awaiting a 100 / 2 IS along the same lines.
Abu Mahendra Veteran Member • Posts: 5,312
Canon EF 50mm f/2 L IS USM Macro 1:2
...essentially the 50mm brother to the 100L, very sharp and very contrasty from the get-go.
>> I am already lovin' the Canon EF 35L II lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
Yes the astigmatism coma is crazy.  But carrying the 50mm 1.8 STM + 6D is very carefree and light compared to a Sigma 50mm 1.4 Art.
I like to experiment and see how much I have to PP the photo and resize to take away the characteristic Canon 50mm wide open look.
OP KLO82 Senior Member • Posts: 1,527
I agree. I also like wide open softness in portraits. Though many here will argue that you can capture the sharpest possible photo and make it softer in post process as well. Here is a portrait at f2, captured with 50mm STM. Even at f2, you will be able to see the acnes on her face.
Nikon 58 1.4 is designed to have a certain balance such that wide open it obviously has its share of spherical aberration.  It's also a light lens, but not cheap.
kotmj Contributing Member • Posts: 571
We already know how Canon's fast 50mm will look like. There has been a string of patents. Pretty long barrel.
Didn't know that!
Re: The sharpness of the Nikon 50 / 1.4G...
I would love the same or more sharpness as 50mm 1.4G, around ~350g and $450-500.
Digitalis32
Digitalis32 Contributing Member • Posts: 574
Basically a contemporary re-make of the 50mm f/1.0L
I have the old 50mm f/1.0L, and it has issues: but I think Canon could make several optical and hardware improvements that could make it really stand out among the "Me too" 50mm f/1.4 lenses.
 Digitalis32's gear list:Digitalis32's gear list
Leica M Monochrom (Typ 246) Leica M (Typ 262) Pentax KP Pentax K-1 II Leica Summilux-M 21mm f/1.4 Asph +13 more
Canon's latest patent for a 50/1.4
The L2 group slides back and forth for internal focussing, so this will be a quick USM.
https://www.flickr.com/photos/126939108@N02/
With 11 elements, it will be a large and expensive lens (if it materializes). I wonder what will be left for Canon 50mm L.
Jonathan Brady
Jonathan Brady Veteran Member • Posts: 6,725
I'd like to be able to sell my Sigma 50mm f/1.4 Art and my EF 50mm f/1.4.  I keep the Sigma because it's plenty sharp even wide open.  I keep the Canon because my wife likes the light weight.  If Canon can make something that's in between the 2 of these, weight-wise, and is sharp wide open, I'm in.  If it has IS, I may even pay the early adopter fee and get it right away.
mrmjs
mrmjs Contributing Member • Posts: 523
How bad is the current Canon 50 f/1.4? Is it worth $275?
 mrmjs's gear list:mrmjs's gear list
Canon EOS 6D Canon EF 70-200mm F2.8L IS II USM Canon EOS 7D Mark II Canon EF 50mm F1.8 II Canon EF 135mm F2L USM +3 more
crashpc Veteran Member • Posts: 7,240
Many say it is not good, many have problems with it, especially these who don't handle it very genly, but I must say it still has something over these 1.8 versions, and I don't have big problems in geting very sharp image wide open for no smaller resolution than 2560x1440p. I'd still recommend it for these who know what they nee, and for those who value faster aperture setting for good money.
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
Not too shabby!  In my opinion, the 50 / 1.8 STM is the best bang-for-the-buck lens out there (aside from the lenses in our cellphones, which, of course, come for free with the phone).
